Old 05-31-2013, 02:00 PM   #169
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by vtmike View Post
What is annoying is it seems to be enough of a problem to change the transient retard settings in the factory rom on all recently manufactured cars.
I should be able to walk into a dealer and get the most current rom flashed to my car when ever if it's not up to date. Instead they seem to have the mentality to let something break first even though there is something very simple that can be applied to prevent the problem.
Completely agree, this frustrates the hell outta me. :mad:
Old 05-31-2013, 02:00 PM   #170
vtmike
vtmike's Avatar
Drives: Scion FR-S
Originally Posted by Opie View Post
Number of claims with P/N: 16607JB000 (Direct Injector Insulator) = 0
Number of claims with P/N: 16608JB000 (Direct Injector Seal) = 0
Source: Subaru of America
There have been quite a few people on here with the issue.
vtmike is offline   Reply With Quote
Old 05-31-2013, 02:02 PM   #171
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I don't know the original poster, or how he may or may not have "used" his car and don't have any information on his case.
I do know that Subaru repair's many things as warranty that are found to be "defects" on their vehicle's regardless of use (just like Honda) and they repair even more things that NOT due to a defect as customer goodwill gestures.
I also know if Subaru is flat-out denying this claim, they have already found something that is clearly not warrantable. They don't make denials without having a pretty good reason to do so, and they just don't go around posting what they have found on internet forums.
I know how CSG used the car and know locals who have seen him use it. That usage has never been described as harsh or abusive. LD and myself both have cars that get work done by Mastro obviously and both are used the same way the CSG car is. Both of us have used timing equipment for self-improvement. Neither of our cars are raced or abused, just used within reasonable limits with excessive maintenance being done on them to help ensure nothing fails due to the usage the cars see. CSG/Mike's case is no different from that perspective. I know how Mike maintains his personal S2K and if the CSG BRZ is anywhere close then I know this isn't a maintenance related issue. It hasn't been raced by most technical definitions. The failure is currently "unknown" but there's metal in the engine. Why? Oil pump failure? Lack of oil? ran lean and popped a piston like some Scions on here (which were repaired under warranty BTW)?
Unfortunately what seems to be missing is what SOA actually found. Metal can be from a lot of things as you know, could be from a failure or from abuse. They appear (based on the SOA emails) to have stopped at that point. If there's an oiling issue (and I went to a higher weight oil because I detected low oil pressures in my own BRZ) how is that CSG's fault?
My point is still that I don't believe SOA has any evidence to show this failure was caused by abuse and they are not authorizing any further investigation into the matter based on the emails we've seen. If there were obvious signs of abuse I'd be right there with you on this discussion, but I don't see any of those signs here. :shrug:
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
DAMotorsports (06-18-2013)
Old 05-31-2013, 02:10 PM   #172
SkullWorks
Drives: SSM LT MT BRZ
...ok and this proves what? That you don't understand the topic at hand WHATSOEVER and should quit trolling people looking for intelligent conversation about an issue they are having?, I can find (and you have already been offered) photographic proof of no less that 2 complete failures (related directly to the seal failing)
Now the funny thing is no one is blaming the seal, I don't know if you are dense or playing ignorant but the issue (as acknowledged by toyota who sells the exact same powertrain in a very similar vehicle made on the same assembly line) has been defined in a TSB and seems to relate far more to a bad engine control strategy concerning rate of acceleration and related timing values immediately following an upshift at or near redline.
I have an Audi DI, a Nissan DI, and a Chevy DI, sitting on my desk that have the same seal in the same location and the same apparent tolerances, (yes I fully dimensionalized them) none of the other users of this design DI have had failures of the seal while on factory ECU.
Please simply remove yourself from discussions you don't get, your trolling is reducing what credibility you may have previously established.
Old 05-31-2013, 02:15 PM   #173
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Here is the paperwork that i got from the dealer stating an injector seal malfunction caused cylinder #2 to fail. BTW my car had 4000 miles when the engine failed.
[IMG]http://i23.photobucket.com/albums/b395/nismo350z/Scion%20FRS/250396D5-7246-48AD-89FB-***E27D2B313-1032-00000132D6BCC474_zps686e4a0a.png[/IMG]
A message to Toyota and Subaru: If you really want this car to succeed in being the next S2K or Miata you should focus on keeping your customers loyal and making sure the car is fit to handle spirited driving and HPDE'S. I have never in my life seen mazda denying warranty on a MX5 for tracking (I have seen 2 engine failures in person and they covered it.). Even though 98% of your customers buy it as a daily driver and the cars will probably never see a race track they focus on the people who are tracking since it shows what the car is really made up of and how much it can handle, remember 10-30 thousand miles on a race track = around 80-100k miles of a regular car. If 98% of your customers see that the cars are having problems while being tracked and you guys are denying warranties you are scaring them off. Its a great little car, dont ruin it by denying warranties and denying issues that are really happening with the car.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
The Following 11 Users Say Thank You to track_warrior For This Useful Post:
ATL BRZ (05-31-2013), CSG Mike (05-31-2013), Dave-ROR (05-31-2013), Enraged21 (06-02-2013), kludger (06-03-2013), Lonewolf (05-31-2013), Noli (05-31-2013), pmccut (06-18-2013), robispec (06-01-2013), Spartan65 (06-11-2013), WolfpackS2k (08-20-2013)
Old 05-31-2013, 02:17 PM   #174
CSG Mike
CSG Mike's Avatar
Definitely borken.
SkullWorks (05-31-2013), SubieNate (05-31-2013)
Old 05-31-2013, 02:31 PM   #175
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Trolling? Funny...so because I refuse to jump on your side of the discussion I'm a troll.
The DI seals have been faulted by many a poster in this thread, that's why I looked up their failure rates.
I do understand the topic at hand, member had an engine failure and everyone else here seems to have figured out what caused it via the magic of the internet. Because none of them have diagnosed the car themselves.
Lot's of fear mongering and mis-information all over this thread.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 05-31-2013, 02:34 PM   #176
Opie
Opie's Avatar
And I would believe they do have evidence, they just don't go posting it. As I said, they wouldn't risk the legal, financial and bad publicity risk of denying a claim otherwise.
Old 05-31-2013, 02:36 PM   #177
CSG Mike
CSG Mike's Avatar
I'd like to point out that our FIRST engine had a DI seal failure. It did not completely fail, but we did agree to cover the diagnostic cost (which ultimately was not charged) to figure out what was wrong. A master tech at Irvine was taken out for a ride, and immediately told the driver to take the car back to the dealer as soon as they pulled out, because the misfire was replicated.
I can have someone dig up our original repair order if necessary, but consider this a 100% confirmed case of a DI seal failure.
I'd also like to point out that Irvine Subaru has been nothing but fair to us, and has graciously provided us with a loan vehicle for the ENTIRE time the BRZ has been there (it still is, and we still have the loaner as of this post).
Old 05-31-2013, 02:36 PM   #178
SkullWorks
Im sorry but despite your self confidence you DO NOT understand. Nevermind I'm tired of trying to teach a brick to read, I know you aren't as stupid as you are currently pretending so I'm gonna quit troll feeding.
@CSG Mike
Have you considered forwarding this thread or the Photos TrackWarrior provided to Subaru, the dealer and SOA both?
Old 05-31-2013, 02:38 PM   #179
CSG Mike
CSG Mike's Avatar
We're still actively working with the dealer, but ultimately their hands are tied by SoA.
Old 05-31-2013, 02:49 PM   #180
Opie
Opie's Avatar
CSG Mike - Did they (Irvine) actually tear down the first engine? Or did SOA give them a long block to swap out so they (SOA) could tear it down & diagnose it themselves?
Old 05-31-2013, 02:55 PM   #181
Lonewolf
Lonewolf's Avatar
Drives: Moped
With the large majority of the misinformation provided by you...
Old 05-31-2013, 02:57 PM   #182
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
That's funny, since the DI seals were reported as the cause of the first motor issue in the CSG car, as well as a number of other people on here who have documented service involving the seals.
Me thinks your database may not be 100% up to date, and probably also doesn't interface with Scion's.
SubieNate is offline   Reply With Quote
We Ask Toyota & Subaru about James May's Claim that Toyota Gets 90% of GT 86/FR-S/BRZ vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 94 09-15-2013 08:55 PM
Denied service... Chen Northwest 37 09-13-2013 08:37 PM
HELP with diminished value claim! zohare Scion FR-S / Toyota 86 GT86 General Forum 41 04-03-2013 11:17 AM
Hit and Run Insurance Claim CharlieChaos Off-Topic Lounge [WARNING: NO POLITICS] 9 12-26-2012 08:54 PM
Japan loses its claim to "Creepiest Asian Country" reni Off-Topic Lounge [WARNING: NO POLITICS] 3 05-07-2012 11:57 PM
