go_a_way1
Old 05-31-2013, 12:33 AM   #1457
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
Originally Posted by 2point0 View Post
I didn't reply due to not knowing for sure. But...TiC has 9.5 +30 all around on their car, maybe see what they say. 4mm isn't much, but it could be the difference between rubbing and not rubbing.
Do you have a link for that thread? Coz i saw a thread with guys mounting 9.5 +30 all over, but the thread is pretty much dead.
JackSmiley is offline   Reply With Quote
Old 05-31-2013, 12:46 AM   #1458
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
I don't really keep track of links. Just search for threads started by Turn in Concepts. Now that I'm thinking...it might have been at nasioc.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
JackSmiley (05-31-2013)
Old 05-31-2013, 01:01 AM   #1459
2point0
2point0's Avatar
@JackSmiley ... Browsing just now, I saw this thread: http://www.ft86club.com/forums/showthread.php?t=23079
Looks like he's on 18x9.5 +38 (with coilovers). Looks damn good.
Old 05-31-2013, 02:37 PM   #1460
jshadeck
jshadeck's Avatar
I have 18x9.5 +38 on stock suspension, with the poke (and +30 would poke 8mm more) id have to run alot of camber ("alot" is my opinion not a measurement) to lower the car much w out rubbing. Also in my case i would be weary of front camber as my rim clears my spring perch by mm's, and camber would bring my rim and tire closer to the perch and spring.
Again tho, i am speaking relative to the stock perch and spring, and i am 8mm inward compared to a +30.
jshadeck is offline   Reply With Quote
Old 06-01-2013, 04:45 PM   #1461
drift94
Drives: 2013 scion frs whiteout
17x8.25 +25 on 235/40/17
front and
18.8.75 +20 on 235/40/18
in the rear.
plan on lowering it on stance coils about an inch.
will they fit? any pics? how aggressive?
drift94 is offline   Reply With Quote
Old 06-02-2013, 12:43 AM   #1462
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Question about offset, i plan on getting the rocket bunny kit next year, what would be the rec offset for the kit? My wheels of choice are 17*9 +35 fpf1 or BBS RS, since the RS are 3 piece i believe I can get them redone with a lower offset?
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 06-02-2013, 12:46 AM   #1463
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
You'd have to go way wider and way lower with offset... Like 10.5 -0 is a good start
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 06-02-2013, 12:48 AM   #1464
WolfsFang
Scrape Master
WolfsFang's Avatar
Do you know if i would be able to redo the BBS RS for a wider and lower offset? Lastly is running spacers to extreme for a low offset?
Old 06-02-2013, 02:24 AM   #1465
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
You could re-barrel them. It's pretty costly, I had a set of wheels done and it was close to $600 a wheel + shipping both ways.
As for running a massive spacer to make up for the narrow sizing/high offset, I'd advise against it. The further you push the wheel out without added width the more stress you're going to put on your wheel bearings. At this point I'm clueless to how strong brz/frs spacers are, but I know Subaru doesn't have a great rep when it comes hub/wheel bearing strength.
Omar GC
Instagram: 2jzus
The Following User Says Thank You to OmarGC For This Useful Post:
WolfsFang (06-02-2013)
Old 06-02-2013, 02:28 AM   #1466
WolfsFang
Scrape Master
WolfsFang's Avatar
Thanks for the help, looks like im going BBS RS and will rebarrel them when needed.
Old 06-02-2013, 10:35 AM   #1467
Steve
Steve's Avatar
Drives: 6MT
18x9 +42 in the front, stock suspension, any inner clearance issues?
Steve is offline   Reply With Quote
Old 06-02-2013, 10:55 AM   #1468
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Too close to the spring perch. You may "just" clear the suspension (3-5mm at most) but as soon as you drop it or add camber it will hit.
The ideal offset for this wheel is +38.
Slick is offline   Reply With Quote
Old 06-03-2013, 09:26 PM   #1469
sybrite
Drives: 2013 Subaru BRZ
Will 225/40R18 fit 18X8 +48? Tire rack recommends 235/35-18. I've seen quite a few people using 225/40R18.
(http://www.tirerack.com/wheels/Wheel...All&sort=Brand)
sybrite is offline   Reply With Quote
Old 06-03-2013, 09:42 PM   #1470
Slick
Slick's Avatar
Sure will, 225/40R18 is a good fit for 18x8. Pretty much perfect diameter too. The 235/35R18 is a pretty rare tire size anyways.
The Following User Says Thank You to Slick For This Useful Post:
sybrite (06-03-2013)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
