Old 06-12-2013, 05:17 PM   #1
Rev Works
Rev Works's Avatar
Drives: 2013 STi
Part 1 of our FR-S / BRZ Turbo Kit Sneak Peek
We're very excited to start posting a few sneak peeks at our new FR-S / BRZ Turbo Kit. This is PART 1 of the release of this kit. Click here to read the basics and get some sneak peek looks at our design.
It all starts with turbo selection:
It was our goal to find a turbocharger that would provide the most usable power band and torque possible with this Boxer 2.0L. We were on the hunt for a turbo that would be responsive, offer superior transient response and still be able to produce horsepower on pump gas. We decided on a GTX Turbocharger from Garrett and have opted for Tial's V-Band turbine housing. We'll have more details on the exact turbocharger and specs in Part II.
Turbo Kit layout and space optimization:
We wanted to make this a kit that would make daily driving a blast. The whole kit was designed around the idea of maximizing torque and response. Routing got a bit tricky as we went and found that the chassis didn't want to play along with some of our ideas but we were able to squeeze in all of the components without any conflicts or unwanted points of contact. It is a tight squeeze but the design provides for better cooling and ideal performance.
Building the Manifold, Down Pipe and Dump Tube:
There are a few obstacles with building the FR-S/BRZ Turbo Kit. With attention focused on potential hot spots, points of contact and more, we had to make sure to clear the oil pan, not be too close to the crank pulley or any other heat sensitive spots on the motor. Our AMERICAN STAINLESS STEEL tubing is paired with our 1/2" flanges to offer superior quality and kit durability. We were able to construct a true 3" V Band down pipe to optimize flow at the turbine and with this build, we recirculated the wastegate dump tube. Product kits will be available with the option to dump or recirculate.
The Intercooler and Charge Piping:
Our team worked together to optimize the charge system. We wanted to keep it as short as possible and use lite weight aluminum. We were able to achieve what we feel is the shortest path possible and kept it very lite. The final weight numbers of the kit will be in PART 2. We converted the MAF to a blow through style to optimize the MAF's ability to meter the charged air.
Current Status of the Build:
We've got hardware, piping and all in place. We're wrapping up a few loose ends and finishing up on the oiling system. We've very close to firing her up and getting going on kit #2! We're very happy with how the kit is looking so far and cannot thank the customer, James Martin enough for allowing us the opportunity to build such a great project together.
Be sure to keep up with the build on our Facebook Page.
[ame="https://www.youtube.com/watch?v=O9h20-ZQ6js"]Rev Works FR-S/BRZ Turbo kit - GTX2867 12psi - YouTube[/ame]
Rev Works is offline   Reply With Quote
Old 06-12-2013, 05:24 PM   #2
Rev Works
Rev Works's Avatar
Drives: 2013 STi
Reserved for updates.
Old 06-12-2013, 05:27 PM   #3
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Looking good. Can't wait to SeE the results
One thing.
Though you've chosen to make the routings a small as possible isn't this going to prevent people upgrading down the track?
I.e adding aarger radiator and such.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 06-12-2013, 05:27 PM   #4
velin86
velin86's Avatar
Drives: 2013 Raven FRS 6MT
oh great another thing to make my FI decision harder lol. looks good!
velin86 is offline   Reply With Quote
Old 06-12-2013, 05:45 PM   #5
Rev Works
Rev Works's Avatar
Drives: 2013 STi
One thing.
This is a very purpose built kit. This isn't designed for anyone looking for crazy power. We set out to build a solid, quick spooling, responsive kit. We already have another one lined up that will probably go a bit bigger. We'll address each of the limitations, if any as we go.
We're here to help.
Old 06-12-2013, 05:59 PM   #6
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Looking good
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 06-12-2013, 09:47 PM   #7
Shit Luck
Drives: red frs
is there a reason nobody is going into the top of the intercooler and out the top of intercooler?
the shortest routing looks like it would be under the rad support with both intercooler pipes.
Shit Luck is offline   Reply With Quote
Old 06-12-2013, 10:17 PM   #8
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Very clean.
mines13 is offline   Reply With Quote
Old 06-12-2013, 11:04 PM   #9
DriftEightSix
Pegasus White
Drives: 86
We're here to help.
Sounds good to me cause im after a quick spooling system but i'd still like to get to 300rwhp.
What do you think the max of the kit will be?
Old 06-13-2013, 10:50 AM   #10
Rev Works
Rev Works's Avatar
Drives: 2013 STi
I've made 420whp out of a similar turbo a few years back on a different application so the power potential is there. We've yet to have a single person interested in boost ask for anything over 400whp so I think this will be a very solid performer in the mid 300whp range at a low to moderate boost level.
Old 06-13-2013, 11:03 AM   #11
rupert
Audio & Bacon Junkie
rupert's Avatar
Drives: 2013 WRB BRZ Ltd
Are there any chances of a UEL setup? The current picture looks to be EL.
rupert is offline   Reply With Quote
Old 06-13-2013, 11:08 AM   #12
Rev Works
Rev Works's Avatar
Drives: 2013 STi
I don't have one in the immediate plans but you're in JAX, a simple drive down and some custom work could make all kinds of dreams come true, my friend.
Old 06-13-2013, 11:23 AM   #13
carlitosway6891
Drives: white out project fr-s
i was just there not too long ago buying exhaust manifold flanges for my FRS ( which i must say look top quality!), got there right before you guys were closing, wish i could have seen the build!! ill have to swing by one of these days =)
carlitosway6891 is offline   Reply With Quote
Old 06-13-2013, 11:26 AM   #14
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I can't tell from the picture. Which GTX turbo is that? I agree that the intercooler should be modified so that the turbo outlet goes into the top of it to minimize tube length. Kit looks damn good though. I like that you showed it with a recirculated dump as well.
Sprintex Supercharger Sneak Peak!!! invisage Forced Induction 52 03-03-2013 06:11 AM
A Sneaky Sneak Peak? White64Goat Other Vehicles & General Automotive Discussions 2 02-20-2013 04:03 PM
Sneak Peak Video of Crawfords Turbo BRZ WingsofWar Forced Induction 48 10-18-2012 10:14 PM
Invidia N1 - Sneak Peak **FT-86 SpeedFactory** FT-86 SpeedFactory Engine, Exhaust, Transmission 54 10-02-2012 10:48 PM
Sneak peak at first Aussie turbo kit MZ21 AUSTRALIA 133 09-22-2012 03:45 AM
