Old 06-07-2013, 02:08 AM   #15
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
@*KID* that looks more than a 1 inch drop. Looks clean though
Enraged21 is offline   Reply With Quote
Old 06-07-2013, 02:08 AM   #16
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Originally Posted by TouchMyHonda View Post
Thanks to the crew over at @Touge Factory I was able to get ahold of some Swift springs for a B day present to myself. I should start off with that stage that I have driven may cars on all kinds of shit coil-overs to the cream of the crop super expensive stuff.
Did you cut your oem bumpstops? if not, which bump stops did u use?
hanabie is offline   Reply With Quote
Old 06-07-2013, 09:36 AM   #17
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Originally Posted by *KID* View Post
Heres a side view of my FRS with the FRS application
That is exactly what my car looks like.
I left them completely alone. No reason to cut them.
TouchMyHonda is offline   Reply With Quote
The Following User Says Thank You to TouchMyHonda For This Useful Post:
hanabie (06-07-2013)
Old 06-07-2013, 11:03 AM   #18
8686
8686's Avatar
Drives: 86
Did you need any alignment after the install?
Seriously considering these springs now.
8686 is offline   Reply With Quote
Old 06-07-2013, 11:52 AM   #19
hanabie
hanabie's Avatar
Yes. It is required when the car is raised or lowered.
It is time to find a good alignment shop
The Following User Says Thank You to hanabie For This Useful Post:
TouchMyHonda (06-07-2013)
Old 06-07-2013, 11:58 AM   #20
overlookedx
overlookedx's Avatar
Drives: 2015 WRB Limited
Well, this thread has made my decision for me. Swift springs it is. At a drive a few weeks ago I saw a car with these springs in person and first thing I thought was it's the perfect drop.
Superfast Jellyfish
overlookedx is offline   Reply With Quote
Old 06-07-2013, 12:12 PM   #21
hanabie
hanabie's Avatar
yay! finally made my decision! was torn between swift and rce.
would love that extra .20" inch drop.
Does the instruction tell you to cut bump stops?
I would love to leave it alone.
Old 06-07-2013, 12:23 PM   #22
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
Does seem lower than an inch, I havent done any measurements. Like the OP said it feels alot smoother than stock. You dont feel every bump or rock, but once you really work them on the corners, it stiffens up nice. Really love the ride and performance and the looks.
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 06-07-2013, 12:25 PM   #23
TouchMyHonda
Vtec Jesus
You guys need to hit up my buddy Jamie @Touge Factory. He probably can beat most any price you find online.
If you are going to keep stock shocks I would highly recommend the swift. The stock shocks really dont have much travel from the oem ride height, let alone taking an inch off of that. Any lower would cause the shocks to really wear out fast. Swift took a lot of time to make sure this setup would last and truly improve the handling characteristics of the car naturally.
overlookedx (06-07-2013)
Old 06-07-2013, 05:40 PM   #24
soodxn
Drives: S2000
how much negative camber in the back after installing these?
soodxn is offline   Reply With Quote
Old 06-07-2013, 05:50 PM   #25
TouchMyHonda
Vtec Jesus
I am trying to score an alignment soon. I will post specs as soon as I do that.
Old 06-07-2013, 10:45 PM   #26
getbent
Drives: 2013 FR-S Blue MT
Mine was -1.9 / -2.4. You should plan on some LCA to dial in the camber to your liking.
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
Old 06-07-2013, 11:02 PM   #27
TouchMyHonda
Vtec Jesus
2.4 in the rear isn't so bad actually that may be ideal for me. I plan on getting some whiteline front camber bolts for when I snag some 17x9's. that way I am prepared.
Old 06-08-2013, 01:50 AM   #28
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
id like to get the swift springs for the frs. since the frs and brz share the same rear spring rate, can someone elaborate between the difference in the front spring rate 3.0k in the frs vs the 3.8k in the brz. what does this do to the driving characteristics? my car is a dd but also plan to do HPDE as well.
garfull is offline   Reply With Quote
Prototype Swift Springs for FR-S mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 137 09-17-2013 10:36 PM
Stance coilovers with Swift Springs clickfiveZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-05-2013 07:20 PM
Swift springs rate ID subaruferrucci Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2013 05:26 PM
Fortune auto with swift springs? DarkCard Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 03-29-2013 04:15 PM
SWIFT lowering springs ? rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 10-31-2012 07:15 PM
