Old 06-08-2013, 02:40 PM   #85
derek1ee
Drives: BRZ/FRS/STI/M3
These shocks come with a slight slot on the front struts so use the stock bolt to adjust camber as it does NOT Stretch like the WL camber bolts do. STOCk can be tq-ed to 140 ft lbs. WL's stretch above 85 ft lbs.
Hope that helps.
Myles
Hi Myles -
What if the slot doesn't give me enough native camber (@ ~-1 now and want ~-1.7)?
Can I use the OEM crash bolt on the upper slot hole? Or should I use SPC 81305 for the lower hole?
Thanks,
Derek
derek1ee is offline   Reply With Quote
Old 06-08-2013, 04:20 PM   #86
Originally Posted by wootwoot View Post
Do either of these set ups offer additional suspension travel over stock? If so, how much front and rear?
We get another shipment in soon. I'd rather pull some measurements from pics and show the travel than using drawings. But yes there is a good amount of droop and bump travel.
Myles
Old 06-08-2013, 04:21 PM   #87
Originally Posted by derek1ee View Post
Hi Myles -
Thanks,
Derek
I run my car 1 inch lower and I use OEM camber bolts. I get -2.6 front camber.
You will be fine !
Myles
melon (06-11-2013)
Old 06-09-2013, 03:14 AM   #88
derek1ee
You will be fine !
Myles
I'm sorry but just want to double check to be sure:
Running OEM camber bolt on upper slotted hole. correct?
Old 06-09-2013, 04:03 AM   #89
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Anxiously awaiting feedback on the zeros in regards to street daily ride. Was within days of just ordering v3s now these zeros seem interesting as I'm very likely "that guy" as Myles states.
Old 06-09-2013, 03:58 PM   #90
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
Ok.. so OEM camber bolts are the way to go? I ordered the WL camber bolts and have only been able to get -1.4 and -1.9 front camber with the T2s dropped low in the front.
OjiGeorge is offline   Reply With Quote
Old 06-09-2013, 07:32 PM   #91
UnOvertime
UnOvertime's Avatar
Drives: Firestorm FR-S AT
Off came the yellows and on went the Tarmac 0's. 1.25" drop all around.
UnOvertime is offline   Reply With Quote
The Following 3 Users Say Thank You to UnOvertime For This Useful Post:
ATL BRZ (06-10-2013), hanabie (06-09-2013), tg_1981 (06-09-2013)
Old 06-10-2013, 12:05 AM   #92
Overland'n'5thGEN
Overland'n'5thGEN's Avatar
Drives: 5th Gen Toyota 4Runner
How is the ride compared to the yellows? I really am closr to purchasing the zeros. I will probably only go an inch down though.
@Racecomp Engineering can you PM me a price for the zeros?
sent from a Galaxy SIII...
Overland'n'5thGEN is offline   Reply With Quote
Old 06-10-2013, 02:06 AM   #93
OICU812
Just a dude
OICU812's Avatar
+1 would really like to hear thoughts on what you see from the yellows going to the zero...
Old 06-10-2013, 03:13 AM   #94
OrbitalEllipses
Drives: Attitude
Indeed, do share.
Old 06-10-2013, 02:21 PM   #95
FR-S Matt
That clearance is what I love the most about them. Exactly what I need. I'm curious about the ride as well. Please share!
Old 06-10-2013, 07:38 PM   #96
UnOvertime
UnOvertime's Avatar
Alright. I have only driven 1 day and about 100 miles on them. The drop is wonderful, I actually stopped and drooled over the car when I left work about how nice it looks, so does it ride as nice as it looks?
The answer is yes. It is slightly rougher than the yellows, but not by much. On smooth as glass pavement, it is amazing and on rougher surfaces it is a good ride without too much bounce. Part of the "roughness" could honestly be from being a .5" lower and could be from me trying to compare every bump to the yellows. I drove about 4000 miles on the yellows. I have not gone and got my alignment yet, but I plan on doing that when I stop working 6:30-6 the first few days of this week.
If you are on the fence about the tarmac 0's because you feel they may be too rough then get off the fence. I love the ride and it feels almost the same as the yellows which I absolutely loved.
The Following User Says Thank You to UnOvertime For This Useful Post:
ATL BRZ (06-12-2013)
Old 06-10-2013, 07:45 PM   #97
OrbitalEllipses
Drives: Attitude
Yellows on stock shocks? I think the Yellow/Yellow combo is overdamped personally; I'm looking for something more critically damped without being underdamped/oversprung.
Old 06-10-2013, 07:47 PM   #98
UnOvertime
UnOvertime's Avatar
Yes yellows on stock shocks.
Racecomp Tarmac II Clubsport coilover JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 11-17-2013 12:02 AM
Tarmac Zero Coilovers Specs? tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 06-14-2013 12:26 AM
KW CLUBSPORT COILOVERS W/ FREE SHIPPING FOR THE SCION FR-S/SUBARU BRZ!!! NJA Brakes, Suspension, Chassis 7 03-30-2013 09:26 PM
Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 01:24 PM
Toyota 86 Tears Up Tarmac at 2012 TAS (TRD, N1, HKS, Up Garage Models) + LFA Roadster knoxviue FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 35 01-20-2012 02:44 AM
