#127 |
Drives: RS 1.0 #633
Holy mother of all car build! Very nice!
#128 | ||
Drives: 1986 Subaru LEONE TURBO
![]() lol thanks man very excited about this radiator ! its a brand spanking new OEM Subaru 1988 Subaru XT6 2.7L H6 Radiator, its 2 core and also has the proper port size for inlet also outlet as a new EJ motors use. it's also a perfect match to my EA82T turbo radiator, same size same width same cap location same mount points and also XT6 rad hoses to complete the job. I wish I new all this from the start of the build, but it sure is going to be sweet next summer on the race track to do more laps in the heat, also the spal fans will bolt up in the same position as the gl-10 turbo mt rad. with the bigger radiator and my oil cooler this should complement the motor very well now. ![]() ![]() ![]() and my new trunk seal which took a long time maybe it was made for me in japan but it came in also oem subaru for that perfect fit, i had a small rip in mine that i didnt like.
#129 |
Are you 20/20?
Drives: Hopes and dreams
This build... I don't even ... Oh my God this is epic.
DAT build.
| The Following User Says Thank You to AznKirby For This Useful Post: | Nico TURBO (01-02-2014) |
#130 | |
LOL thanks man that was funny haha I been slacking on my updates, but most my parts are in for the spare EJ22T motor. i decide to get all new case bolts washers caps pretty much everything lol. ![]() also got a new weather stripping for the hood, the original one had a small tear in it. ![]() also picked up the original stickers for my rear doors, i have turbo on the door from factory but my car was a FWD not AWD... so i have to give it the subaru justice of the AWD.
#131 |
and here we have 2 EJ22T blocks out of 9 cleaned and ready for the shelf for when the time comes, lets hope no more broken motors for 2014 season..
#132 |
here is the spare EJ22T ill be using and its V9 JDM heads rods pistons all on a wheelie cart lol... this motor will get all the new plugs and JDM oil cooler.
#133 |
Drives: Subaru BRZ
I've been looking for this build again! Finally its back on the front page!
Definitely sub'd... |
#134 | |
Ya been slacking on the post was busy working on other stuff here is my water pump set up, this pump is for a non turbo Subaru "1990 Subaru Legacy 2.2L NA". There is a couple things special to this water pump which works perfect in my build. The black pipe is coolant heater core pipe single, and the hose adapter is H6 ez30 ![]() little back ground on the design ![]() The EJ257 and EJ255 engines are using a low cost stamped impeller water pump that is inferior to this JDM spec closed back cast impeller water pump. The stamped impeller pump is less efficient and more susceptable to cavitation. We suggest installing a closed-impeller pump on any performance or motorsport Subaru engine build ![]() so besides the cast impeller, the inlet port is huge which should help a bit more with coolant flow. on a turbo water pump there is 3 nipple ports... 1 oil cooler... 2 swirl pot... 3 heater core... now because I'm not using a swirl pot and have a rad cap on the rad I can delete that nipple port & the pipe all together. also my oil cooler has no coolant going into it any more so that port can be deleted also, because of the use of the JDM spec-C S204 adapter.
#135 |
Drives: 2013 Raven Fr-s, 2013 Versa Sedan
you've gone too far sir.
#136 |
#137 |
![]() my new momo prototipo steering wheel, its got that old vintage look ![]() more boost with race fuel and a tune fore some real power.
#138 |
Are you 20/20?
I've said it, and I'll say it again - this build is amazing!!
| The Following User Says Thank You to AznKirby For This Useful Post: | Nico TURBO (03-16-2014) |
#139 |
Drives: 2013 Scion FR-s
It looks great. WOW !!!!!!!!!!
| The Following User Says Thank You to USMC For This Useful Post: | Nico TURBO (03-16-2014) |
#140 |
Drives: ADM Toyota 86 GT
^^+1,000,000
Love it. |
| The Following User Says Thank You to Snake For This Useful Post: | Nico TURBO (03-16-2014) |
| New Rumor: Subaru Developing Turbo 4 2.0T for BRZ | Hachiroku | BRZ First-Gen (2012+) — General Topics | 350 | 02-02-2013 02:52 PM |
| My 1986 Toyota corolla!! | El Diablito | Other Vehicles & General Automotive Discussions | 15 | 07-26-2012 02:34 AM |
| Fr-s with subaru turbo? | Afdad120108 | Engine, Exhaust, Transmission | 46 | 05-19-2012 06:10 AM |
| Assumption: Subaru=Turbo / Scion=NA | ftw-86 | Scion FR-S / Toyota 86 GT86 General Forum | 159 | 06-20-2011 04:28 PM |
