Old 06-08-2013, 03:21 PM   #1
jflogerzi
jflogerzi's Avatar
FT-86 STG2 Brake Kit VS Wilwood 4R Slotted Front
FT-86 STG 2 Brake Kit
http://ft86speedfactory.com/ft-86-sf-stage-427.html
Wilwood 4R
http://ft86speedfactory.com/wilwood-...black-830.html
So I know that the stock brakes on the FR-S are pretty damn good. I am by no means a track person(Maybe 3-4 times a year is what I am shooting for) and mostly being a weekend car.(I will be taking the train to work, and my new house is 2 miles from the station) I plan to do an upgrade on the breaks later this fall after wheels and suspension this summer(I hope) Just trying to do some research to see whats worth it and whats over kill. I am also thinking of just new pads that have better byte as long as the car stays NA. Lastly I only plan to do the front breaks. If I do anything to the back, it will be only pads.
Old 06-08-2013, 03:58 PM   #2
powerj2
powerj2's Avatar
Drives: 2013 Scion FRS
you linked the same thing twice
Pew
powerj2 is offline   Reply With Quote
Old 06-08-2013, 04:02 PM   #3
jflogerzi
jflogerzi's Avatar
Haha fixed! Thanks
Old 06-08-2013, 04:27 PM   #4
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Just brake pads is all u need, i recommend PMu Club Racer
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
The Following User Says Thank You to RehabJeff86 For This Useful Post:
jflogerzi (06-09-2013)
Old 06-08-2013, 04:43 PM   #5
wparsons
wparsons's Avatar
Don't waste money on big brakes, just get better pads and fluid. I'm running Ferodo DS2500's and ATE Super Blue fluid with stainless lines and it's much better than stock.
flickr
Old 06-08-2013, 08:20 PM   #6
troek
troek's Avatar
Drives: 2012 Toyota 86
i second that. this car needs more power before it needs bigger brakes. im running trd pads and have to push them very hard before i notice any fade, and thats on stock fluid.
troek is offline   Reply With Quote
The Following User Says Thank You to troek For This Useful Post:
Old 06-09-2013, 12:00 AM   #7
jflogerzi
jflogerzi's Avatar
Thanks for the responses. Now are guys running the same upgrade pad for both the front and rears?
Old 06-09-2013, 12:29 AM   #8
RehabJeff86
Ya i hv PMu club racer both F/R with Motul RBF600 fluids and so far did 250 laps w/o fading even at Laguna Seca and Sears Point both heavy braking tracks
Old 06-09-2013, 08:00 AM   #9
troek
troek's Avatar
yeah i wouldn't mix and match pads.
Old 06-09-2013, 10:18 AM   #10
wparsons
wparsons's Avatar
I'm running the same compound front/rear as well. The only people that seem to be mixing compounds are people running Hawk pads since there isn't an HP+ for the rear yet so people run HP+ front and HPS rear.
flickr
Old 06-10-2013, 04:31 AM   #11
mike2100
mike2100's Avatar
Drives: 23 BRZ
What tires are you guys running? Thanks
mike2100 is offline   Reply With Quote
Old 06-10-2013, 09:47 AM   #12
wparsons
wparsons's Avatar
225/45 Dunlop Z2's, on stock pads/fluid it was pretty easy to overheat the stock pads (without boiling fluid!) in just a few laps. Stock pads also didn't have enough bite to really trigger the ABS with the stickier tires, the new pads don't have that trouble at all.
flickr
Old 06-10-2013, 09:56 AM   #13
CSG Mike
CSG Mike's Avatar
Same or similar compounds front/rear.
If you're a fairly experience driver, you'll want a BBK to reduce operational cost. The Essex kit is unbeatable in terms of value. If you want bling, then pick any kit you want.
I wouldn't be surprise if I finish off a set of PMU Club Racers in about 50 laps at Laguna on street tires.
Old 06-10-2013, 10:14 AM   #14
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Why not, nothing wrong with doing so. All depends on your goals and how you want the car to handle, trail brake and etc...
To the OP. We have Ferodo DS1.11 on our red car all around with DBA T3 rotors up front and this combo dramatically increases braking as well.
FT-86 SpeedFactory is offline   Reply With Quote
╬╬ WILWOOD Big Brake Kits ╬╬ Free Shipping - Expert Advice - Photos and more... FT-86 SpeedFactory Brakes, Suspension, Chassis 186 04-25-2016 01:28 AM
Wilwood Big Brake Kit Installed msile Suspension | Chassis | Brakes -- Sponsored by 949 Racing 52 03-03-2014 02:00 PM
FS: WISC. BNIB Wilwood Front BBK Scooby South Brakes, Suspension, Chassis 4 03-10-2013 03:22 PM
Wilwood Big Brake Kit for Scion FR-S / Subaru BRZ at Chase Bays Chase Bays Brakes, Suspension, Chassis 15 02-11-2013 02:58 PM
StopTech Slotted Brake Rotors (Front/Rear) for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 0 07-13-2012 10:58 AM
