#127 |
Drives: Toyota GT86
First case in Peru
After abiut a year of tracking once a month, I got the first P0352 CEL, cleared it, took it to the dealer and they said nothing appeared to be wrong. Next month, another track day, same P0352 CEL, but now with popping under the hood. Back to dealer. They replaced a bad injector but not the coil. Next track day, same thing, with popping again. Now back at dealer. They say injector is ok, but replaced the coil this time. When they were testing it, another coil failed, so now they've called in the cavalry, as this is the first case here in Peru and they want to be as thorough an by the book as possible. Problem is it looks like I'm more up to dat on the issue from reading this forum than they are. Just told them about the stock tune and the reflash.. They hadnt heard of it. Dont want to swap in the spare Okadas I have yet so the warranty is still good. im not a mechanic, but Im still not sure if the P0352 is coming up due to a faulty coil, or a faulty injector, if they are necessarily related, and if so, which causes which.
No engine mods at all. Just a perrin catback, and wheel and suspension upgrades. |
#128 | |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
P0352 is for #2 coil malfunction and on certain vehicles the ECM may shut down the associated injector when that code is thrown. I'm not sure yet if the code is directly correlated with DI seal failure. I've done a few track days since getting P0351 and replacing my #1 coil and haven't had any issues since. I should mention that since last year I've been running a tune based on the latest B01C revision which includes the DI seal fix (prevents high-rpm detonation between shifts). I'm also running E85 at the track which lowers cylinder temperatures and is much more knock resistant. If you track the car frequently I'd recommend getting the latest tune revision either through your dealer or an EcuTek tuner. Make sure you're running at least 93 octane gasoline and if you can get E85 there then a Flex-fuel kit and EcuTek tune is a good option to help the engine handle track abuse.
#129 | |
then you can also log If your on (C rom or G rom) with tactix and adjust tune with Romraider or Ecuflash. Logging should work with other rOM you would have to get the rAM addresses from the romriader guys. http://www.ft86club.com/forums/showthread.php?t=62332 run E85 see here with Openflash Tablet www.openflashtablet.com http://www.ft86club.com/forums/showthread.php?t=67310 or you can use Ecutek plenty of options |
#130 | |
Drives: Toyota GT86
Yeah, the first tine it was the direct injector that went bad due to the seal issue. This time though, I got the sane CEL and the popping sound but they say that the injector is ok. That I find weird. I'd think that at least the seal would have to go bad in order for popping to occur. But them again I may still be in the bad comunicación phase with the dealer. Still haven't got the car back. But they did clarify that no additional coil went bad. They aré still searching for the answers . I only use 98 octane fuel or at Worst 97. No other real options here. I'm definitely getting an Ecutek tune after this whatever the outcome. |
#131 |
Drives: Toyota GT86
Only one local tuner here that I know of who's worked on a single GT86 in tandem with a remote tuner in the US.
Gonna bring in an Ecutek kit next week. |
#132 |
Turbo 86
Drives: Toyota 86 Turbo
Very good read.. just had my error. . 40 000 km on clock after two misfire errors on coil one... will take is in.
#133 |
Drives: BRZ Ltd WRB, MT6; '91 M5; '89 911
After several episodes of P0351 CELs being tripped, took car to dealer. They say it isn't likely the coil, but the 'pins' in the harness. They are keeping the car, drive it and get it warm to test that idea.
Anyone heard of this before? What are the 'pins' that they are talkn' about? Thanks |
#134 | |
I just got a persistent P0353 today at the track and ruined my day since I parked the car not taking any risks. My #3 coil is acting up now after my #1 did the same thing back in March at the track and has been fine since replacing the coil. Just ordered two new coils. This is getting old quick. Someone needs to manufacture some decent performance coils with HEAT SINKS on them! |
#135 | |
Drives: '14 Monogram 6MT FR-S - Hot Lava
My thought is that perhaps they're near max duty cycle under hard driving conditions, and the passenger side head having the exhaust under it is only exasperating the issue. Maybe some sort of heatshield will improve coil life?
#136 | |
That's a good understanding of what's happening, but nobody knows with certainty if that's the true cause of failure. Go back a few pages in this thread and you'll see some heat shield ideas that I thought of and came to concept thanks to @gramicci101 |
#137 |
Off Topic
Those are actually GM LQ9 coils that Mojo builds brackets to use with various engines. I'm not having any luck finding physical dimensions for the injectors to see if they'd fit though.
@MAPerformance, are the Okada coils priced individually or as a pack of four? Are they any more tolerant to heat than the OEM coils? Cusco's are too expensive. Alternately, you could contact Accel, MSD, or similar companies about making some. Last edited by gramicci101; 07-21-2014 at 10:35 PM. |
#138 |
Off Topic
Ok, I don't think the LQ9 coils will work, at least not with a fair amount of modifications.
Here's a GM coil compared to a Supra coil. ![]() Our coils are similar to the Supra coils, but I don't think the body of the GM coil will fit into our block. Also, we would need a bracket to hold them down. |
#139 |
If I had to put money on it, it's a combination of things. The theme of the car seems to be tolerance stacking.
Max duty cycle, plus negligible airflow, plus hot cylinder heads from hot oil, all having to cope with the extra heat from being 6" above a close coupled catalytic converter. Fine copper wire, epoxy, and enamel don't like heat. We'll see what Toyota/Subaru do on the mid cycle refresh, if anything. It might end up like the RX-8 and someone adapts a readily available, unkillable coil to our platform, and it turns into a "do this first" mod. Sent from my hand computer using radiation.
#140 |
Off Topic
Does anyone have a diagram of the BRZ coil that shows physical dimensions and output voltage? I'd like to farm it out to the various ignition coil companies to see if there's an existing product that would work, but my google-fu is weak. Some of Accel's supercoils look like they would work, but right now I'm just guessing based on appearance.
| WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset | GC GTS Aero Kit | Australia Classifieds | 16 | 03-22-2013 05:49 AM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 05:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| Shutting off your "key-in-with-door-open" beeper -- it's very easy | avusblue | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-13-2012 05:29 PM |
