| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: frs white tri-coat
Wheel Directory: Work VS-XX 18x9.0 +33 / 18x10.0 +33
![]() Hi guys! Recently, i have find a set of work vs-xx in 5x100 (18x10 +33, 18x9 +21) , I thought the wheels would not go and would rub on the body but surprise ... all is okay. Here are some pictures but i will post more soon.. Last edited by DarrenDriven; 05-12-2014 at 12:27 AM. |
#2 |
Drives: Scion FRS
What tire size? And MOAR PHOTOS!
#4 |
no its on bc rancing coilovers but im not slammed lol..
#5 |
225/40/18 all around
#6 |
Drives: 2005 Toyota Camry
I'm not sure those offsets are correct... the VS-XX is a 3-piece wheel and the offsets can't change from what is offered.
And those offsets (on the car, as-listed) are not offered. What offset are they? http://www.workwheelsusa.com/media/w...-XX%20Spec.pdf -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | diss7 (06-05-2013) |
#7 |
Drives: Argento FR-S
Sick
#8 |
Drives: e92 335i, FRS, Lexus ls400
looks really nice! and its not rubbing because your not low enough..haha
IG: nabb335 |
#9 |
Would really help the community if correct offset info was posted...
-alex |
#10 |
oups sorry ...corection: 18x9+21, 10+33 .. maybe different offset beacause the step lips... idk..
#11 |
Drives: AE86, 2x GT86, TE27
#12 |
yess but look at vrmotoring.com and you can see many set have not the offset in work catalogue... maybe a special order idk...
#13 | |
Señor Member
Drives: white BRZ 6MT
#14 |
You can't customize special order 3-piece wheels that go beyond what the manufacturer offers.
There's only 3 parts to a 3-piece wheel: inner barrel, outer barrel, and center disk. The center disk is always of a fixed design, usually R-disk, A-disk, or O-disk for different caliper clearance. The inner/outer barrel is also of a fixed design in the sense that when pieced together, they create the width of the wheel. So given those 3 fixed parameters, you do not have "custom" offsets available... to be honest, every multi-piece wheel anyone will ever order will always be custom because they are made to the order. I really suggest you (or anyone else researching) to actually look at the link I posted. You CANNOT order a Work VS-XX beyond what is listed in the PDF... unless you shave the backpad of the wheel 2-3mm to get more offset. But, Work won't do this for you since it won't meet their safety compliance in Japan. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | diss7 (06-06-2013) |
| Wheel Directory: Work VS-XX 18x9.0 +34/18x9.5 +39 | mav1178 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 09-13-2014 04:09 AM |
| Wheel Directory: Work Meister S1R 18x9.5 +25 | ebphoto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 158 | 06-09-2014 05:29 PM |
| Wheel Directory: Work Meister S1R 18x9.0 +35 | diss7 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 01-02-2014 01:05 AM |
| Wheel Directory: Work Emotion 11R 18x8.5 +45 / 18x9.5 +38 | DR1FT | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 01-04-2013 01:16 PM |
| Wheel Directory: Work Emotion 11R 18x9.5 +30 | autofashionfred | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 24 | 08-11-2012 01:39 AM |
