Old 12-13-2021, 04:58 PM   #127
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Quality control issues bleeding over into web content. Could only afford the One Sigma model.
Non linear or classical?
yes I had to look that up
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Ultramaroon (12-13-2021)
Old 12-13-2021, 06:30 PM   #128
FrickingReallySlow
Drives: 2015 FR-S
You're on your 3rd engine now correct after suffering through 2 spun bearings? Did you get a chance to look at the internals and if its always the same #2 or #3 bearing and what the wear patterns were? did you do any UAO?
I put in the killer B, it fits all 2013-2020 86s
Originally Posted by demasrv View Post
The Killer B Motorsport website lists that the oil pickup fitment is for a 2015+ BRZ/FRS. Does anyone know why? I'm in the middle of rebuilding my 2013, purchased this pickup but I'm not sure what the differences would be. I don't remember seeing any major differences around the oil pan when I was looking at buying a newer engine for the 2013 instead of attempting a rebuild. I did reach out to them via their form on the site so I'll report back if/when they respond.
FrickingReallySlow is offline   Reply With Quote
Old 12-13-2021, 07:06 PM   #129
Ultramaroon
not playing cards
Ultramaroon's Avatar
I was too cryptic. Lame Six Sigma reference. Sorry.
NoHaveMSG (12-13-2021)
Old 12-13-2021, 07:22 PM   #130
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Well now I am confused
Old 12-14-2021, 12:52 PM   #131
demasrv
demasrv's Avatar
Drives: 2013 Rally Blue BRZ
I received a response from Killer B:
You are correct about the oil pan. They changed them in 2015 and that is the model pan that our pickup fits. I’m not sure why they changed the pan but the new pan is a little deeper where the pickup tube sits.
Let me know if there is anything else I can help you with,
Nick Ruston
Killer B Motorsports
demasrv is offline   Reply With Quote
The Following 5 Users Say Thank You to demasrv For This Useful Post:
Compelica (12-22-2021), jcw99 (10-20-2022), kevaughan (10-27-2022), NoHaveMSG (12-14-2021), Ultramaroon (12-15-2021)
Old 12-14-2021, 12:55 PM   #132
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I received a response for Killer B:
That is interesting.
Old 12-14-2021, 01:00 PM   #133
demasrv
demasrv's Avatar
Yeah 3rd engine. First one went around 54k and was replaced under warranty. The shop just said one of the bearings went but everything else was fine. This engine I'm rebuilding now went at 78k, with the valve spring recall done at 65k. I think it was #3 that spun this time but I'm not sure which cylinder it was on the first engine. I haven't cracked the block yet but will once I get the wiring harness and everything moved over to the new block.
I know the first time around, the service tech told me my heads and almost everything else in the engine looked flawless. This is what I'm seeing in my current rebuild--heads and everything look really clean. I found one small metal shaving but even the oil pan was really clean.
I don't know what you mean by UAO.
Old 12-14-2021, 01:03 PM   #134
demasrv
demasrv's Avatar
¯\_(ツ)_/¯
Maybe the supersessions represent the change? I don't have a newer one to compare against but in all the pictures they look the same
https://parts.subaru.com/p/Subaru__B...1109AA222.html
Part Number: 11109AA222
Supersession(s): 11109AA220; 11109AA221
Old 12-14-2021, 01:11 PM   #135
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
¯\_(ツ)_/¯
I saw the pan number changed but the pickup is the same.
Old 12-14-2021, 11:08 PM   #136
FrickingReallySlow
Drives: 2015 FR-S
Used oil analysis. Need to do it 3-4 times to establish trends and see the wear metals start to rise. its not definitive (plenty of BMW owners will attest to this) but can give you early warning signs.
interestingly enough UOA actually won't pickup metals shavings you can see with your eye. That's because they are too big and don't atomize and make it into spectrometer. They can only find the microscopic particles that are small enough to get vaporized by plasma
Let us know what you find in your shortblock!
Old 12-15-2021, 03:56 PM   #137
Ultramaroon
not playing cards
I retract my snarky comment with respect to their website content.
Old 12-22-2021, 01:17 AM   #138
demasrv
demasrv's Avatar
Ah yeah I've requested one of their containers before but forgot to send it in. I'll probably do that with this rebuild. Mostly nervous about gasket material ending up in the oil...
Old 01-16-2022, 10:17 PM   #139
chipmunk
Drives: _
This is regarding the pickup tube...
I cross checked the part number for OEM pickup tube, it only fits BRZs 2013-2020. So it's hard to argue that the tube was taken from parts bin. It seems to be specifically designed for this application. Then why would Subaru engineers select that diameter for the tube? And why that bend? I want to install Killer B tube, but there has to be calculated reason why Subaru went with the OEM design. So is it worth switching to Killer B? Instead of any benefits, are there any unforeseen drawbacks to using larger tube,?
chipmunk is offline   Reply With Quote
Old 10-20-2022, 11:44 AM   #140
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Necroed this to show cavitation in this video.
https://youtube.com/shorts/xM6zdim0yk4?feature=share
The Following 3 Users Say Thank You to Irace86.2.0 For This Useful Post:
DarkPira7e (10-20-2022), Wally86 (11-23-2022), x808drifter (10-20-2022)
FA20 Engine Oiling, Bearings, and Starvation Element Tuning Engine, Exhaust, Transmission 784 04-20-2024 04:25 AM
VVT Problems: 100$ reward for a solution!! Exhaust targets all 0, intakes no response bren5279 Forced Induction 12 03-14-2017 07:34 AM
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-04-2016 11:18 PM
An alternate solution to Drone problems 86-tundra Engine, Exhaust, Transmission 1 09-26-2013 02:50 AM
Question about oiling filters showbe Engine, Exhaust, Transmission 7 10-25-2012 09:50 PM
