#127 |
Drives: 2014 FRS LS Swap
Once i finish fitting everything i will send to swaintech to coat everything to cut down on heat. Look at the hoonicorn piping. They use swaintech there and it works awesome. http://swaintech.com/race-coatings/r...aust-coatings/
Sent from my SM-G950F using Tapatalk |
#128 |
Drives: '13 Scion FR-S & '17 Toyota 86
LOVING the build so far!
#129 |
Already have a full blown radiator and upgraded fans. Heat should not be an issue with everything coated. Engine never got above 196 under repeated hard runs previously. Need to find vents for the hood now. Think this would make the biggest difference.
Also found an ls3 waterpump and spacers to move the outlet to the drivers side on ebay for 51.00. Pulled off a crate engine. Cant go wrong there! Sent from my SM-G950F using Tapatalk |
#130 |
Drives: WRB 14 BRZ
Thanks for keeping us updated on this thread. Definitely some valuable info in here. My favorite article I read on the 4.8 was a HotRod article I believe. They had what they thought was a 5.3 that they swapped cam heads and used forced induction. Made crazy power and they tore it down to realize it was 4.8 lol.
#131 | |
#132 |
Cut out a hole in the hood for the 2nd turbo. Going to make a rounded section to cover it.
![]() ![]() Sent from my SM-G950F using Tapatalk |
#133 |
Mocking up intercooler piping. Intercooler will be here monday then i can mount it. Hood is being welded right now. Switched to all ls3 accessories. Waiting on balancer. Got the manual belt tensioner in and cut the alternator mount down by 3/4 of an inch. This way i don't have to use waterpump spacers and everything lines up with the corvette belt line. Also if i ever get another engine (looking at the cost of an ls3 block with 4.8 crank for 8k rpm) the accessories are ready to go. Ground the block slightly and everything lines up.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G950F using Tapatalk |
| The Following 2 Users Say Thank You to kurty85 For This Useful Post: | alex87f (01-12-2019), eastendraceshop (01-14-2019) |
#134 |
Drives: 2015 frs
Looking good.
#135 |
Got the intercooler and piping in. Need to weld one pipe to the throttle body piping and put the clamps on. Next i need to put the new balancer on, belt, and remove all piping to make beaded ends on. All the hot parts of the turbo system need to go to swaintech after the downpipes are done too.
![]() ![]() ![]() ![]() ![]() Sent from my SM-G950F using Tapatalk Last edited by kurty85; 01-14-2019 at 03:40 AM. |
| The Following 3 Users Say Thank You to kurty85 For This Useful Post: |
#136 |
Drives: 2017 WR BLUE BRZ
Looks pretty cool!
#137 |
Drives: 14 BSP Edelbrock BRZ
Isn't that intercooler way undersized for a pair of turbos feeding a V8? My STI had half the horsepower you're going to end up with and my intercooler was bigger than that.
#138 |
The Gunshine State
Drives: '14 BRZ Limited
How thick was your core? That has a lot more to do with cooling efficiency than just length and width.
![]() Current DD: M235i |
#139 |
#140 |
The intercooler is 3.5" thick. Rated at 968hp
| The Following 4 Users Say Thank You to kurty85 For This Useful Post: |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 11:54 PM |
| Not just another ls swap | killin'_for_a_livin' | Member's Car Journals | 7 | 08-28-2016 05:58 PM |
| WRX SWAP!!! | PowderfaceTr. | BRZ Photos, Videos, Wallpapers, Gallery Forum | 1 | 02-24-2015 07:29 PM |
| Ej Swap | koyv90 | Engine Swaps | 50 | 11-14-2013 08:59 PM |
| Should I swap? | michaelahess | BRZ First-Gen (2012+) — General Topics | 8 | 06-12-2012 08:32 PM |
