#127 |
For my winjets I used a tape and tape measure method I found online. It's hard to find a place to do it that people allow use of at night, but I used a high school parking lot that was relatively flat. Even then I found it a little odd. So I had a friend bring my CX-5 GT which comes with factory LED headlights. Marked it's location 30 feet away from the wall and beam pattern relative to the wall using tape, parked the FR-S on the same tape and aimed around 1.5 inches below them. This is a really crude and incorrect method but the tape method didn't give me the road coverage I wanted with a non retrofit hid setup. I have yet to be double flashed by oncoming traffic with these lights and they appear to not blind others as I'm not able to see into the cabins of other vehicles for the most part. For your headlights which have a proper projector and led setup the tape method should work perfectly. You shouldn't have any issues.
#128 |
Drives: Whiteout
Did you guys figure out a fix for the blinking high beams for the FRS?
Instagram: @battleship_86
It's more than a hobby it's a lifestyle. |
#129 |
Drives: FRS
It doesn't bother me, its momentary.
#130 |
Drives: Asphalt FR-S
#131 |
NotVinnyy
Drives: 2013 White Pearl FRS
#133 |
Drives: FRS
I have a 13frs, was pnp for me
| The Following User Says Thank You to Chimera For This Useful Post: | LeonardoDaVinny (11-17-2018) |
#134 |
NotVinnyy
#135 |
How do I shift?
Drives: '13 GBS BRZ
It's pretty easy, just make sure to take bumper out properly trying to not break the clips. After that everything's pretty straight-forward.
| The Following User Says Thank You to carsebuco For This Useful Post: | LeonardoDaVinny (11-18-2018) |
#136 |
Drives: '13 SWP GT86
These work when replacing European GT86 headlights right? My car is a 2013, manufactured in 2012, not sure if newer models have different types of lights (HID, LED etc).
IG @squareddesign
http://www.squareddesign.se |
#137 |
Drives: 2017 Toyota 86
So post 48 also confirms my hyperblink issue in sequential mode, even on my 2017. Why aren't these things advertised as needing a hyperblink module?
#138 |
Drives: Scion Fr-s
I have a set, that I might be willing to sell. If anyone is interested Pm me an offer.
#139 | |
Drives: FRS
That is a fair question. my guess is its prob oversight, most users are prob people who would have already gotten the much cheaper mod/upgrade of LED blinkers and flasher module.
#140 |
I thought the MY 2017+ were LED compatible since my tail lights are LED/sequential and have no trouble. Anyway, I installed the hyperblink module and sequential turn signals on the headlights work correctly now. What a bitch to get at though.
| Spec-D Headlights & Morimoto D2S HID Kit | FyeaFRS | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 03-10-2017 01:19 AM |
| 6K H11 Morimoto HID Kit | Zero90 | Exterior Parts (Aero, Lighting, Etc.) | 2 | 05-20-2014 01:49 PM |
| FS: FRS HID Retrofit Kid (Morimoto) | Khyron686 | Exterior Parts (Aero, Lighting, Etc.) | 2 | 04-21-2014 11:08 PM |
| Stock FR-S Headlights & Tail Lights, Morimoto Elite HIDs, and OEM Mud Guards | tbox | Exterior Parts (Aero, Lighting, Etc.) | 14 | 01-11-2014 03:18 PM |
| Help Morimoto HID kit | Jacob G. | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 02-18-2013 03:03 AM |
