Old 06-12-2013, 07:22 PM   #43
jacobzking
Drives: White FRS
The GM at my local Toyota dealer told me personally that my unit will be in stock tomorrow (and so will his). He keeps his own FRS at the dealer, so tomorrow when they come in his tech will look at it. I should have a solid confirmation of plug n play/features, etc, tomorrow or Friday at latest.
jacobzking is offline   Reply With Quote
Old 06-12-2013, 07:26 PM   #44
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
Originally Posted by Re~Mix View Post
Called the dealer again and convinced them to speak with Toyota HQ. They said Toyota doesn't have any notes on the install at the moment, meaning they can't confirm weather its a plug-n-play drop in replacement.
Waiting to hear back from you guys before pushing an order through.
MotoP already confirmed that it's plug-n-play.. unless you're looking for a 2nd confirmation.
azian_advanced is offline   Reply With Quote
The Following User Says Thank You to azian_advanced For This Useful Post:
Re~Mix (06-12-2013)
Old 06-12-2013, 07:56 PM   #45
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
This is what I wanted to hear! I think the dealer is worried that they will have to physically mess around with the dash to get the unit to fit.
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport
13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook |
Re~Mix is offline   Reply With Quote
Old 06-12-2013, 08:20 PM   #46
Calavera
Calavera's Avatar
Drives: Scion FR-S Whiteout
The part number for the unit with gps is pt296-00140.
Calavera is offline   Reply With Quote
The Following User Says Thank You to Calavera For This Useful Post:
azian_advanced (06-12-2013)
Old 06-12-2013, 09:06 PM   #47
jacobzking
Drives: White FRS
Where did you come up with that?
Old 06-12-2013, 09:17 PM   #48
Calavera
Calavera's Avatar
From the manual
http://a230.g.akamai.net/7/230/83646...ers_Manual.pdf
The Following 2 Users Say Thank You to Calavera For This Useful Post:
azian_advanced (06-12-2013), Bristecom (06-15-2013)
Old 06-12-2013, 11:03 PM   #49
azian_advanced
*****istrator
That's understandable since they probably knew the slot for the headunit isn't double-DIN and wasn't sure if the stereo was double-DIN or not.
On the other hand, for those looking at getting an aftermarket double-DIN headunit instead, you can get these spacers from Subaru (link) to fill in the gaps on the sides.
Enraged21 (06-13-2013)
Old 06-12-2013, 11:24 PM   #50
Mandy
I came from a motorbike
Mandy's Avatar
Drives: Firestorm 2013 FR-S 6MT
Don't get me wrong, I'm ready to throw another $600 on top of the worthless BeSpoke unit I already paid for, but I'm left with the question of:
Will my old BeSpoke receive an update?
I'd hate to wind up with two stereos despite the fact that the old one does look a bit tacky.
Mandy is offline   Reply With Quote
Old 06-13-2013, 08:54 AM   #51
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
Would like to know the same thing. Current bespoke needs an update.
Wish it was android compatible too :/
Enraged21 is offline   Reply With Quote
Old 06-13-2013, 10:48 AM   #52
HooverFish
HooverFish's Avatar
Drives: 2013 FR-S Ultramarine Automatic
Considering to use that pile of crap they supply you with ONLY a connector for a last gen iphone, they would suddenly have to do a lot of changing around and not to mention i'm sure the hardware is probably wildly different.
And yes, I know with the new app that Android actually connects and is used through bluetooth (which is hilarious they couldn't do that to BEGIN WITH) but that new app, again, probably has chips inside the new head unit that it needs to be compatible which means old units are screwed.
Oh, and do you really think any car company would willingly upgrade what they consider a "last gen" device when they can have you pay an exorbitant amount of money to upgrade?
HooverFish is offline   Reply With Quote
Old 06-13-2013, 12:13 PM   #53
Re~Mix
Re~Mix's Avatar
As a semi-redundant question. Are those people ordering this unit having the dealer install it, or assembling it themselves?
15' 228i MSport
Old 06-13-2013, 01:59 PM   #54
jacobzking
Drives: White FRS
i'd install it myself. pop off passanger panel (just 6 clips, grab and tug. remove head unit surround, again gran and tug. remove 4 easy to access screws. pull out old head unit. remove harnesses. reverse to reinstall. 5-10 minute procedure.
Old 06-13-2013, 03:03 PM   #55
mdf4uk
Drives: 13 Firestorm FRS MT & 09 DGM WRX
Correct me if i am wrong but i do not think this new radio has the pre-outs for subwoofer
mdf4uk is offline   Reply With Quote
Old 06-13-2013, 03:57 PM   #56
Re~Mix
Re~Mix's Avatar
Has anyone actually verified that this new 2014 headunit is dimensionally equivalent and will bolt in appropriately? The pictures from Moto-P look like the case, however I have yet to see an install performed on a 2013 MY.
To be clear, I am looking to upgrade from the base 2013 unit (not bespoke).
*EDIT*
Looks like this thread provided my answer, YES. http://www.ft86club.com/forums/showthread.php?t=39071
15' 228i MSport
Oil plug part number? dem00n Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 03-03-2013 10:15 AM
Headunit bracket frame, part number bebopblues Cosmetic Modification (Interior/Exterior/Lighting) 2 01-22-2013 01:20 AM
need a part number the Red Devil Scion FR-S / Toyota 86 GT86 General Forum 0 12-12-2012 12:42 PM
I need a part number Bones36 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-01-2012 05:25 PM
Part Number for this DriftEightSix AUSTRALIA 20 06-25-2012 08:30 PM
