Old 05-29-2013, 09:56 PM   #29
OrbitalEllipses
Drives: Attitude
Originally Posted by Shit Luck View Post
i have not seen that confirmed. i know aftermarket is 60 degree. i havent found anything confirming that the twins are infact 60 degree from the factory.
ALL [modern] Subarus are 60 degree cone tapered from the factory. Go use your stock lug nuts and seat them onto a wheel as a test if you don't believe me, or vice versa. The AREA of the seat on the stock nuts is significantly smaller, but that's about it.
Old 05-29-2013, 10:00 PM   #30
Shit Luck
Drives: red frs
i looked at a stock nut but i dont have anything to compare it too with out pulling one off the car.
I was told when I bought my wheels to get lug nuts aswell because they were unsure of the stock seat type. i have since searched and all i could find was people saying subaru is 60 degree. no body saying the twins were actually 60 degree.
Shit Luck is offline   Reply With Quote
Old 05-29-2013, 10:20 PM   #31
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
...all i could find was people saying subaru is 60 degree. no body saying the twins were actually 60 degree.
The lug nuts style and thread pitch on these cars are all Subaru. The stock lug nuts are identical to the leftovers from my last two Subies. I have no idea why I ended up with so many stock lug nuts...
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 05-29-2013, 10:22 PM   #32
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
mine were a 12mm stud... 14mm on the hub side and 12mm on the wheel side.
in fact i have a set waiting to go on my rabbit track car when the cage is done so i can run aftermarket wheels. i would take a pic but they are a long way from home at the shop.
link to a set on ebay.
http://www.ebay.com/itm/14x1-5-TO-12...p2047675.l2557
Good point... most of the stud conversions I dealt with before in the past were straight 14/14mm studs, since they run wheels meant for German cars and didn't deal with wheels drilled for 12mm.
Either way, the most important thing for this thread is:
- Plenty of wheels available
- FRS/BRZ is niche market car, and wheel companies will eventually come out with newer designs, demand-permitting
- Beware of online fitment guides, not everything is accurate and/or easily swapped around.
-alex
Old 05-29-2013, 10:28 PM   #33
mav1178
mav1178's Avatar
60mm tapered means you can run any lug with a 60 degrees seat (95%+ of all lug nuts for cars on the market)... Really, the only issue lies with the openings for lug nuts on the wheel.
Some wheels must use a skinny tuner-type lug nut with an internal hex socket, others are skinny lugs that use 17mm sockets. But in reality there's only about 3 major types of lug seats:
- acorn/tapered (usually 60 degrees)
- mag seat w/ washer
- ball seat
This is a good summary:
-alex
Old 05-29-2013, 10:30 PM   #34
Shit Luck
Drives: red frs
never had a subie before, a bunch of yotas and some mitsubishi's thats why i questioned it.
-alex
very true...
I still lurk the vw forums hoping score something weird in 5x100
Old 05-29-2013, 10:56 PM   #35
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
very true...
Also guilty of checking out the 5x100 section on the vortex.
Old 05-29-2013, 11:15 PM   #36
2point0
2point0's Avatar
very true...
Understandable. This car is a mix-match of parts anyway. But it sounds like the shop just wanted to sell you lug nuts, they should have known better.
I've seen lots of Scion TC folks selling wheels on the Subaru boards, might want to browse scionlife or whatever it's called for more options.
...all about lug nuts...
-alex
Huh? Did you quote me on accident? I stated that I know this.
And yeah, gotta watch out for the diameter of the lug nuts. I have a set of Drag DR-31s in the garage that have different sizes for the 5x100 and 5x114.3 holes. My Project Kics nuts fit fine for one bole pattern, but are too fat for the other. Had to use Gorilla spline drives. Splines are the best bet for clearance. Even some of Drag's lug nuts don't fit their own wheels, and not because of seat type, just diameter of the nut seat.
You also have to be able to get a socket around the nut (nut to wall of pocket clearance). This can be a pain if you have locking lug nuts with a special socket that may or may not fit.
Can we just stop talking about nuts? Makes me feel weird...
Old 05-30-2013, 06:38 AM   #37
Shit Luck
Drives: red frs
I went out and got lugs later actually.....
Any Car Rental companies have FR-S' in the US? BenArmstrong Scion FR-S / Toyota 86 GT86 General Forum 21 12-02-2016 01:36 AM
Can't figure out what noise this is...any takers? lostmessengers Issues | Warranty | Recalls / TSB 5 05-21-2013 11:45 PM
Go figure! Pdxc43 Northwest 3 01-26-2013 09:03 PM
BRZ vs WRX Skid Pad Figure 8 ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 1 05-29-2012 12:50 PM
