Old 06-04-2013, 02:57 PM   #729
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by FRSPirate View Post
Love the vinyl on this car! And it has an appropriate hood.
The Following User Says Thank You to sw20kosh For This Useful Post:
whataboutbob (06-05-2013)
Old 06-04-2013, 07:20 PM   #730
Pete
Pete's Avatar
Drives: 22 BRZ
nevermind, *sigh*
Edit: That is some good looking vinyl+hood. I wonder if i could rig up an oil cooler in front of that scoop...
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
The Following User Says Thank You to Pete For This Useful Post:
sw20kosh (06-04-2013)
Old 06-04-2013, 07:28 PM   #731
invisage
Drives: Thunder Silver 86 GTS
Will see if I can grab weight etc today
invisage is offline   Reply With Quote
Old 06-05-2013, 04:07 AM   #732
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by Subzero View Post
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
The Following 3 Users Say Thank You to carbonBLUE For This Useful Post:
invisage (06-05-2013), s2d4 (06-05-2013), Subzero (06-05-2013)
Old 06-05-2013, 04:22 AM   #733
invisage
So it cooled down overnight so they could get to work on it today. Got to see them assemble the intercooler inside the manifold:
Figured out the pics finally Thanks for the help.
The Following User Says Thank You to invisage For This Useful Post:
Sonolin (06-05-2013)
Old 06-05-2013, 04:26 AM   #734
invisage
Here it is in the air after the radiator for the intercooler was installed.
Old 06-05-2013, 04:40 AM   #735
robispec
Drives: Black frs project
NICE..you know what the IC weights in at? (total additional)
robispec is offline   Reply With Quote
Old 06-05-2013, 05:07 AM   #736
s2d4
s2d4's Avatar
1st picture is meant to be about the intercooler but it has 4 other chargers in that looks like the 150 variant, no clear picture of the intercooler setup.
2nd picture is just a rather cheezy picture of the car in the air with the supercharger acting like some japanese girl doing a scenery photo shoot, no picture of the heat exchanger showing where and how it was mounted/water lines routed.
Ohh, and no invites Although I didn't wake up until 2pm..
Old 06-05-2013, 06:14 AM   #737
invisage
Will find out tomorrow when I go back to pick her up
Old 06-05-2013, 07:13 AM   #738
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by Fast_Freddy View Post
Do you know what the limit of the oem MAF setup is? The MAS looks very similar to the Denso unit used on my 08 XB and that was good for +120bhp. MAS voltage maxed at 3.9V stock and 4.5V at 6psi. IIRC that was about 240 g/s? I can check some data logs to be sure.
Just curious how far I can go on the MAF before resorting to less accurate speed density.
Stock it's scale up to 280g/s at 5.0v I see just over 4v 140g/s with tune, front pipe and axle back. Stock rom has a max maf table that is limited to 200g/s in stock form. There should be enough room at least for the low boost setup with header etc on the stock maf housing but there won't be much headroom after that i don't think.
Can anyone chime in on if the base maps are speed density or maf based?
The Following User Says Thank You to mad_sb For This Useful Post:
Fast_Freddy (06-05-2013)
Old 06-05-2013, 08:25 AM   #739
FeaR-S
Drives: Great White
i believe that is left to the tuner and what they prefer.
FeaR-S is offline   Reply With Quote
Old 06-05-2013, 08:55 AM   #740
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I'm pretty sure you can just increase the intake piping and rescale the MAF to move as much air as you want. That's why running a full intake without a tune has the potential to be disasterous.
As for the fuel maps, traditionally Subaru maps are Load vs RPM, with Load calculated: Load = (total g/s airflow) / (rpm) * (60)
g/s is derived from MAF voltage then adjusted by the scaling. So you can, in theory, bump up to a 4" intake and all you'd have to do is adjust the scaling to get the appropriate g/s.
Old 06-05-2013, 08:57 AM   #741
ft_sjo
Drives: GT86
.. and potentially suffer low-end MAF resolution problems.
Old 06-05-2013, 09:05 AM   #742
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
The same resolution problems that just about every other MAF based vehicle suffers from. We're all limited to a 5v signal to determine total air flow, yet there are quite a few people using that same 5 volts to measure air for a whole lot more power than anyone is making in an 86...
Sellout is offline   Reply With Quote
Bullet/Sprintex/Innovate on the bullet website JoeBoxer Forced Induction 333 04-18-2013 10:07 AM
Still searching for an FR-S? 2 available in Little Rock Moshpit37 Southwest 9 01-02-2013 10:32 AM
Bullet SC 86 Loki556 AUSTRALIA 9 08-08-2012 01:39 AM
Searching Inventory in the SE Erroneous Southeast 40 07-23-2012 04:40 PM
