Old 06-10-2013, 01:06 PM   #1
FRS8SIX
Drives: 2013 hot lava FR-S
Wheel Directory: Work Emotion XD9 18x10.0 +38
Recently picked up a new set of wheels.
Work emotion XD9
18x10 +38 front and rear.
235/40/18 nitto neogens
Test fit
Thanks for viewing
FRS8SIX is offline   Reply With Quote
The Following 24 Users Say Thank You to FRS8SIX For This Useful Post:
619_FRS (06-19-2013), Baldoak (06-11-2015), Beyer Subaru (07-10-2013), BlaineWasHere (06-10-2013), boucher (06-10-2013), camelflage (06-10-2013), chris x sway (05-22-2014), diss7 (08-31-2013), Freshfrs86 (11-21-2013), HATED1 (06-11-2013), hmong337 (02-26-2014), humanshield (06-12-2013), Jay2420 (07-15-2015), Kakawate (11-27-2014), Manji (01-24-2015), mit_peid (06-10-2013), P86RAVES (03-12-2015), punchdrunkjuice (06-22-2013), Redlinedfrs86 (06-11-2013), switchlanez (06-12-2013), travelmonkey (06-21-2013), TylerLieberman (06-11-2013), vividracing (06-21-2013), Zaku (08-21-2014)
Old 06-10-2013, 08:49 PM   #2
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
i like the last two shots. but still i would put a meatier tire size in the back. at least 255
DuMa is offline   Reply With Quote
The Following User Says Thank You to DuMa For This Useful Post:
Old 06-10-2013, 09:23 PM   #3
boucher
Leaux Down Krewe
boucher's Avatar
Drives: 2014 SSM Limited
Very well done! What offsets are you running?
boucher is offline   Reply With Quote
Old 06-10-2013, 09:24 PM   #4
TTGT
TTGT's Avatar
Drives: 2013 Whiteout FRS
Offset?
TTGT is offline   Reply With Quote
Old 06-10-2013, 10:05 PM   #5
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
too many holes
Old 06-10-2013, 10:26 PM   #6
PANDA86
Old School Status
Drives: .
e.t./camber/drop specs.
PANDA86 is offline   Reply With Quote
Old 06-10-2013, 10:35 PM   #7
dabocx
dabocx's Avatar
Drives: Scion FRS
Offset should be +38
dabocx is offline   Reply With Quote
Old 06-11-2013, 07:57 AM   #8
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
I think he chose 235 so it would fit using the specs he has.
With a wider tire he would need more camber or fenderwork to keep it flush
dori. is offline   Reply With Quote
Old 06-11-2013, 02:17 PM   #9
Superman
Drives: Whiteout Scion FR-S 6MT/GSX-R 1000
I think I saw this setup at Wekfest LA...the color combination is perfect. I am surprised that an 18x10 wheel would fit on the front as well as it does...and stick out so much in the rear, but it looks good.
Superman is offline   Reply With Quote
Old 06-11-2013, 03:53 PM   #10
FRS8SIX
Thanks! Yeah they are +38's all around. And chose 235's because nitto didn't have the 245's I wanted.
Old 06-11-2013, 07:26 PM   #11
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
any rubbing in the front?
how much camber front and rear?
Old 06-11-2013, 07:56 PM   #12
ozne99
Drives: GBS BRZ Limited
Jesus, I did not expect that to fit as well as it does. Nice.
ozne99 is offline   Reply With Quote
Old 06-11-2013, 08:44 PM   #13
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
nice!
Jesse is offline   Reply With Quote
Old 06-12-2013, 12:52 AM   #14
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Oh me too! Back in jan.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following 3 Users Say Thank You to OmarGC For This Useful Post:
ozne99 (06-12-2013), PradiG (06-12-2013), switchlanez (06-12-2013)
Wheel Directory: Work Meister S1R 18x10.0 +12 / 18x10.5 +17 larryw Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 01-16-2014 01:29 AM
Wheel Directory: Work Emotion CR Kai 18x7.5 +48 TexMex Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 01-03-2014 08:44 PM
Wheel Directory: Work VS-XX 18x9.0 +33 / 18x10.0 +33 brunofrs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 11-08-2013 01:26 AM
Wheel Directory: Work Emotion CR Kai 17x8.0 +42 sneaky Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 01-08-2013 04:05 PM
Wheel Directory: Work Emotion XC8 18x?.? +?? quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 09-14-2012 02:42 AM
