#15 |
Drives: 2013 FRS Ultramarine
I'm going to get it professionally done. I was originally going to do it myself, but i've learned that due to CA laws, I cant order gallons of plasti dip from their website. There are a few shops in my area that I've received price quotes from in the 400-$500 range. I'm deciding on this matte green or matte white..matte black just seems a little boring. I have my rims dipped matte black, and it really is due for a re-dip..its just a lot harder to keep clean cause of the constant break dust (and my negligence for washing my car more than once a month). I think i will try and do a gloss black dip for my rims this time around. And apparently there is a break dust cleaner product that does wonders for plasti dipped rims..i'll look into that.
#16 |
AKA Mugen Dom
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
Still seems like a waste of $ in the long run
#17 | ||
Drives: frs
I used it on my rims before. Technically you are speculating that I'm speculating. And I also did it properly, it's a rubbery material so things will get stuck. The only difference may be that I have winter here.
My rims, like yours, had a build up of crap, don't notice from far but up close the color is a bit off. Bugs me, which is why I wouldn't do a whole car. Last edited by p4png; 06-03-2013 at 02:27 PM. |
#18 | |
Drives: slow
I only wanted to correct you in your statement that you can't properly wash plastidip, because its entirely false. There has been plenty of people dipping their whole cars with excellent results. As with any paint, it's the prep work and application that makes the biggest difference. In the end though, even IF it only lasted a few months... that's the entire point of a product like plasti-dip. It's designed to be temporary and cheap to apply. |
#19 |
AKA Mugen Dom
Anything from a spray CAN (not shot from a gun) is going to have blemishes on a large surface...you can have plastidip shot from a gun....google it. Its temporary like I said...its throwing money away. I guess if you have money to waste thats cool, but for $500 Id spend it elsewhere.
#20 | |
Drives: frs
#21 |
Drives: '13 Firestorm FRS
I recently saw a FRS that had been plastidipped flat black. It was kind of uneven and definitely didn't look as good as flat black wrap. Also, it was really rough to the touch and was textured like sandpaper.
#22 |
A Very Annoying Person
Drives: Subaru Impreza :( Hopefully BRZ
Just dip it. Get some glossifier if you don't want it a completely matte color. I think they look great and when I get mine, I'm planning to do a few coats of matte clear with glossifier all the way around. Give it a bit shinier than satin look.
#24 |
AKA Mugen Dom
Like I said, using a spraycan over a large surface is going to look like you used a spray can but if you spend like $130 on the sprayer and buy it by the gallon you can make it look legit...or have it done by someone with a gun.
#25 |
Driver of FR-S 1467
Drives: 2013 scion frs 001467
I used plastic dip on dash trim. It does what it promises but I vinyl wrapped it afterwards for 2 reasons. A little difficult to get good coverage without it turning uneven. And the bigger reason is how it felt to the touch. Didn't like the rubber feeling. But again, I think dip is a fine product that delivers but i still prefer wrap
| The Following User Says Thank You to mrlewistan For This Useful Post: | bcmakesiteasy (06-03-2013) |
#26 |
Drives: 2010 WW Lancer ES
As someone who has used Plasti-Dip extensively, I feel I should put some of your negative uneducated feelings toward this product to rest. Plasti-Dip has about 3 stages of curing depending on the thickness. The first two weeks (give or take a few days) is stage 1 this is where the dip is most vulnerable, it will feel like rubber and might have a rough texture. Stage 2 is is next this is when the dip feels somewhat "hard" (its not easy to dig your finger nail into) it will look smoother than before and have a rubbery plastic feel. Stage 3 I have found comes around 2 months after the dip has been in the sun. It will feel like vynl and have a very smooth texture (if originally applied properly) this is how the dip will remain until more dip is added. The finished product (if sprayed through a gun) looks almost identical to vynl wrap and the texture is very very smooth. Plasti Dip does absolutely no damage to paint or clear coat. As long as your paint area is prepped properly nothing is going to stick or bind to the dip... EVER. This is a fantastic non-permanent and cheap solution to change the look of a vehicle the owners personal taste. If you have some stupid idea in your head that Plasti Dip is bad then don't click on the thread in the first place!
Hope this clears some of the confusion in this thread up. So many people uneducated about plasti dip.. just posting random negative comments... SMH |
| The Following 4 Users Say Thank You to SethR For This Useful Post: |
#27 | |
| The Following 2 Users Say Thank You to SethR For This Useful Post: | mrlewistan (06-03-2013), NorseLegend (06-04-2013) |
#28 |
Driver of FR-S 1467
Another positive thing on dip is it is repairable. Fonzzy on dip your car on YouTube showed you how. Just need a little paint thinner and a coat or two of fresp paint on and around the repaired dip. That's definatly a plus over vinyl especially on the bumper
| Neon Green | meeskee2 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 05-15-2013 07:56 PM |
| Digital camo vinyl | Lee358 | Cosmetic Modification (Interior/Exterior/Lighting) | 23 | 04-24-2013 06:53 PM |
| Would FB Green or Red fit any existing kit? | HighLife | Forced Induction | 17 | 01-04-2013 05:18 PM |
| FT-86 De-Camo Photoshop (plus Aasbo livery) | Rampant | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 185 | 03-21-2012 07:00 AM |
| New info!! I saw production photos no camo | nickatdunning | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 07-28-2011 02:44 PM |
