Old 05-27-2013, 12:11 PM   #15
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Ditto
TouchMyHonda is offline   Reply With Quote
Old 05-28-2013, 09:14 AM   #16
brillo
Drives: 2013 Firestorm FR-S
going to install the subframe bushings and tranny mounts and see what improvements I get. I don't want the car vibrating at idle, but I think some stiffer bushings will help especially when launching the car or cornering hard.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 05-28-2013, 09:28 AM   #17
Mikem53
Drives: FR-S 6MT
Depends on what you put a priority on with this car.. When you add stiffer mounts to tighten up the driveline.. You will be transferring NVH to the cabin..
Everything is a compromise.. It's setup to be liveable on an everyday basis.. If it were my dedicated track toy.. I would be addressing some of the slack in the system..
Mikem53 is offline   Reply With Quote
Old 05-29-2013, 08:00 AM   #18
Ingen
Drives: Ultramarine FR-S 6MT
Sometimes when I let the clutch out and get on the gas it'll fee like it sort of lurches or jerks and then accelerates. I get the same thing if I lift, it sort of feels like a little impact. IS that caused by the weak-sauce bushings and motor mounts?
What specifically should I change to fix that? This is my autocross toy but ALSO my daily driver, with 2 hours a day spent highway commuting. I need a happy medium here, if at all possible
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 05-29-2013, 08:55 AM   #19
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by moto-mike View Post
Huge issue on this car. You'll want the whiteline subframe and diff inserts to take care of it. Driving them back to back is like night and day. I thought there was some throttle response/delay issue with the ECU at first until I drove a properly tightened up car. Some videos online of the diff movement.
How difficult of an install are the subframe and diff inserts?
Old 05-29-2013, 09:50 AM   #20
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Easy. Sounds much much worse than it is. Just have two jacks if you don't have a lift, and impacts help. Make 100% sure the subframe/diff are lifted back up and in the right position before putting the bolts back in, and start easily by hand. Otherwise this is where people run into issues.
IMO it is much better now, but I think the motor mounts are the other 30%. That's next.
Xero-Limit is offline   Reply With Quote
Old 05-29-2013, 10:57 AM   #21
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
We made this video which shows how much movement is in the rear diff. This will be Stock vs. the Cusco rear diff mount.
[ame="http://youtu.be/10rspcW8uek"]http://youtu.be/10rspcW8uek[/ame]
Myles at @Racecomp Engineering also speaks highly of the Whiteline Rear Diff Inserts, and I would agree with him. I think anything you can do to take up the slop is going to make a big difference.
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 05-29-2013, 11:46 AM   #22
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
@phat 86 Installed my subframe and trans insert in less time than it took me to swap my header.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
drive train slop
Pulled battery for 5 minutes, now massive gas pedal slop post_break Issues | Warranty | Recalls / TSB 9 10-11-2012 01:12 AM
Aftermarket Drivetrain Parts wootwoot Engine, Exhaust, Transmission 0 07-26-2012 05:23 PM
Subframe/Drivetrain Thoughts.... TrackDog Scion FR-S / Toyota 86 GT86 General Forum 12 11-10-2011 10:53 PM
Drivetrain experts! Name this car! :) aspera Engine, Exhaust, Transmission 200 08-15-2010 11:41 PM
