#127 |
Drives: Scion FRS
Hopefully this issue doesnt pop up once I throw the turbo on, hopefully the updated rom helps.
I do see this becoming a recall if the issue continues to happen even after the flash. |
#128 | |
Drives: Attitude
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | dabocx (05-29-2013) |
#129 | |||||||
http://www.media.subaru.com/newsrele...id=190&mid=127 Quote:
Is our car driven hard? Most certainly. Have we done anything to alter the parameters of the drivetrain? Absolutely not. We're using the car as designed, at least, according to their press materials. Last edited by CSG Mike; 05-30-2013 at 08:56 PM. |
| The Following 5 Users Say Thank You to CSG Mike For This Useful Post: | ATL BRZ (05-30-2013), cobrabyte (06-06-2013), dabocx (05-29-2013), SkullWorks (05-29-2013), Sportsguy83 (05-29-2013) |
#130 | |
| The Following 2 Users Say Thank You to 2forme For This Useful Post: | ATL BRZ (05-30-2013), SkullWorks (05-29-2013) |
#131 |
Drives: Attitude
Get it posted to Jalopnik; at the very least your engine would likely be warrantied after the bad press.
#132 |
I've really been hoping that it wouldn't come to a forum post... we've tried to reach an amicable solution with Subaru of America
| The Following User Says Thank You to CSG Mike For This Useful Post: | SkullWorks (05-29-2013) |
#133 |
#134 |
Drives: SSM LT MT BRZ
CSG Mike is a standup guy, he doesn't feel making a spectacle out of this will provide a great name for the twins we all know and love....It is likely that the pictures in the TSB we have all been seeing are pictures of his DI's from the first motor, which he also did not heavily publicize....he wants Subaru to make good on their promises, and is giving them the opportunity to do so...
....schmuck.... Lol |
| The Following User Says Thank You to SkullWorks For This Useful Post: | spitz (06-03-2013) |
#135 |
Drives: SWP Subaru BRZ Limited MT
So it's pretty clear that Toyota has acknowledged this issue with a TSB but do we have any word from Subaru?
Would the prevention fix for this just be as easy as calling a Subaru dealer and making an appointment to have the latest flash thrown on to the ECU? Better yet does Subaru even have a flash fix for this yet? Also does this only occur when you bounce it off the rev limiter or is it just with fast/aggressive shifting at very high RPM? (IE. Would shifting slower or with less aggressive throttle input at high RPM possibly prevent this?)
#136 |
It has been discussed that it is the high RPM shift followed by loading and unloading the throttle, as you would do when adjusting the angle of a car in a high-G corner on track. Or in alot of our cases a canyon road, or ...name your own fun here....
It seems the latest flash upload (per Epifan) from Japan, has extended some spark retard tables all the way past redline where it was previously only enabled/defined to about 5k rpm (maybe lower I forget) I have not had this issue at all in my car due to the choice of tuning solution, but my car is driven on track at and above factory redline. I'm hoping this lets us quit worrying about a material defect and consolidate this to a Factory Tuning Issue. |
| The Following 4 Users Say Thank You to SkullWorks For This Useful Post: |
#137 |
I Love custom Turbo kits
Drives: Limited BRZ
Thanks for explaining, I did not understand this correctly. I thought it was only fast shifting at redline.
#138 |
Drives: Scion FRS
I find it intresting how many issues are being solved with ecu updates. The idle dip/cel/ now the injector issues.
| The Following User Says Thank You to dabocx For This Useful Post: | tripjammer (05-30-2013) |
#139 | |
Drives: 2010 BMW M3, 2013 Subaru BRZ
And yes my powertrain is 100% stock except for HKS airfilter. |
#140 |
Drives: Moped
Reposted from another thread for your consideration:
***DISCLAIMER: This post is in no way, shape, or form legal advice or counsel. I figured a public discussion of some issues might be of some benefit to the members here. CSG~ 1) If the problem which ultimately caused your engine to seize is later found to be a design/manufacture defect or flaw, then your position is suddenly much stronger here (worth mentioning since Toyota has attempted to remedy certain issues with the FA20 via the latest tsb regarding engine software/calibration). The problem is proving the cause (Magnusson-Moss comes into play here) of the engine seizure with respect to any intervening/superceding factors such as your "spirited driving." So was the cause of the engine failure your driving, the modified suspension and tire components, or the potential design/manufacture defect (factory tune, injector parts and functioning)? That is the major question here. 2) The fact that Subaru's press/marketing materials tout and encourage performance use of the BRZ (despite their somewhat contradictory warranty and user manual statements) is a potential avenue to be explored as well. In a sense, Subaru is marketing the product one way, and then refusing to honor a "reasonable" if not intended use of a sports coupe. 3) The fact that Subaru previously replaced your motor under warranty after similar driving conditions may come into play as well. Was this move an act of "good will" on behalf of Subaru, a waiver and acceptance of your spirited use of the vehicle, or was it an indirect concession that there are unresolved issues with the FA20? 4) As you said, another issue worth noting is that the drivetrain was stock. Now if you had an intake or aftermarket tune (which can cause a lean condition) then I can see Subaru's justification for denial of warranty coverage of the motor. In this case, the fact that the motor was stock (and I presume properly maintained) works in your favor. ***So what to do now...any combo of the three depending on your decision: 1) Seek counsel from an attorney who specializes in warranty/contract or automotive claims. Further investigation of the cause of the engine seizure will likely be necessary here and will involve considerable expense. 2) File a safety complaint with the NHTSA since having an engine seize during operation is a safety concern. 3) Spread word of this problem using the power of the internet (particularly Autoblog and Jalopnik). Last edited by Lonewolf; 05-29-2013 at 07:31 PM. |
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
| FRS-BRZ Port Fuel Injector (interesting) | Element Tuning | Engine, Exhaust, Transmission | 50 | 04-21-2016 04:26 PM |
| Need Help - 2 codes thrown | jpit | Issues | Warranty | Recalls / TSB | 3 | 04-20-2013 12:41 AM |
| Bulb codes | JDMenrique | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 02-17-2013 03:25 PM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 0 | 08-21-2012 05:03 PM |
