Old 05-19-2013, 10:54 PM   #155
Alliedforces86
Flat 4 Handyman
Alliedforces86's Avatar
Drives: Firestone Red FR-S & WRB MY2002 WRX
Originally Posted by dwx View Post
Looks great I have some coming eventually. I would have gone with a 245/40 tire myself.
I don't mind a meaty tire
Alliedforces86 is offline   Reply With Quote
Old 06-04-2013, 01:31 PM   #156
loogs
Drives: on cruise control
Going with the +45 setup in these. Will post pics next week
loogs is offline   Reply With Quote
Old 06-04-2013, 04:59 PM   #157
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
The +45 will hit the tie rod ends on full lock if the car is lowered 20mm. Or even just under compression and full lock.
86•BRZ is offline   Reply With Quote
Old 06-04-2013, 09:00 PM   #158
Gunman
Drives: 2019 Mazda Miata RF
Looking foreward to pix. Shots of the front spring clearance would be nice too.
Old 06-04-2013, 10:04 PM   #159
loogs
what does that mean?
Old 06-05-2013, 12:07 AM   #160
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
They do not fit
Old 06-05-2013, 08:12 AM   #161
loogs
They do not fit
You're the only person to say that. Tirerack says they do fit. No offense but I believe them
Old 06-05-2013, 08:36 AM   #162
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
for someone who doesn't know what a tie rod end is, it might pay to heed the advice of others rather than generic fitment calculators. I am not the only one to say that they don't fit.
I was genuinely trying to help you avoid the mistake I made. I still maintain the +35 pokes too much but it is the best option if you want 9" RPF1 fitment.
They rub as pictured on both sides. It took me a while to notice.
Please go ahead and fit them and let me know how you go
The Following 3 Users Say Thank You to 86•BRZ For This Useful Post:
DriftEightSix (06-05-2013), rcm47 (04-10-2017), Vic4uf (07-03-2016)
Old 06-05-2013, 09:02 AM   #163
loogs
Sorry, that's just my frustration rearing its ugly head as I have already ordered these. I spoke to tire rack again and they guaranteed me they would fit. They said they wouldn't list it if it didn't fit and they said they bring the vehicle in and test it before they list the fitments. So I don't know what to think
Old 06-05-2013, 09:22 AM   #164
loogs
Out of curiosity, which coil over would be best to go with to resolve this issue?
Old 06-05-2013, 09:24 AM   #165
apexaddict
FWIW, my car is fairly low (on KW V3s) and I do not get tie rod rubbing with 17x9 +45 RPF1s and 245/40/17 Hankook RS3s. However, the tires do rub the sway bar slightly at absolute full lock, so it's possible that is keeping them from hitting the tie rods. The sway bar rub is just enough to clean the bar off, so it's not an issue, even with daily driving and/or autocrossing. I make a conscious effort to not go absolute full lock (and I rarely need to anyway), but even if I have to, it's not enough rubbing to be an issue.
I think you will be fine, depending on your tire size. I also agree that the +35 sticks out too much, so worst case scenario you can add some studs and a 3-5mm spacer up front.
Andrew P.
#14 STX Scion FR-S - powered by Stranoparts and Moto-East
apexaddict is offline   Reply With Quote
Old 06-05-2013, 09:43 AM   #166
loogs
remember though im not on coilovers, im only on eibach springs with a 1 inch drop. i really dont know what to do. i cant afford coil overs right now but i want to do these wheels without spacers. BTW, can you post a pic of your setup? thanks
Old 06-05-2013, 02:44 PM   #167
apexaddict
All I have at the moment that's recent.
Andrew P.
Old 06-05-2013, 04:07 PM   #168
loogs
i just got back from the shop. they mounted the front wheel for me and we studied everything and it comes down to this, the 245/40 setup that i have, hits the tie rod at full lock. its not the tire but the rim itself. im just gonna live with it cause like you said, its just a rare scenario for full lock. i hope im not making the wrong decision but the installer at the shop said that he would do it if it was him and not worry about it. thanks for the help
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
