Old 06-06-2013, 01:59 PM   #71
mla163
Overthinking it
Drives: BRZ in CS
If I have to choose between better acceleration (235/40 or 215/45) and higher top speed (225/45), I'll pick acceleration everytime.
I know the 235 will fit. I want to make sure it's not so wide that it squirms excessively.
mla163 is offline   Reply With Quote
Old 06-06-2013, 02:44 PM   #72
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
I don't necessarily agree with that statement, particularly on cars which have such an intrusive rev limiter and based on the size and style of course you may typically run on.
With that said, the gearing and top speed differences of a 235/40 versus a 215/45 versus a 225/45 is so negledgable I would not consider one an advantage over the other based purely on a rolling dimeter basis, it is all within noise. Which tire provides maximum grip while still being "happy" on the wheel diameter is the way I would go.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
Old 06-06-2013, 03:08 PM   #73
simpleisbest
Senior Citizen
Drives: Scion FR-S
FYI, my BFG Rivals 225/45-17 are actually wider than my 235/40 ZIIs.
Guess the metric system is still a mystery for many US companies...
simpleisbest is offline   Reply With Quote
Old 06-06-2013, 03:12 PM   #74
mla163
Overthinking it
Drives: BRZ in CS
In light of my recent posts, I went ahead and changed my title to be more appropriate
The Following 3 Users Say Thank You to mla163 For This Useful Post:
Boxer 86 (06-27-2013), des (06-06-2013), Kido1986 (06-06-2013)
Old 06-06-2013, 04:29 PM   #75
des
des's Avatar
No noticeable squirm on the 235 ZIIs. I'm on my second set; love 'em.
des is offline   Reply With Quote
The Following User Says Thank You to des For This Useful Post:
mla163 (06-06-2013)
Old 06-06-2013, 04:33 PM   #76
qoncept
qoncept's Avatar
FYI, for the first post, here are the numbers quoted by Whiteline for their 22mm front sway bar. Mine should be here next week.
Soft Setting - 118.5%
Hard Setting - 174%
qoncept is offline   Reply With Quote
Old 06-06-2013, 05:39 PM   #77
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Hard Setting - 174%
Thanks. First post updated
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 06-06-2013, 06:08 PM   #78
xwd
Hard Setting - 174%
FYI most of us running in RTR/CS (and even STX) and using Whiteline front bars are using their 20mm bar. I'm not aware of anyone using the 22mm bar without also using their larger rear bar. I can't imagine running a 22mm bar, I feel the 20mm on the second hole is too much front bar.
Old 06-06-2013, 06:50 PM   #79
Kido1986
Dodging cones
Kido1986's Avatar
Think about how I felt when I decided to try the 25.2mm Hotchkis... dear god understeer
Old 06-06-2013, 07:15 PM   #80
Biggins
Drives: Yes
I'm still on the Hotchkis; I know it's a little too big, but I'm not dumping it for at least another month or two. I keep changing too many things each event and need a baseline. I'll probably move to the 20mm Whiteline or Strano eventually.
Biggins is offline   Reply With Quote
Old 06-06-2013, 08:25 PM   #81
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Why baseline off something you know is directionally incorrect? Id suggest you'd be better off baselining with the stock bar than doing that.
Old 06-07-2013, 10:33 AM   #82
Biggins
Drives: Yes
I ran the stock bar last year. My ~PAX position from this vs. last year shows I'm much faster on the Hotchkis than stock, but every event I've done this year has been under 50 degrees or rainy. I'm not convinced the Hotchkis is incorrect, but I'm not sure it's ideal. The DC Pro this weekend will give me a gauge of how far I am from where I want to be... but the looming rain may still not help me find a comfort zone.
Old 06-11-2013, 06:08 PM   #83
mla163
Overthinking it
Drives: BRZ in CS
Tirerack has 17x7 RPF1s on backorder until the end of July. Discount Tire Direct doesn't sell Enkeis.
Does anyone know where else I can pick up a set in the near future?
Old 06-11-2013, 06:55 PM   #84
Eric1855
Drives: LP DSP / CSP '13 BRZ
If the rules go through as published what about this option...
225/50/R16 BFG Rivals on 16x7 rims.
You'd get a lighter rim, and tire is same weight and tread width as 225/45/17, but a slightly smaller diameter over 225/45/17.
Eric1855 is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
