#43 |
i'm sorry, what?
Drives: Canada
people can do 1.5G sustainable on A6s, spikes can easily get into the 2.0 category
in your picture the bolt bends nearly 45 degrees at 2.0 side load thats... kind of catostrophic, is it not?
#44 | |
Drives: 2013 FR-S Ultramarine
What you're looking for in those pics is for peaks in the stress/strain the part is being put under. blue usually represents a very low stress level, yellow is higher, orange higher, and red is usually bad. That is, if the material properties and unit scaling are setup properly. The pics show that according to that analysis, everything is well within acceptable stress/strain levels. ![]() Cheers Nathan |
| The Following User Says Thank You to SubieNate For This Useful Post: | 7thgear (06-04-2013) |
#45 |
i'm sorry, what?
Drives: Canada
excellent, thank you.
#46 |
FT86Club Official Vendor
Drives: Subarus
Thanks Nathan! Correct, the images are exaggerated, the actual deflection will be fractions of a mm, almost impossible to spot with the naked eye so the program automatically exaggerates it for visualization. We've also increased the adjuster size from 5/8's in the prototype model to 3/4's in the production version. It will add a good amount of stiffness and strength. The final OTS arm will look like this to remove debris build up and allow for bottom mounted adjusters to be reached:
#47 |
Drives: A Potential Traffic Ticket
ETA?
#48 |
Drives: Subarus
There is one prototype version available. The revised version will take roughly four weeks to receive from date of build order
#49 |
Drives: 2003 Subaru Outback
How much camber adjustment will this allow for the rear?
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
#50 |
Drives: Subarus
It depends on your ride height and which side it's on. We haven't had a chance to rack it with a car at stock ride height, but you should be able to get over -3 degrees at stock ride height. More when lowered.
#51 |
What about dialing back in? If you want less camber and you are dropped around 2 inches and have -3*, could you dial it back to around -1.5*?
#52 |
Drives: Subarus
Yeah, that shouldn't be an issue, the arm shortens about 15mm vs. stock.
#53 |
Drives: Toyota 86 GTS
Out of curiosity, have you considered lowering the mounting point of the shock to decrease ride height while maintaining bump travel. For e.g., Stance and GTSpec have this sort of design. If not, what were your reasons? Would a lower point have an adverse effect on the geometry?
| The Following User Says Thank You to eckoflyte For This Useful Post: | ML (08-13-2013) |
#54 |
Pegasus White
Drives: 86
has anyone fitted these yet?
Driving: Pegasus White Manual GTS 86.
#55 |
Drives: GT86
The thing that worries me about these (and no doubt similar design items) is as is shown on the first page, with just 2G force (on multiple planes), the arm fails. what about when you lose the rear end a bit and tap the rear wheel against a curb? That's a LOT more than 2G!
#56 |
Pegasus White
Drives: 86
Even a stock arm wouldn't survive that kind of impact.
| Tags |
| hancha, rear lower control arm |
| Rear lower control arm part # | BRZranger | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 05-15-2013 12:33 AM |
| Hancha Rear Toe Link | Hancha Group | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 51 | 04-05-2013 08:18 PM |
| Delete | driver01 | Brakes, Suspension, Chassis | 11 | 02-06-2013 01:56 PM |
| cusco rear lower control arms for FR-S BRZ | driver01 | Canada Classifieds | 3 | 02-01-2013 05:28 PM |
