#127 |
Drives: Legacy GT
Well, it doesn't specifically "generate extra downforce to the spoiler," but in theory it keeps flow attached to the rear window and decreases drag. It would take actual testing to determine if that increased downforce.
That actually looks pretty nice and probably doesn't hurt. I wouldn't expect huge numbers but it might be enough to turn a little bit of lift into a little bit of downforce. |
#128 |
MODERATOR-SAMA
Drives: Swagtron Scooter
You know why the diffuser center channel curves upwards? because it doesn't need to be flat anymore. No reason to keep up air velocity after air has reached behind the axles. It doesn't do anything to the downforce or liminar profile on the vehicle by extending it. Instead, use the high pressure air stream made up of slower moving air molecules and divert them to the area that greatly suffers from wake and vacuum which is directly behind the trunk and centerline of the vehicle.
#129 | |
Drives: Legacy GT
#130 |
Drives: vw mk4 r32
This is Alvin from Borla Performance in CA. I did not know about this discussion... Thanks to OrbitalElipses for cross-posting. The intent of our exhaust diffuser (77012) is an aesthetic accessory to our cat-back (140496), filling the void of the OE muffler, and returning OE-level aerodynamics.
I compiled this video footage yesterday with a quick edit today. I did not have the stock exhaust as a baseline. Perhaps one of you can make this video for us.. ![]() I look forward to reading and learning from all of you here. Let me know if you have any questions. Thanks in advance. |
#131 | |
MODERATOR-SAMA
quick examples of what i was thinking of... ![]() ![]() ![]() The air current from rear spoiler and rear diffuser may interact, but at which point? How is there interaction after the airflow has detached from the vehicle a major deal? if the underbody surface is continuously flat after the rear axles how is this any benefit when you can just taper off when it reaches high pressure atmosphere.
#132 | |
Kuruma Otaku
On a FR-Z, the effect won't be as much as on an Evo, I think. Plus we have the roof sculpting, which could be doing something already. What? I have no clue.
Because titanium. |
#133 |
Drives: Legacy GT
Well, you want to make the area of flow separation behind the car as small as possible and do what you can to draw air out from under the car. So if you have a diffuser, it will create a low pressure area under the car. If you have a wing or spoiler down low off the trunk deck there will be a low pressure area below it which will help draw air out from the diffuser and create more downforce just from the underbody plus reduce drag. A smoother transition from the diffuser to that low pressure area would probably be helpful.
But, like I said, it just *looks* like it would work well. |
#134 | |
Kuruma Otaku
Because titanium. |
#135 |
Drives: vw mk4 r32
Borla Cat-Back™ + optional Exhaust Diffuser (combined weight 3-lbs less than factory cat-back)
![]() ![]() ![]() Slight curve adds rigidity. Angled up ~10degrees to rear.. |
#136 | |
MODERATOR-SAMA
So in order to make this downforce by.....how? because the way i see it..the low pressure area is already making the most downforce, and feeding it any sort of air perpendicularity especially high speed air will make it no longer a low pressure zone, but normalized atmosphere. but you talk about reducing drag behind the trunk area using a smooth transition from the diffuser..then...exactly how was I incorrect when i said, the reason why the center diff channel feeds upwards was to divert "to the area that greatly suffers from wake (turbulance) and vacuum (drag) which is directly behind the trunk and centerline of the vehicle" sounds like we are talking about the same dam thing
#137 |
Drives: Legacy GT
Because of wing-body interaction. A wing that helps draw air out of the diffuser can make more total downforce with less drag than a just having a diffuser and a wing mounted up high working independently.
#138 | |
Kuruma Otaku
It's important to not just think in terms of just high and low pressure, but of pressure differences.
Because titanium. |
#139 | ||
Drives: Subaru
#140 | |
Drives: GBS Limited 6MT
Just don't move the camera while you install the diffusor and you can make a simple side by side comparison of rear ride height(obviously you need to be going the same speed in each video and not accelerating). Then the difference in rear lift is ~ ride height difference * 2 * rear spring(wheel) rate. Anyone with an aftermarket rear muffler who complains of excess rear lift could use this same testing technique to quantify the difference. Thoughts? |
| Front aerodynamics... need help! | TuxedoCartman | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 10-23-2012 09:27 PM |
| Interesting aerodynamics differences between USDM, JDM, etc. | yargk | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 09-20-2012 04:00 PM |
| Coefficient Drag & Aftermarket Aerodynamics | FT-86GOD | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 06-28-2012 01:20 AM |
| Video: FR-S / BRZ Aerodynamics and D-4S Fuel Injection Explained | Moshpit37 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 19 | 06-26-2012 09:19 PM |
| Video: FR-S / BRZ Aerodynamics and D-4S Fuel Injection Explained | Moshpit37 | BRZ Photos, Videos, Wallpapers, Gallery Forum | 1 | 06-21-2012 12:47 PM |
