#14701 |
Drives: Ultramarine FR-S AT
...I really understand the whole shudder when coming out of general forums.
That place is a madhouse.
The Following User Says Thank You to Spd229 For This Useful Post: | Dimman (06-03-2013) |
#14702 | |
I did have my primary come apart about 100ft down though.....that was interesting...-breath- -breath...water, oh shit-
#14703 |
So is internet access. Granted, it's not like I've watched phone / cable companies milk slow internet before simply because it "isn't available in your area."
There's infrastructure issues and then there's just greed.
#14704 |
Wayward Member
Drives: Hot Lava 86
I wonder what a relatively inexpensive, very modest drop would be... Because I want a lip kit too, but I really don't want to worry about scraping. I also don't need like super special racing springs/coils that cost like 3k. I don't want cheap ones, but I'm not really planning on tracking, at least not hardcore, if ever.
#14705 |
Drives: Sexy Frs Firestorm M/T
If you get a larger rim, say 18" and than dropped the car 1" would that leave you at the stock height?
... Probably a dumb question but I was curious |
#14706 | |
My BMW came stock with 17" Wheels with 235/45 tires, I switched to 18" and now use 235/40 tires keeping the diameter close to original specs. Otherwise I would have to get my speed re calibrated for the new diameter as the wheels would need to make less rotation to achieve the same speed as the original wheels Also the rim difference from the center of the hub to the outer portion of the rim is actually 1/2 of the difference, since radius is half that of the diameter. In reality you are only increasing the car's height by 1/2" if you keep the original sidewall height... |
The Following 2 Users Say Thank You to Luis_GT For This Useful Post: | IntotheOcean (06-03-2013), M-17 (06-03-2013) |
#14707 |
Drives: 2020 BRZ tS #54
Ahhhh ex gf trying to get a hold of me
#14708 |
#14709 |
Drives: 2013 Whiteout FR-S
#14710 |
#14712 |
Drives: '06 AM V8V Coupe
Dude @Dimman, check this out:
http://liquidpiston.com/technology/how-it-works/ FAIRY TRIANGLES FLIPPED INSIDE OUT This is actually pretty clever, though I wonder how you'd cool the rotor so that the seals still work seeing how you have fresh air coming in right next to the exhaust, so the rotor would be expanding on one half only. Maybe Or maybe they just do the whole spring loaded thing again like on the Wankel engines. Also it probably loses a shitload of efficiency at low speed since it essentially has the piston equivalent of 180 degrees dwell at TDC, unless of course you're doing a compression ignition setup. Would be great for a motorcycle engine though, I'll have to get this custom machined someday if I get rich. |
#14713 |
Wayward Member
Drives: Hot Lava 86
I'm afraid to make a racecar part wishlist because I'm afraid of how much it will all cost...
#14714 |
Now w/ over 400 womprats!
Drives: BRZ LZR
MY PASSENGER SIDE WINDOW SWITCHES STOPPED WORKING!!!
That's Issue #1 really... I have heard the HPFP a few times but its not really an issue. Idle drop hasn't been a problem either... Lets hope this is the only problem...
- The Ancient BRZ Sacrament by Zaku |
h6 swapouts? any thoughts or advice? | f1ver | BRZ First-Gen (2012+) -- General Topics | 53 | 11-21-2014 11:46 PM |
Aspera's thoughts on AWD/RWD... | aspera | Scion FR-S / Toyota 86 GT86 General Forum | 89 | 11-16-2013 02:55 PM |
random casual discussion on dynamic brakes | serialk11r | Other Vehicles & General Automotive Discussions | 4 | 07-16-2012 09:34 PM |
The "if you wanna kiss the backside of white musicians make a thread about it" Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 12-19-2011 07:59 PM |
