Old 06-06-2013, 10:12 AM   #29
tomato86
tomato86's Avatar
Drives: '13 FR-S | '08 Evo [Sold]
Originally Posted by CrazyWookiee View Post
Sorry, I don't follow
Trust, I was heavy into that. I had everything from HKS to Tomei IC piping, Gruppe M intake, Cusco strut bar etc. It wasn't the selection the earlier Evo's got.
This car will be worse
tomato86 is offline   Reply With Quote
Old 06-06-2013, 10:24 AM   #30
dabocx
dabocx's Avatar
Drives: Scion FRS
Im too used to the honda scene with their super tucked and cleaned out engine bays. Even the s2000s get cleaned up so well.
I wonder how much you could clean up ours.
dabocx is offline   Reply With Quote
Old 06-06-2013, 11:15 AM   #31
DIM
It can probably look similar to this.
DIM is offline   Reply With Quote
The Following User Says Thank You to DIM For This Useful Post:
dabocx (06-06-2013)
Old 06-06-2013, 11:23 AM   #32
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
dam how did you guys keep your engine bays so clean it's like you guys never drive the car. I have my car for 4 months now and my engine bay is dirty.
chenshuo is offline   Reply With Quote
Old 06-06-2013, 11:33 AM   #33
Hardrock4445
Hardrock4445's Avatar
Wash it?
I wash mine down every time I wash the car.
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
Hardrock4445 is offline   Reply With Quote
The Following 2 Users Say Thank You to Hardrock4445 For This Useful Post:
CrazyWookiee (06-06-2013), Retro86 (06-06-2013)
Old 06-06-2013, 12:03 PM   #34
CrazyWookiee
Drives: Whiteout FR-S
I just have a larger paint brush and "dust" it every time I wash the car and use some Citrus Guys grime reaper.
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
The Following User Says Thank You to CrazyWookiee For This Useful Post:
Old 06-06-2013, 12:19 PM   #35
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
i remember the first few wire tucked s2000s in the US and how the tires ate up wire harnesses that ran too close under the wheel wells.
Chasebay is doing a semi-tucked FRS, like what they do with their honda's
WingsofWar is offline   Reply With Quote
The Following User Says Thank You to WingsofWar For This Useful Post:
dabocx (06-06-2013)
Old 06-06-2013, 01:04 PM   #36
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
Originally Posted by Marchy View Post
what did you end up using?
VHT ENGINE METALLIC™Burnt Copper
It's chemical resistant and good up to 650 degree
Spartan65 is offline   Reply With Quote
The Following User Says Thank You to Spartan65 For This Useful Post:
Marchy (06-06-2013)
Old 06-06-2013, 01:22 PM   #37
dabocx
dabocx's Avatar
Drives: Scion FRS
Yep looking closely at chasebays build, im hoping after im done with boost and wheels I can focus on little details like engine bay and interior.
Old 06-06-2013, 01:23 PM   #38
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
Like this?Name:  ImageUploadedByTapatalk1370535810.860068.jpg
The Following User Says Thank You to Lverasky For This Useful Post:
ZetaPerformance (06-06-2013)
Old 06-06-2013, 02:25 PM   #39
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Originally Posted by Hardrock4445 View Post
Wash it?
what do you use to wash? what components do you cover up? how do you dry it? I don't have a lawn blower to dry.
Old 06-06-2013, 06:24 PM   #40
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
I think there is plenty out there for engine bling, its just not cheap for pretty much something that doesnt add performance.
Here is mine and I still plan to add JDM Password red battery tie down and purple bolt dress up kit...Then finally top it off with the APR carbon fiber alternator cover.
FR-Shadow is offline   Reply With Quote
The Following User Says Thank You to FR-Shadow For This Useful Post:
Old 06-06-2013, 06:37 PM   #41
Hardrock4445
I just use simple green. Put it on mist and spray it around. Hit it with the hose and take the car for a drive to dry it off. If I gets really grimy ill run it to get hot. Then continue the same way.
Edit: I don't cover anything up. I just try not to spray a direct shot at the fuse box.
The Following User Says Thank You to Hardrock4445 For This Useful Post:
chenshuo (06-06-2013)
Old 06-06-2013, 10:34 PM   #42
UltraMarine86
UltraMarine86's Avatar
Drives: Ultramarine '13 FR-S
These are from the password:jdm website:
Engine Pulley Cover
http://passwordjdm.com/PasswordJDM-D...8712C2582.aspx
This is their Other Cover:
(not affiliated with password:jdm in anyway)
UltraMarine86 is offline   Reply With Quote
Engine bay caps colored red? husker741 Cosmetic Modification (Interior/Exterior/Lighting) 4 05-03-2013 04:40 PM
Purpose of alternator and a/c covers Turbowned Engine, Exhaust, Transmission 3 03-03-2013 05:54 PM
Plasti-dip or painting the fluid caps in the engine bay Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 8 09-07-2012 04:03 PM
Anybody have a lead on custom fitted car covers and seat covers for the FR-S? Grateful Dave Cosmetic Modification (Interior/Exterior/Lighting) 17 08-27-2012 10:41 AM
