Old 06-02-2013, 08:54 PM   #701
Verge
Verge's Avatar
Drives: 2013 Scion FRS
pm me when the kit is ready for sale (take ma money) also carb approved? may need to live in cali in the future.
Verge is offline   Reply With Quote
Old 06-02-2013, 09:05 PM   #702
Carwhisperer
Drives: A lot of supercars.
Originally Posted by Darryljr11 View Post
Welp unless I can order by June 21st and see performance info/stats im gonna get the vortech kit
It'll be worth the wait, even if its this time next year. Or the year after that. Which I'm absolutely fine with R&D taking that long if it means its going to be that more reliable once its released to the public.
Carwhisperer is offline   Reply With Quote
Old 06-02-2013, 11:29 PM   #703
robispec
Drives: Black frs project
Originally Posted by Carwhisperer View Post
Considering flying out within a month and coming to hear and take a ride in person. I'm on the east coast, I don't see anyone on my side of the states who's got one yet.
Come on out
I'll give you a ride!
robispec is offline   Reply With Quote
Old 06-03-2013, 02:45 AM   #704
Yruyur
Yruyur's Avatar
Not sure if anyone else posted it but I see innovate has a new video on youtube. Nothing great but shows its running and its still being worked on. Looks like its current setup has a 75mm pulley. Sounds good.
[ame="https://www.youtube.com/watch?v=Xlq3XspyBH0&feature=youtube_gdata_player"]Innovate Motorsports: FR-S Non-Intercooled 75mm Pulley - Under hood road test - YouTube[/ame]
Sent from my GT-P3113
Old 06-03-2013, 07:40 AM   #705
cmss2000
Drives: 2013 BRZ Premium 2012 Acura TSX
See post #621
cmss2000 is offline   Reply With Quote
Old 06-03-2013, 10:04 AM   #706
kilrb
Drives: '13 Black BRZ
Edit: Don't want to pull the discussion off-topic.
kilrb is offline   Reply With Quote
Old 06-03-2013, 11:31 AM   #707
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by carbonBLUE View Post
this is dependent
1 ... so you essentially ride the tq hump. if you shift at pk tq and you have rpms to go you will land further away from peak tq in the next gear.
3 ...you should shift later because of work over time.
4 tq is different in every gear, the amount of tq going to the wheels is going to be greater at the top of second gear than at peak tq in third gear even if the tq falls off 20 - 30 ft-lbs. thats just how power is translated to the ground through the transmission
Originally Posted by Mitch View Post
You want to shift at the point where either:
1. Torque has dropped off to the point that the torque at the current engine speed multiplied by the current gear ratio drops below the torque at the engine speed you would be at if you shifted multiplied by the (lower) gear ratio
That is, let's say we have Torque (T) and gear ratio (R) and we're shifting from 2nd to 3rd. When T2*R2=T3*R3, shift. If you shift too soon, you're giving up mechanical advantage of being in the lower gear (higher ratio).
2. You hit the rev limiter and must shift to continue to accelerate.
I have been wanting to mention all of those things especially the effect of gear ratio.
Back on topic.... Any news on a firm release date yet? And If we are on E85 will be be able to buy the larger pully and a base map with the stg1 kit?????
Old 06-03-2013, 11:53 AM   #708
TemeCal
Drives: 86
FYI...larger pulley actually reduces the boost. I assume you want a smaller pulley?
TemeCal is offline   Reply With Quote
Old 06-03-2013, 11:55 AM   #709
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Back on topic.... Any news on a firm release date yet? And If we are on E85 will be be able to buy the larger pulley and a base map with the stg1 kit?????
Not quite yet. There will only be a canned tune from us for 91 octane fuel. Various 3rd party tuners will be able to supply other options, so you will be able to have any tuner you are comfortable with build you whatever you would like.
mines13 is offline   Reply With Quote
Old 06-03-2013, 12:40 PM   #710
mad_sb
I do my own tuning via BRZedit. Just wanted to see if there was a baseline tune I could run on to get to the dyno to get a starting point / baseline pull.
Old 06-03-2013, 12:53 PM   #711
mad_sb
Derp, yes But may end up having to start with the smaller pulley / lower boost setup since it will be maf based tune... and it seems i'll be creating my own basemap, that or i can go ahead and swap to a larger maf housing / rescaled maf before hand.
Old 06-03-2013, 12:54 PM   #712
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
I was wondering if someone could release a similar graph once the supercharger isnt under non disclosures
@GotM think you might be able to chime in?
i think the AT guys can get away with keeping current gear ratios with a power bump but the MT will benefit from a FD change
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 06-03-2013, 11:08 PM   #713
Carwhisperer
Sure its posted further back in here, but just personally found this. Nice Robi. [ame="http://www.youtube.com/watch?v=6nNbpGUXrv0"]Robispec meets Innovate Twin Screw 2 - YouTube[/ame]
Old 06-03-2013, 11:46 PM   #714
Fast_Freddy
Drives: Passat
Do you know what the limit of the oem MAF setup is? The MAS looks very similar to the Denso unit used on my 08 XB and that was good for +120bhp. MAS voltage maxed at 3.9V stock and 4.5V at 6psi. IIRC that was about 240 g/s? I can check some data logs to be sure.
Just curious how far I can go on the MAF before resorting to less accurate speed density.
Fast_Freddy is offline   Reply With Quote
Bullet/Sprintex/Innovate on the bullet website JoeBoxer Forced Induction 333 04-18-2013 10:07 AM
Still searching for an FR-S? 2 available in Little Rock Moshpit37 Southwest 9 01-02-2013 10:32 AM
Bullet SC 86 Loki556 AUSTRALIA 9 08-08-2012 01:39 AM
Searching Inventory in the SE Erroneous Southeast 40 07-23-2012 04:40 PM
