Old 01-05-2015, 03:17 PM   #127
redphaser
Drives: 2015 Subaru BRZ Limited
Originally Posted by Target70 View Post
... once I had the pin out, I used a pair of channel lock pliers, with the pedal up I just clamped the top and bottom spring pearches in the jaws, then pressed the pedal to the floor with my other hand, let go with the pliers and it shot right out.
I wish I had enough posts to thank you for this one. I just did the removal and fought with that SOB for nearly an hour before finding this, which did the trick.
The clutch feels so much better without the spring. It feels more "mechanical" in a way, and less like the clutch from a gaming wheel. I still need to drive it around for a few days to get fully adjusted to it, but I took it around the block and I definitely will not be going back.
Thanks all!
redphaser is offline   Reply With Quote
Old 01-05-2015, 05:54 PM   #128
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Thanks all!
You are welcome, glad it worked for you. I wrestled it for a while too before I tried that.
Old 01-07-2015, 07:10 PM   #129
klittl06
Drives: FRS?
I took a look today at my clutch pedal but it doesn't look like the spring rotates at all when pressing the clutch. It just looks like its making the pedal harder to push (like someone mentioned on the first page).
I don't have a difficult time driving the car by any means, I just prefer a stiffer clutch. My clutch as is seems to have a "dead spot" for the first inch or so as many have described post spring removal.
I wonder if the original owner messed with it... My car didn't come stock, so I guess it's a possibility. Or maybe I'm just being dumb; I'm open to both scenarios.
klittl06 is offline   Reply With Quote
Old 03-13-2015, 11:41 PM   #130
eric6
eric6's Avatar
Drives: 93 MR2 Turbo; 2014 BRZ
I just wrote a decent how to on this modification. Took me 15 minutes learning how to do it and taking photos along the way.
http://www.ft86club.com/forums/showthread.php?t=84622
eric6 is offline   Reply With Quote
The Following 2 Users Say Thank You to eric6 For This Useful Post:
flippy (05-01-2015), Slysdexia (03-19-2015)
Old 03-17-2015, 03:27 PM   #131
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
Just removed this over the past weekend. Should have done it a year ago.
Mad_Mike is offline   Reply With Quote
Old 03-18-2015, 03:51 PM   #132
kbye
kbye's Avatar
Drives: 2014 FR-S
The Gs and 370z have this exact same problem, and people reported a bit of free play when they removed their spring as well. Some members swapped it with a lower rated spring, and that seemed to be a balanced solution of increased pressure plate feel with no free play in the pedal (by keeping a softer spring in there).
If anyone won't miss their spring too much, mind sending one to me? I'm going to try to experiment with different spring replacements and I misplaced mine :/
I know the free play isn't a big deal but I figure it's something I can fiddle with and fine tune while waiting for my other parts to arrive.
kbye is offline   Reply With Quote
Old 05-05-2015, 12:47 PM   #133
D_Thissen
D_Thissen's Avatar
Tried to do this today, couldn't get the Damn pin out. I tried with the clutch pedal depressed also. Anyone have any tips?
Old 05-05-2015, 01:08 PM   #134
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Originally Posted by D_Thissen View Post
Tried to do this today, could get the Damn pin out. I tried with the clutch pedal depressed also. Anyone have any tips?
Get the biggest flat head you can fit in there and use the thing holding the pin/spring as leverage.
The Following User Says Thank You to Andrew025 For This Useful Post:
D_Thissen (05-05-2015)
Old 05-05-2015, 01:43 PM   #135
Aozora.BRZ
Aozora.BRZ's Avatar
Drives: '15 WRB Series.Blue
But what really worked well, was once I had the pin out, I used a pair of channel lock pliers, with the pedal up I just clamped the top and bottom spring pearches in the jaws, then pressed the pedal to the floor with my other hand, let go with the pliers and it shot right out.
After taking the pin out I almost got a hernia trying to remove the spring. Locking Pliers saved my day as it was so easy to remove with them using this process.
It has been a week after removing the spring and adjusting the pedal height and I can't understand why the car did not come like that stock.
I learned MT on this car so I was already adapted to the original setup, but this mod instantly improved all my shifting activities. I can up/downshift so smoothly now. I can take of from stoplights faster as well.
No more guessing where the clutch engages. I just want to drive and drive...
Aozora.BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to Aozora.BRZ For This Useful Post:
jcw99 (08-02-2016), Target70 (05-05-2015)
Old 05-05-2015, 01:54 PM   #136
D_Thissen
D_Thissen's Avatar
Right on, thanks! Ill try again later. I think Ill just bust out the pry bar instead
Old 05-05-2015, 01:55 PM   #137
Aozora.BRZ
Aozora.BRZ's Avatar
For the pin lock it didn't matter whether the pedal was depressed or not. That helps when you take out the spring. For the pin I pushed it back from the ends of the U shaped lock with a set of pliers. It comes in and out sideways, so you would be pushing the pin lock towards the front of the car. There are some good pictures on this thread: http://www.ft86club.com/forums/showthread.php?t=84622
After removing the lock i used channellock pliers to push the end of the pin. Once the pin moves back a bit, I used the flat screwdriver and some force to pull it out using the pin head,moving the pedal up and down a little bit. while pushing it out.
For the spring removal, get a set of locking pliers and lock it at the top and bottom of the spring assembly. Once it is locked, press the pedal and the spring assembly will separate from the pedal, allowing you to push it back and take it out. Took a couple attempts as the pliers were not tight enough, but a lot easier than trying to do it manually.
Old 05-12-2015, 03:55 PM   #138
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
Great review on removing the clutch pedal spring but I've noticed that no one has commented on clutch adjustment for aftermarket (High Performance) clutches... I've been looking on our forums but it doesn't seem that anyone is running a heavy duty pressure plate (Exedy Hypersingle, ClutchMasters FX400/500, ACT stage 4+, etc).
I'm guessing this mod might not benefit those that have heavy racing clutches?....
Just my two cents but I hope some peers will chime in on this thought.
shiro is offline   Reply With Quote
Old 05-12-2015, 06:19 PM   #139
DemonRawr
Drives: 2014 BRZ Limited 6M
I would like to ask if ANYONE have discover that the removal of the spring actually causes the clutch to slightly be engaged even without any pressure on it? About a month after removing the spring (car is at 12,000) the clutch began making squeaking noises everytime you depress it during the first 15 minutes of driving. I do NOT ride my clutch as I just rest my foot on the dead peddle. Even if I did from everyday driving, how can it wear out so early? So that brings me back to my question... Does removing the spring cause the clutch pedal to sit lower, thus causing it to engage? Can someone reply back ASAP?
DemonRawr is offline   Reply With Quote
Old 05-12-2015, 06:41 PM   #140
Cuchullain
Cuchullain's Avatar
Drives: 2013 GBS Subaru BRZ Limited
Originally Posted by DemonRawr View Post
I would like to ask if ANYONE have discover that the removal of the spring actually causes the clutch to slightly be engaged even without any pressure on it? About a month after removing the spring (car is at 12,000) the clutch began making squeaking noises everytime you depress it during the first 15 minutes of driving. I do NOT ride my clutch as I formed a habit of just resting my foot on the dead peddle. Even if I did, how can it wear out so early? So that brings me back to my question... Does removing the spring cause the clutch peddle to sit lower, thus causing it to engage? Can someone reply back ASAP?
FWIW my spring has been out for approximately 10,000 miles, and I don't get any squeaks. Soon after I removed the spring I also added a bumpstop behind the pedal to shorten the distance to bottoming out the pedal, and more recently I have replaced the clutch master cylinder to the smaller bore one. No problems
Cuchullain is offline   Reply With Quote
The Following 2 Users Say Thank You to Cuchullain For This Useful Post:
DemonRawr (05-12-2015), jcw99 (12-21-2015)
clutch helper spring, helper spring removal
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
