View Poll Results: Stock Engine or Built Engine
Stock Block 22 53.66%
Built Block 19 46.34%
Voters: 41. You may not vote on this poll
Old 06-07-2013, 07:35 AM   #15
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
As NLM said, build while the block is still intact. FRS300 had to buy a new block as opposed to using his own. There really isn't much else to it.
slicktop is offline   Reply With Quote
Old 06-07-2013, 10:46 AM   #16
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I gotta disagree with the build it while it is running crew. I am never a fan of pulling a perfectly working engine out of a car. While everyone likes to believe that when you build your motor it will be put back together perfectly and will run like a top for hunderes of thousands of miles, but that just isn't reality. Piston rings can be gapped improperly, cross hatching and piston ring seal can go wrong, rod bearings can be improperly sized, crank bolts, rod bolts, head bolts can be torqued improperly, head gasket might not seal properly (happened to one member), and any number of other things can go wrong when building the motor that will just lead to pulling it back out and the car being down again. Enjoy the car now. If it blows, then build a new one at that time. If you are worried, then start stock piling parts for the rebuild now. I mean kids are totaling these things left and right, so blocks should start becoming more more easy to aquire.
The Following 4 Users Say Thank You to King Tut For This Useful Post:
akuhei (06-07-2013), DAMotorsports (06-07-2013), JoeBoxer (06-07-2013), PineappleFriedRice (06-07-2013)
Old 06-07-2013, 11:53 AM   #17
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
good point but wouldn't building before it blwong allow you to reuse what you have verus, replacing what you had and forging ?
killerkid08 is offline   Reply With Quote
Old 06-07-2013, 12:08 PM   #18
SillySaxon
SillySaxon's Avatar
Drives: Sc10n Series FR-S
So 11 psi is safe on stock without any mods?
Or are you going to have to mod your engine no matter what if you boost?
SillySaxon is offline   Reply With Quote
Old 06-07-2013, 01:18 PM   #19
King Tut
NASA SpecE30 Racer
King Tut's Avatar
A used shortblock will come with everything you need and you can build that up and have it ready for if and when your motor does blow.
Old 06-07-2013, 01:19 PM   #20
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Spend some time reading some threads n00b. You don't have to build your motor no matter what, and I am running 14 psi. Others run higher psi on E85 as well.
Old 06-07-2013, 01:22 PM   #21
SillySaxon
SillySaxon's Avatar
reading threads, oh like this boost advice thread perhaps?
Maybe the advice place is a good place to get advice?
Maybe?
Save your unhelpful garbage for the honda forums.
Old 06-07-2013, 01:49 PM   #22
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Maybe?
This a thread about deciding whether or not it is worth pulling a stock engine out to build it. This isn't a thread for a n00b to ask how much boost is safe. Only n00bs ask questions like that because there is no correct answer as there are way too many variables. Go read every thread in the Forced Induction section like I have, and then tell me that my posts are unhelpful garbage. I like Honda-Tech by the way.
Old 06-07-2013, 01:53 PM   #23
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Yes... and if you blow your motor and it damages your heads, than things get very expensive, very fast.
No Limit Motorsport is offline   Reply With Quote
Old 06-07-2013, 02:05 PM   #24
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
That is true !
Similar thing happened to my bros STI, crank got messed up ( whole short block ) so we thought the heads where fine. Went ahead built that thing real bad ass , sleeved the motor and everything and once we tuned it one of the cylinders would have a slight knock a very slight one. After a week or two we pulled the heads off and one of the valves on cylinder 4 were cracked/ bent which was caused from the prior issue. So it was more money into the pit.
I'm having doubts about building this engine for some reason, I feel like the DI system and all the issues are making wander away and think about a 2j swap
Old 06-07-2013, 02:10 PM   #25
SmsAlSuwaidi
Boosted
Never going to happen
A 400whp frs would obviously from a roll
Old 06-07-2013, 02:13 PM   #26
killerkid08
Cool Stuff
Drives: Cool Car
Originally Posted by SmsAlSuwaidi View Post
That is true !
If someone , hint hint, had a kit for the big 6's, rb/2j/1j, I'd have bought it already and skipped the whole boxer build up. I just grabbed a seperate engine for build up, and I'll try not to explode my current one.
Old 06-07-2013, 02:16 PM   #27
SmsAlSuwaidi
Boosted
True, I'd have to do it custom !
You got another engine ?
Old 06-07-2013, 02:37 PM   #28
killerkid08
Cool Stuff
Drives: Cool Car
Yea. Grabbed it used.
Large Project - Assistance Required Dezoris Tracking / Autocross / HPDE / Drifting 12 04-16-2013 08:45 PM
Maintenance Required? Dan86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 01-23-2013 01:58 PM
Please Help! Front pipe advice on a stock exhaust... ScionFrsFan Engine, Exhaust, Transmission 12 01-15-2013 01:45 PM
Damage to built up area of sidewall/stock tire. Zadkiel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 09-25-2012 09:03 PM
To ALL Vendors: Sponsorship Now Required for Commercial Use of Site Hachiroku Engine, Exhaust, Transmission 0 08-03-2012 12:40 PM
