Drives: '12 C63 P31, '23 GRC
Inaccurate outside temperature display
I've become quite frustrated with this reading. I've noticed two things about the exterior temperature display:
-it takes forever to level out after being somewhere hot (like in a garage or parked in the sun) -it never displays the correct temperature. It always reads 5-7 degrees too high. Has anyone else had problems like this? I'm wondering if my temperature sensor needs to be recalibrated/replaced or is the sensor just located in a really crappy location where its readings are corrupted by artificial heat sources. Any info on this would be appreciated. (I did a topic search but nothing came up).
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
#2 |
From my experience this is pretty typical with all cars. I'm not sure where they mount the sensor but it seems to get very hot sitting.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
| The Following User Says Thank You to swift996 For This Useful Post: | samisons (06-20-2014) |
#3 |
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
I've had that featue in my last 4 or 5 cars and none of them have been very accurate. Consequently I don't pay that much attention to it.
#4 |
I don't have an issue with it being way too hot from sitting. I do have an issue with it being 5-7 degrees off 30 minutes later (and staying that inaccurate). My last car's outside temperature sensor had no such problems.
| The Following User Says Thank You to WolfpackS2k For This Useful Post: | Prog (06-17-2014) |
#5 |
head of infinite swagger
Drives: 2013 FR-S 6MT
i agree i also find the reading to be WAY off sometimes, like reading 30+C when it's only 15C and not correcting for long periods after.
my old car used to be very accurate even after it was sitting in the sun.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater 2000 Silverstone M5 6MT - SOLD 2013 Ultramarine FR-S 6MT - Car Journal - SOLD 2004 AlpineWhite M3 6MT - SOLD |
#6 |
In the summer time I suppose it's just something "handy" to know, and in this day and age checking a more accurate temperature on your smartphone is just a click away.
However in the winter time it can be quite important to know what the local "on the ground" temperature is if you are concerned about freezing road conditions. By all accounts this car's temp sensor will fail at that miserably.
#7 |
I usually post drunk
What difference does it make?
Do you keep your wardrobe in your trunk and it makes your testicles freeze off if the temp is not accurate with 5 degrees? IMO it's a worthless "feature" to add to a list. Much like clicks on a cheap coilover... |
#8 |
What difference does it make? It's a feature on the car that doesn't work properly.
Thus I don't see the harm in posting on here to see if it's a common occurrence or not. You'll have to excuse me for wanting everything on my brand new car to function properly.
#9 |
Drives: 2013 FR-S whiteout
OMG LEMON LAW
#10 |
Drives: WRB BRZ
When you say the temperature reading on your car is 5-7 degrees too high, what are you comparing with? IF you're comparing with your local weather report, you need to keep in mind that temperature at where you are and where the weather station is could be different. When comparing the car's thermometer reading with another device's temperature reading, there will always be anomalies. Cars also produce quite a bit of heat, so no matter where they install the thermometer on the car, it'll always be reading the temp differently from the air a distance away.
I'm not saying that our car thermometer reading is 100% accurate, but i find the accuracy is within an acceptable range. Just like how our wrist watch or clocks at home is not going to be the same preciseness as the atomic clock in Colorado. Or that your car's speedometer does not indicate the same speed reading as a laser gun's reading. So basically what my point is, this shouldn't be something of a concern, it'll do the job
| The Following 4 Users Say Thank You to chenshuo For This Useful Post: |
#11 |
NASA SpecE30 Racer
The sensor is mounted just in front of the radiator on the passenger side. I have found that mine is always very accurate once I get it some air flow at speed for a couple of minutes, and I have a big intercooler in the way. There is no way it is 5 to 7 degrees off in my car.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#12 | |
^that leads me to believe this is something wrong and should be looked at by the dealership. After a 30 minute drive of 75% highway driving my temp sensor is still off a lot (this being my daily commute to/from work). Thanks for your input.
#13 |
as an example I just got home from driving around for 45 min, prob averaged around 35 mph. Temp gauge currently says 92. Meanwhile it's 84 outside. That's not even close.
#14 |
There's a temperature gauge somewhere on our car..?
| Fuel Gauge is Inaccurate | Surakusa | Issues | Warranty | Recalls / TSB | 13 | 09-02-2017 11:26 PM |
| Southeast Toyota FR-S recall for inaccurate load carrying capacity labeling | Dadhawk | Issues | Warranty | Recalls / TSB | 6 | 04-24-2013 12:19 PM |
| FS: AEM 30-4402 Oil/Transmission/Water Temperature Digital Display Gauge. | Sportsguy83 | Engine, Exhaust, Bolt-Ons | 4 | 03-25-2013 11:37 AM |
| BRZ temperature display malfunction | percyng | CANADA | 7 | 10-24-2012 10:31 PM |
| Optional Rear View with Homelink....does it display indoor temperature? | Fugazi | BRZ First-Gen (2012+) — General Topics | 1 | 06-30-2012 09:15 PM |
