Old 01-19-2018, 06:03 PM   #127
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by dostoyevsky View Post
I had the same question for my 2017 too. So is it bad or not to cruise at 4k?
I dunno if it's bad or not but drive at 4K regularly in the city and on backroads. Now, on the highway I'll cruise in 5th which put me around 3300 RPM if I recall correctly.
I don't use 6th at all...IMHO 4K is the sweet spot for this car.
The Following 2 Users Say Thank You to new2subaru For This Useful Post:
chaoskaze (02-01-2018), spike021 (01-19-2018)
Old 01-19-2018, 06:07 PM   #128
ermax
ermax's Avatar
If you’re in top gear you have no other option. Don’t loose sleep over it.
The Following 2 Users Say Thank You to ermax For This Useful Post:
humfrz (01-19-2018), Ultramaroon (01-19-2018)
Old 01-19-2018, 06:50 PM   #129
humfrz
I thought we covered that ........ a few hundred posts back ........
So, just cruise away at 4,000 rpm.........
humfrz
Old 01-19-2018, 09:11 PM   #130
spike021
spike021's Avatar
6th is totally fine if you're really just cruising nonchalantly, IMO. RPM isn't gonna matter at that point.
But yeah 5th is usually what I stick in except for long highway trips with variable traffic.
spike021 is offline   Reply With Quote
Old 01-19-2018, 09:36 PM   #131
new2subaru
Weight Weenie
Drives: 15 FR-S
Hey Spike,
I agree but I prefer to be able to hear the engine and experience some NVH, even if it's just a bit. I feel like I'm lugging it in 6th...I'll probably change out the FD at some point.
EDIT: It's also nice to be able to just touch the gas pedal and get an instant response
Old 01-19-2018, 09:59 PM   #132
spike021
spike021's Avatar
Hey Spike,
Yeah if you’re lugging then sixth isn’t right. For me generally I’ll be in sixth at 60 and above (or 5th). 6th gear at any speed lower than about 60 basically has the engine lugging.
The Following User Says Thank You to spike021 For This Useful Post:
new2subaru (01-19-2018)
Old 01-19-2018, 10:05 PM   #133
new2subaru
Weight Weenie
Drives: 15 FR-S
Quoting isn't working Spike.
I said it feels like I'm lugging it. Forgot to add (Compared to the way I normally drive it)
You got it, around 60 in 6th feels like the engine is lugging
The Following User Says Thank You to new2subaru For This Useful Post:
Old 02-01-2018, 11:53 AM   #134
itsAlex
itsAlex's Avatar
Drives: 2016 4Runner / 2016 FR-S
I've made plenty of four-hour round trips in my FR-S doing about 3500rpm in sixth gear. The car will handle it no problem, it's within the design specs anyway. The only downside to cruising at that rpm is the decrease in fuel economy. It makes more sense to decrease your speed a bit and cruise at a lower rpm than to rev it up higher just for a bit more speed. You'll be fighting more air resistance and it'll take more fuel to maintain your speed at those higher speeds.
It matters to me as I make these round trips often so the fuel costs add up. To some it doesn't matter, but to answer the original question again, yes the car will be fine cruising at 4000rpm.
I pay more per month for insurance than I pay for the FRS.
itsAlex is offline   Reply With Quote
The Following User Says Thank You to itsAlex For This Useful Post:
StraightOuttaCanadaEh (02-01-2018)
Old 02-01-2018, 10:16 PM   #135
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
I used to drive around @ the deepth of torque dip @ 3.5k rpm.... cuz it can only get better when you are not tuned. LOL
The Following 2 Users Say Thank You to chaoskaze For This Useful Post:
bcj (02-01-2018), StraightOuttaCanadaEh (02-01-2018)
Old 02-03-2018, 12:40 AM   #136
Audio
Drives: 16 FR-S Raven
Is it harsh on the engine? My fiance's Mini is at 1800 rpm, plowing along, meanwhile mine is roaring at 4K rpm at the same speed. Is it safe for prolonged periods? Should I limit my engine speed and slow down? Really dislike this part about the MY17 final drive. Sometimes it really feels like a car better left to the track, not too perfect for daily driving. At green lights, I get left so far behind by normal econoboxes with their CVTs. To keep up I have to shift fast and rev and make all kinds of racket, meanwhile they just whoosh away. Anyway I'm ranting, back to my original question... so is it safe?
Just relax, turn up your music
Sent from my Pixel XL using Tapatalk
Audio is offline   Reply With Quote
The Following 2 Users Say Thank You to Audio For This Useful Post:
StraightOuttaCanadaEh (02-03-2018), Tcoat (02-03-2018)
Old 02-03-2018, 12:56 AM   #137
Decep
Drives: 2013 FR-S Series 10
You're definitely not lugging in 6th at 60. You can be cruising at 45 in 6th (right around 2000 RPM) and not be lugging.
Now, if you floor it at 45mph in 6th, you'd be lugging.
Cruising requires very little horsepower.
The Following 3 Users Say Thank You to Decep For This Useful Post:
ermax (02-03-2018), StraightOuttaCanadaEh (02-03-2018), Tcoat (02-03-2018)
Old 02-03-2018, 07:18 AM   #138
new2subaru
Weight Weenie
Drives: 15 FR-S
Yes, I'm aware of that but I said feels. The car just feels better running at a higher RPM IMHO. Same as when I drive at a higher RPM in the city. The throttle response is instantaneous.
Old 02-03-2018, 01:13 PM   #139
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I agree. The car just seems happier in high revs. It's a high strung engine that makes all its power up top so it makes sense. If I am around 2000 RPM the car is sluggish and doesn't sound very good. My LTFT tends to be worse in the 2-3k RPM range too.
The Following User Says Thank You to guybo For This Useful Post:
new2subaru (02-03-2018)
Old 02-03-2018, 01:24 PM   #140
Decep
That's fine, you're just wasting gas. Cruising implies a constant velocity no? If im getting up to speed and people are going too slow i'll stay in 4th or 5th for a while sometimes.
That's the beauty and fun of a manual transmission
The Following User Says Thank You to Decep For This Useful Post:
ermax (02-03-2018)
Opti - coat 2.0 (pro) vs waxing regularly radroach Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 34 01-19-2018 09:39 PM
Who else regularly checks BaT? NWFRS Other Vehicles & General Automotive Discussions 8 08-16-2014 12:02 AM
High rpm cruising in 6th abutterman Issues | Warranty | Recalls / TSB 12 03-22-2013 07:38 AM
Fr-S w/ Evo X cruising in SoCal NGabriel89 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 09-12-2012 06:19 PM
JRP FR-S/BRZ build up (regularly updated) Stav CANADA 5 07-14-2012 04:21 PM
