#127 | |
Delights in pure handling
Drives: Zoom Zoom
Now regarding the Mustang V6 vs. V8. I'm not a Mustang guy at all and never considered one. Not sure if there is more difference between the two than the engine? (I assume suspension, transmission, brakes...etc. would be different and upgraded on the V8 version?). Really depends what I wanted to use it for. I'm sure with the $10k difference between the V6 and V8 you could easily get ~450-500hp with either a turbo/sc and still have some money left over to do other mods to the V6. If you just wanted to buy the car and leave it as that, probably the V8 makes more sense. Just don't see why an enthusiast might not consider the V6. Hell you have people buying Civics, tC, Celica's...etc. and modding them instead of buying an STi or M3 with the total amount of money they paid for the car + parts. Different horses for different courses. |
#128 | |
Kuruma Otaku
With the Civics you'll see a swapped Civic or Si(R, depending on year) driven by an enthusiast but very rarely base motors. Riced out ones yes, but rarely a well done mod'd standard Civic. And it's not like the swapped Civics are done as soon as they got home from the dealer. Celica's probably the same between the GT and GT-S but they are less common at the track (7th gens). The base cars are typically the show-before go crowd (if they're modded), or just an ordinary commuter. I think my request for a stock 148 hp FB20 puts me in the 'would buy a V6 over a V8 if I were a Mustang guy'. But most people here would be 'WTF?' If I do get my wish of a cheap FB20, it will also be with the knowledge that after some immediate handling mods with the $ saved, in a few years the motor will get yanked for a more powerful one. But I think I would be in the vast minority of the enthusiasts with my choice.
Because titanium. |
#129 | |
Drives: Zoom Zoom
No I hear you. I just think there are some enthusiasts that buy a 4 cylinder or 6 cylinder instead of the 8 cylinder to be different and see what they can do with that setup. I don't have a problem with that. Just like you would rather have a lower hp engine but lighter and cheaper car since you will eventually do you own mods at a later point. That is why I say some enthusiasts might want the lower engine option since they will do their own swap/engine build anyways. So I think that is a valid option. Others just want a bone stock car and not have to worry about it and just drive it and enjoy it. So I think both are valid. Just like some on here want a 200hp NA engine and others want a 270-300hp turbo version. Each one is valid, just people have different preferences. |
#130 | |
9 out of 10 MS3 I have come across have blown up the moment they start getting up past the 280 mark. Its a ticking time bomb at 300+. Only a noob who hasn't raced or been involved in any real racing would only look at cars and only form an opinion based only on their HP numbers. Driver skill is significantly more important than the car. Last edited by Dragonitti; 05-01-2011 at 07:45 PM. |
#131 |
Drives: Zoom Zoom
Just one example of a V6 turbo Stang. I wouldn't drive a Stang personally but understand why some might go with the V6 then turbo it. Basically you get GT500 power numbers for the price of a GT with a turbo V6.
[u2b]0HWYq-WAGPU[/u2b] 434whp, 516wtq But for many it is more than just hp numbers and some just want the V8 to say they have the V8 or they always wanted the 8 version. |
#132 |
You guys Need to be specific. If you say 2011 tC with $3k in it beating a 2011 V6 Stang then its a different approach to mods. Can't get a turbo setup for that cheap on a 2011 cause they just came out. But if you talking older Gen tC with $3k in it, I could toss a turbo setup into, Coilovers, and tires onto the stock wheels and destroy every car on that list on or off the track.
And yes I am dead serious about the MS3. Go to the MS3 forums and research. I went there a while back to gain some knowledge on them. I kept running into guys turning up the boost and tuning for 300whp only to be met with a blown motor. Its their fueling setup that's a weak link in them. They have to add a fuel pump setup just to make 280whp. My boy was pushing 280whp on his MS3 when I raced him. A little while later he told me he had to replace the motor. Had an upgraded pump, tuned, etc. Another friend of mine...same story. Last edited by Dragonitti; 05-01-2011 at 07:31 PM. |
#133 | |
Kuruma Otaku
That's partly my concern about only hearing about the regular FB20, and no confirmation on what the FT86 will have, or how different its version of the motor will be. 200 hp @ 7000 rpm from the 90 mm stroke FB20 would be close its max without replacing internals. With the long stroke, that rpm may even be pushing it. Adding boost to that wouldn't make me comfortable at all.
Because titanium. |
#134 | |
Drives: Zoom Zoom
It is only fair to compare new vs. new. But if we are taking used cars might as well throw in a used E36 M3 into the mix. Buy one used, throw in a turbo kit and be done with it. Same thing with a MkIII Supra. Buy used rebuild the engine and throw in a bigger turbo. Last edited by tranzformer; 05-01-2011 at 07:47 PM. |
#135 | |
GL 86!
Drives: Maybe FR-S... maybe not
Canadian MSRP (rounded and on the base model, no options) of the following 2 door RWD cars with a manual transmission (except Challenger V6): Challenger SRT8 V8: $50K 135i: $43K Camaro SS V8: $42K RX-8 R3: $42K 370Z base V6: $41K Mustang GT 5.0: $39K Challenger R/T V8: $38K 128i: $36K _____________________ Genesis Coupe V6: $33K MX-5 GS 6-speed: $33K MX-5 GX 5-speed: $29K Challenger V6: $27K Camaro V6: $26 Genesis Coupe 2.0T: $25K Mustang V6: $23K My guess is that the FR-S will be under $35K base starting for the Canadian market, how far is unknown. IMO the line represents going from one class to another, but it depends on how picky you are in comparing and how much money you have to spend. |
#136 |
Drives: Zoom Zoom
#137 | |
Kuruma Otaku
At $24k it could take Joe Average and Suzie secretary out of V6 Mustangs with its looks, reliability, economy, ease of parking, etc... All the boring stuff (discounting looks). Also if they're emphasizing the 'MPGs' (to save money, right?) in the press release stuff, making it much more expensive than the next Scion doesn't make any sense. Why spend a bunch more money than a tC to get slightly better economy?
Because titanium. |
#138 |
Drives: Zoom Zoom
Well said. Unless of course Toyota has overestimated the success of selling this car as a Scion rather than Toyota in Canada/USA. But I'm sure Scion has put Toyota to ease by telling them how successful this car will be under Scion. Unless someone cares about RWD, lightweight, boxer engine...etc. I'm not sure the average Joe or Suzie Secretary will care about those differences and could very well go with the cheaper tC. However I am assuming the FR-S will look >>>>> than the tC so you might earn a few sales that way. But in general I think most people (average person) in this economy will pick the cheaper option out of two equally specd/designed cars. Only us enthusiasts will care about those small differences.
#139 | |
If you comparing new to new, for $3k into a 2011 tC I know what mods it would take to beat a stock 2011 v6 Stang on and off the track. |
#140 | |
Can you read? I said if you were to buy it NEW $3-5k TOTAL for the turbo setup. If you were to get a used setup then $1500-2000 for a well conditioned one, leaving money left over for a set of coilovers and tires. Hell I might even be able to squeeze an LSD into the trans. That would wipe a mud hole in those cars listed. I don't speak from theory, I speak from experience. And yes "CHEIF" I install my own shit. If I were to just street tune it, it still would be good enough to walk those cars. If I were to do a pro tune it would be around $500 for a tune. And the other part you missed is that I owned a 350z as well. I know what it cost to mod them. You have to remove the motor to drop a set of Twin snails in it. That kinda put a bad taste in my mouth on boosting my Z as I didn't want a single. On the tC, shit is right there up front. And after racing my tC at just 8lbs of boost on a small ass 16G turbo against my 350z and watching the tC put bus lengths on it, it put an even bigger taste in my mouth and I soon understood that the Z is just to heavy. My Z had Stg. 2 Clutch/light flywheel, APS test pipes, Tein-Stechs, K&N drop in filter and some different tires as I was using it for drifting. I stuck to drifting with that car as I didn't feel it was fast enough without a crap load of money into it anywhere else. I did beat a couple SRT-4's with it (one Stg 2 SRT-4). 9 out of 10 MS3's I came across were painfully blown up at the 300whp mark. Couple that with two personal people I know who ran into the same issue, and you think I'm being over critical. Right. I know quite a few 400+whp tC's too, but I'm not a dummy and think it can live a long life at 400whp. MS3 don't live that long in the 300+ range unless you granny driving it to the grocery store and that's it. Saying I dynoed at 500whp on a stock motor, but I never really race = GARBAGE. I'm talking full out reliability at that whp in a racing environment, not Daily Driving it. If you want me to provide proof rather than just talking, I could do that also. No biggie. |
| Tags |
| fanboi, lame |
| Nissan 370Z thread | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 116 | 04-07-2017 11:40 PM |
| FT 86 & 370Z similarities | blur | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 11 | 10-05-2010 01:39 AM |
