Old 06-05-2013, 07:33 PM   #1
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Interior window film (grease?)
Hi Friends,
I've had my BRZ for about 2.5 months and I've noticed and foggy film or grease developing on the inside of my front windshield (a bit in the rear too). It really shows up when driving into direct sunlight or oncoming night time headlights. I had a similar foggy film develop on my previous car as well. Is this from the HVAC system or from me? I have previously tried windex on it but I didn't get the results I wanted.
Anyone have any similar situation or have any idea how to get rid of it?
Update: I seem to have found satisfactory results in removing the film. Do an interior wipedown of the windshield with a damp microfiber cloth and follow up with a dry one. Seemed to do the trick.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 06-05-2013, 09:20 PM   #2
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Drives: 2013 FR-S Ultramarine 6AT
I've been noticing the same in my car, tried Invisible Glass to no avail. I'm open to suggestions.
Frances - 2013 Scion FR-S in Ultramarine
Owner's Journal
Moshpit37 is offline   Reply With Quote
Old 06-05-2013, 09:37 PM   #3
#87
I usually post drunk
#87's Avatar
All of my cars get this over time. It's the result of continuous condesation, it should clean off but getting a streak free finish is hard. You need a non linting cloth and very little cleaning solution. I find the best are high quality paper towels as opposed to a microfiber.
#87 is offline   Reply With Quote
Old 06-05-2013, 09:52 PM   #4
Gunman
Drives: 2019 Mazda Miata RF
Vinyl fog?
http://www.autogeekonline.net/forum/...indshield.html
Old 06-05-2013, 09:56 PM   #5
White64Goat
Mostly off-gassing from the plastics causes this. Try a little ammonia & water mix in a spray bottle and newspapers wadded up then kinda flattened out. Don't use color comics. Newspaper is almost lint free. DON'T use this on your tinted windows. Check around at car shows too for people selling super-micro fiber towels. Usually 2 for $10 and they look like a paper towel but are a super tight woven micro fiber. These you can use with just water alone.
Old 06-06-2013, 12:52 AM   #6
OrbitalEllipses
Drives: Attitude
http://www.detailersdomain.com/Uber-...wel_p_588.html
Will change your life.
Old 06-06-2013, 08:23 AM   #7
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Could be the vinyl off-gassing as stated or could be evaporation of any interior cleaners / detailing products used including leather treatments on leather seats. Some of the earlier products like Armor-All are notorious for this. Could be a combination of the two. In either case leaving a closed up car in full sun and heat will make this worse. If it is vinyl off-gassing, it will eventually get better.
Mine hasn't been too bad so far. I haven't used any products on the interior and there hasn't been enough sun or heat here in New England to cause much off-gassing. Invisible Glass has worked well enough when needed.
BTW, I always lay a clean beach towel over the entire dash / steering wheel area before spraying the glass. No headaches with drips or overspray affecting those areas.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
The Following 2 Users Say Thank You to Clembo For This Useful Post:
BRZNutt (06-10-2013), Cjymiller (06-06-2013)
DCW Carbon Fiber interior items! Center console Plaques / Interior panels doggy Interior Parts (Incl. Lighting) 143 10-11-2013 11:17 AM
LED interior conversion kits (interior), USA stock & warranty WTF Interior Parts (Incl. Lighting) 0 05-22-2013 10:17 PM
interior illumination kit and side window visor davey90 AUSTRALIA 40 05-07-2013 09:49 AM
Sharp grease lines Tiremonkey0824 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 09-24-2012 01:29 PM
headlight film? jdmboss86 Cosmetic Modification (Interior/Exterior/Lighting) 0 06-30-2012 03:21 PM
