#197 |
Drives: 2024 GR86/ 2015 FRS
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts Last edited by Simmons; 09-08-2013 at 11:45 AM. |
#198 |
Drives: GBS Limited 6MT
Do you lose any bump travel with the raceseng camber plates? They do look great.
#199 | |
Simmons
Sponsors Xero-Limit//Karcepts |
#200 |
We got the 12lb cat-back exhaust on the car.
Here is a video from Sunday, car was way to loose but at least you can hear the exhaust. [ame="http://youtu.be/IjT5XjnnU3M"]http://youtu.be/IjT5XjnnU3M[/ame] Simmons
#201 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
Very nice sound (driving too!). Im taking it this will be an expensive catback? I'd like one but funds are short for a bit. If they need a second test fitter.... :P
I may look into this though. When is the ETA?
#202 | |
Simmons
#203 |
#204 |
Señor Member
Drives: 2013 Raven, Drifty things
That looks really cool! Hopefully they use a bigger tip though :/
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris '13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross. |
#205 |
Drives: FR-s
#206 | |
Simmons
#207 | |
Why did you choose to run this way? And are you intending to reduce the camber difference between front and rear? (I haven't read the entire thread so maybe this has already been explained.) (I think that too much camber in the front could also reduce braking performance.) |
#208 | |
Drives: On track
#209 | |
#210 |
^ Ok, thanks that explains it.
(Because of the 'way too loose' comment above, I thought one remedy could be less camber difference between front and rear.) |
| My BRZ ST* Autocross build | Scooby South | Tracking / Autocross / HPDE / Drifting | 848 | 08-14-2018 11:20 AM |
| Nasa High Speed Autocross @ VMP 4/21/2013 Sponsored by Ptuning | Events@Ptuning | Mid-Atlantic | 200 | 07-23-2013 11:39 AM |
| Engine Speed vs Vehicle Speed for 6MT | DetroitJake | Engine, Exhaust, Transmission | 22 | 04-27-2013 06:56 PM |
| Nasa High Speed Autocross @ VMP 4/21/2013 Sponsored by Ptuning | Events@Ptuning | Southeast | 5 | 04-22-2013 11:17 AM |
| Edge Motorworks BRZ Autocross Build, March 3rd Mountain View! | race2win | Northern California | 24 | 03-14-2013 10:05 AM |
