05-17-2022, 03:30 PM | #127 | |
I'm enjoying the door not slamming on me as I gather up my water bottle, running bag and other random stuff when getting to the office but it is strange not being able to close the door by simply looking at it. That was kind of a cool feature. hahaha |
The Following 2 Users Say Thank You to ermax For This Useful Post: | Tcoat (05-17-2022), Ultramaroon (05-18-2022) |
05-18-2022, 12:35 PM | #128 |
Drives: 2015 FR-S
I also installed the 2022 brz door checker since it was only $24 from Subaru and cheaper than the 2017+ version. Here’s the picture side by side. If I could go back I’d get just the 2017+ version. Reason being that it has a longer flat section and earlier in the travel which lets the door stay open at smaller angles (when someone parks really close to you) with the 2022 version the door only stay open in the deeper groove sections (but will definitely stay there) so the door has to open a lot before it can stay open. Not sure if this makes sense.
So it still comes right back at your shins if you just open the door just slightly. I can't believe I'm writing a review for door checkers |
05-18-2022, 02:33 PM | #129 | |
Also why I felt remorse for not noticing it didn't do it with the new parts so I could pass it on two years ago.
The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (06-02-2022) |
05-18-2022, 06:23 PM | #130 | |
Yeah I’ve noticed the same thing. It opens a little, a little more and then a lot. I’m in Florida so the first notch seems to hold just fine. I took some pictures of the door at the three stages. |
05-18-2022, 06:54 PM | #131 |
chicken tonight
The Following User Says Thank You to Ultramaroon For This Useful Post: | ermax (05-18-2022) |
05-18-2022, 06:59 PM | #132 |
The Following User Says Thank You to Tcoat For This Useful Post: | Jdmjunkie (05-18-2022) |
05-18-2022, 07:48 PM | #133 |
chicken tonight
05-19-2022, 09:12 AM | #134 |
Meow
Drives: GT86, Volvo 996
Can anyone post the part numbers for the 2017 & 2022 versions?
05-19-2022, 10:38 AM | #135 | |
Guilt free parts vulture!
Drives: 2013 FR-S - Asphalt 6MT
2017 part number is 61124CA001, online for about $33
2022 part number is 61124CC000, online for about $24
The Following User Says Thank You to nextcar For This Useful Post: | blsfrs (05-20-2022) |
05-19-2022, 11:40 AM | #136 |
Drives: FR-S,GTI
It's great that Toyobaru recognized the problem and solved it. And thirty three bucks is well worth it to fix the only real problem with 86 (besides the TOB of course).
But I think the improved part should be free. Even though I'm ordering mine today. The original fix on mine is less effective after 200,000 miles. |
05-19-2022, 02:26 PM | #137 | |
Fact: according to the parts interchange catalog I looked at, the same door stay is used on the front door of ALL modern Subaru vehicles.
Assertion: Owning a Outback too (although a 2019 with the new door stay) I cannot imagine what it must have been like for the earlier Subarus with doors even heavier than the twins... This improvement was doubtless to address the problem on their mainstay vehicles, and was just an unexpected bonus for the twins.
The Following User Says Thank You to nextcar For This Useful Post: | Ultramaroon (05-19-2022) |
05-20-2022, 02:39 AM | #138 | |
I think the real issue is they took the check from a sedan and threw it on a coupe with significantly longer doors. Even if the BRZ door is lighter, the mechanical advantage will over work a check designed for a short door. The Twins are a mix of parts from Subaru and Toyota and the checks should have come from Toyota who have several coupes to pull from. |
The Following User Says Thank You to ermax For This Useful Post: | Tcoat (05-20-2022) |
05-20-2022, 07:06 AM | #139 | |
Not the first time I have run into this issue with a coupe where they just tried to parts bin a door check. In this case it obviously didn't work well even on the sedans and SUVs so the issue would be magnified on the Twins.
05-20-2022, 12:20 PM | #140 |
chicken tonight
Better check yourself before you wreck yourself
Similar Threads | ||||
Door Open Switch | Raz | BRZ First-Gen (2012+) -- General Topics | 7 | 04-10-2022 05:07 PM |
Door open light | rosol16 | Issues | Warranty | Recalls / TSB | 6 | 11-22-2015 12:42 PM |
Door wont stay open | cregor | Issues | Warranty | Recalls / TSB | 21 | 06-11-2013 11:43 PM |
Door Open Buzzer | cmspooner | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 08-13-2012 10:20 AM |
