Old 05-05-2013, 06:40 PM   #155
lancie
lancie's Avatar
Drives: brz wrb
Remove rear bumper
lancie is offline   Reply With Quote
Old 06-01-2013, 05:19 AM   #156
Avo1789
Avo1789's Avatar
Drives: Ultramarine FR-S
A strip down for the whole interior would be awesome! I'm looking to sound deadening the FRS but a guide to stripping the interior would be key...
Plus any other interior mods would be a lot easier to tackle.
Avo1789 is offline   Reply With Quote
Old 06-01-2013, 11:00 AM   #157
#87
I usually post drunk
#87's Avatar
PLEASE
DIY for sub and amp install with stock headunit.
#87 is offline   Reply With Quote
Old 06-02-2013, 07:33 AM   #158
AG3NT_5CARFAC3
86 Owners of New England
AG3NT_5CARFAC3's Avatar
Drives: Toyota GT86
REQUESTING DIY for illuminated door stills
(BRZ has them/FRS doesnt)
(Open the Drivers side FRS door and the bottom left there is a reflector; would be nice to have to be LED powered)
AG3NT_5CARFAC3 is offline   Reply With Quote
Old 06-03-2013, 11:55 AM   #159
stanm
stanm's Avatar
Drives: 2013 Asphalt FR-S 6MT
Request a way to not use air con when on windshield vent setting (a/c light is off but I can hear compressor running)
stanm is offline   Reply With Quote
Old 06-13-2013, 11:31 AM   #160
FRS_Sovereign
Manual Noob
Drives: 2013 Scion FR-S MT Asphalt
DIY for installation of Halo DRL's (FR-S)
FRS_Sovereign is offline   Reply With Quote
Old 06-13-2013, 12:19 PM   #161
qoncept
qoncept's Avatar
Originally Posted by lancie View Post
Remove rear bumper
I don't have any pics but I describe it in my trailer hitch DIY. It's not too hard. There are also some meh pics in the FSM floating around.
http://www.ft86club.com/forums/showthread.php?t=38706
qoncept is offline   Reply With Quote
Old 06-20-2013, 02:12 PM   #162
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
LED INterior Lighting to go on when the doors open and stay on when you want it to!
Minovsky is offline   Reply With Quote
Old 07-11-2013, 03:42 PM   #163
dpgdave
I can't find a diy on front seat removal/bucket seat install. I recall a DIY post for the front driver seat but not the passenger (though I can't even find that anymore).
I'm trying to get my seat belt light/chime & airbag light off. The front seat was an easy swap but the passenger has the weight sensor to bypass...
Can someone point me in the right direction?
Many thanks,
Last edited by dpgdave; 07-12-2013 at 10:43 AM. Reason: left off the airbag light**
dpgdave is offline   Reply With Quote
Old 07-13-2013, 09:47 PM   #164
ts87
My car got hit and im looking for a DIY for the front fender removal, thanks for any help
ts87 is offline   Reply With Quote
Old 08-01-2013, 06:01 PM   #165
Alliedforces86
Flat 4 Handyman
Alliedforces86's Avatar
Drives: Firestone Red FR-S & WRB MY2002 WRX
The compressor will run because the "windshield vent setting" is really your front defroster. The compressor runs because its removing humidity from the cabin so the windows don't fog up..
Alliedforces86 is offline   Reply With Quote
Old 08-01-2013, 06:03 PM   #166
Alliedforces86
Flat 4 Handyman
Remove the fender liner, the front bumper, then just undo the bolts holding the fender on. There's 2 bolts under the door jam that are annoying, but other than that once you have the fender wheel well liner and front bumper off, there's just some 10mm bolts keeping you from victory.
2 bolts on the underside of the fender at the jack point.
2 bolts in the door jam, need to have the door open half way or so and squeeze you way to the bolt heads.
The bolts in the engine bay, easiest to get to.
A couple by the headlight.
You have to pop some plastic trim pieces off around the windshield to unveil a bolt and clip under the plastic.
From what I remember that about it..
Old 08-07-2013, 04:16 PM   #167
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
DIY to replace Spark Plugs
Old 08-10-2013, 05:27 AM   #168
wes1202
Drives: 86
diy for grounding wires install
wes1202 is offline   Reply With Quote
Going to Hermosa Beach this Saturday...Any requests? dookie11 BRZ First-Gen (2012+) — General Topics 97 03-16-2012 05:13 PM
Last second photo requests for TMS debuts? Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 40 11-30-2011 02:13 PM
Speedhunters article KyShro Scion FR-S / Toyota 86 GT86 General Forum 22 09-23-2010 05:09 AM
