Old 05-18-2014, 07:35 AM   #127
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Originally Posted by pseudo View Post
Does anyone have suggestions on a resource for rapidly learning the ME side of a good suspension setup? Specifically what the ultimate, theoretical goals of an ideal setup are, and the fundamental theory that drives suspension design. Books, technical papers, online articles, forum posts, etc would all be appreciated.
Race Car Vehicle Dynamics
http://books.sae.org/r-146/;
[ame="http://www.amazon.com/Race-Vehicle-Dynamics-R146-Publisher/dp/B004XEA3E2"]Race Car Vehicle Dynamics (R146) Publisher: Society of Automotive Engineers Inc: William F. Milliken: Amazon.com: Books[/ame]
The author's page on the book with links to further information, including a separate 300-page companion workbook, software, etc.: http://www.millikenresearch.com/rcvd.html.
dradernh is offline   Reply With Quote
Old 05-19-2014, 05:59 PM   #128
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
How do we figure out how much change in toe dude to ride height change with the numbers that shankenstine gathered for this car? I ask this because I have been measuring strange changes in rear toe dude to adding and removing weight of the factory muffler assembly and fuel levels.
Old 05-19-2014, 11:38 PM   #129
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Honestly, you'd need to refine the data if you wanted accurate toe curves. Especially at the top and bottom of your travel, minor errors in the "points" will give you major errors in geometry... and there are some minor errors in the data (to say the least).
The thought is with an open-source spot for the information, the Google Doc will evolve as people discover more and more accurate data. With the car being so new, there aren't many "grassroots" projects yet... but I have no doubt there will be plenty of people to over-analyze this car.
One potential twist for the thread that I've been scheming would be to use 3D scanners to generate full CAD models for each component. Assemble and constrain the system in Solidworks or Pro/E. Go as nuts with the simulations as you'd like. Design lighter/stronger/better components, 3D print your ideas, and pass your idea straight to a machine shop.
Anybody have access to a 3D scanner? Makerbot Digitizers are only good for 8" (diameter) x 8" (height). Not sure it would get the job done.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following User Says Thank You to Shankenstein For This Useful Post:
solidONE (05-21-2014)
Old 05-21-2014, 12:33 AM   #130
solidONE
solidONE's Avatar
I'm just curious about how much toe change within plus minus 1/2" from static height, so I can determine whether the toe change is designed in the suspension or due to the toe links not holding the alignment. I've gotten as much as 1/8" ~ 3/16" change in toe by just replacing the stock exhaust with a track pipe and a bit more than half tank less gas in the tank versus a full tank and stock muffler. That cant be more than 1/4" of change in rear ride height...
Old 07-08-2014, 07:05 PM   #131
solidONE
solidONE's Avatar
I installed some toe links coupled with eccentric lockout to try to eliminate possible slippage and toe change with the stock setup.
Here's the alignment specs with stock muffler replaced with a track pipe, all the stuff in the trunk removed and about 1/4 tank of gas.
Here's the alignment after I replaced the stuff in the trunk, factory muffler and filled up to about 3/4 tank of gas. (disregard the front alignment, I believe the front adjusters were not torqued down sufficiently causing it to shift)
A total of 0.26 degrees of difference between the rear toe with the weight added back on. According to this calculator/converter that's more than 3/16" of change in toe with only a quesstimated 50~60lbs difference in the rear. http://robrobinette.com/ConvertToeDegreesToInches.htm
That's is a lot of bumpsteer, no? Something wrong with this picture?? @Shankenstein @Wepeel
Old 07-29-2014, 08:00 AM   #132
Shankenstein
Frosty Carrot
You're going from 1/32" toe in... to 3/32" toe in. Obviously there's some variance in the data, but 1/16" (per side) is not insignificant for static settings.
For 60 lbs, that's 30 lbs/side. Rear springs are 211 lbs/in, so that's ~1/8 in. of compression.
I love extrapolating in public. If we have 2+ inches of travel, one could (wrongly) assume that the toe curve is a line... and your toe at full compression would be 1" toe in per side. Such stability, wow.
solidONE (07-29-2014)
Old 07-29-2014, 11:23 AM   #133
Wepeel
Drives: '13 BRZ Ltd
I remember from the earlier posts the rear toe change you were seeing seemed really dramatic. That seems like a HUGE change in rear toe for just a few pounds of weight... imagine if you are in the car or have a passenger or are carrying groceries, that would mean the toe would be changing. If I did the math right you are seeing a change of more than 1.5mm per wheel due to a weight delta of ~60 lbs. That just seems nuts to me...
I know you said to disregard the fronts... what did you think was loose between readings for the front?
I didn't do the experiment of measuring toe while adding weight to the trunk, but I know when I installed my coilovers, dropped the ride height by 1" in the rear, that the toe change was minimal enough for me not to have to reset the toe in the rear.
Wepeel is offline   Reply With Quote
The Following User Says Thank You to Wepeel For This Useful Post:
Old 07-29-2014, 02:08 PM   #134
plucas
plucas's Avatar
Drives: Subaru
Can you please translate that 1.5mm per wheel into degrees?
plucas is offline   Reply With Quote
Old 07-29-2014, 02:27 PM   #135
Wepeel
Drives: '13 BRZ Ltd
They're in his pic. I converted the degrees in his pic to mm.
Old 07-29-2014, 02:46 PM   #136
solidONE
solidONE's Avatar
So there's got to be something weird going on. I initially measured similar change in toe myself using measuring tapes, so 'operator error' was very likely. This prompted me to have this measured at an alignment shop with proper equipment. Hawkeye machine, in this case, with frikin laser beams. Lo and behold they get the same numbers I'd measured myself using wooden blocks and measuring tapes.
The front camber was added using camber bolts. I'm quite sure they were not torqued down sufficiently by the alignment guy who did it the first time. I actually felt the front alignment shifting while driving. The car would steer more or less in the middle of a turn without additional steering input. Pretty scary. I took it back in only a few days after the first alignment to get this fixed and got the printouts on my previous post. Funny thing is I actually did a trackday before getting it fixed and put down a personal best lap that day. Lol
Old 08-06-2014, 12:19 PM   #137
Wepeel
Drives: '13 BRZ Ltd
Holy Crap!
http://www.vsusp.com/
The Following 2 Users Say Thank You to Wepeel For This Useful Post:
Shankenstein (08-06-2014), solidONE (08-06-2014)
Old 08-06-2014, 06:41 PM   #138
Shankenstein
Frosty Carrot
I'm sure the scaling is off... but that's a mighty cool tool!
Link to VSusp
Old 08-20-2014, 04:38 PM   #139
fika84
fika84's Avatar
This thread is awesome! Great work so far gathering information.
No one wants to measure the suspension points of the car??
I used to work at OptimumG and have used OptimumK quite a bit. I've been very tempted to put the car up on jack stands and measure the points the old fashioned way so that I could have a good baseline to start with before I start doing suspension modifications. But it's a lot of time consuming work.
I contacted Bob Simmons over at Morse Measurements (http://www.morsemeasurements.com/), who has actually done some K&C testing on a BRZ, and has all of the suspension data, but he was reluctant to give any sort of deal (he wanted ~$1,600 for the data).
EDIT: Also very happy to see so many people saying "Damping" as opposed to "DampENing".... drives me crazy
fika84 is offline   Reply With Quote
The Following 2 Users Say Thank You to fika84 For This Useful Post:
Shankenstein (08-20-2014), Wepeel (08-27-2014)
Old 08-20-2014, 10:08 PM   #140
kavanagh
Fat on Corn Syrup
But, I doooooo need dampeners though.
Because it's hot and dry as hell in Phoenix.
The Following User Says Thank You to kavanagh For This Useful Post:
wparsons (08-20-2014)
New Rumor: Subaru Developing Turbo 4 2.0T for BRZ Hachiroku BRZ First-Gen (2012+) — General Topics 350 02-02-2013 02:52 PM
Need opinions on two new items we're developing! yospeed Cosmetic Modification (Interior/Exterior/Lighting) 56 12-03-2012 03:13 AM
Chances of Someone Developing 5x114.3 HUBS (not spacers)? Entropy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-04-2012 04:35 PM
Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) switchlanez BRZ First-Gen (2012+) — General Topics 68 02-14-2012 08:16 AM
