Old 05-24-2013, 12:41 PM   #211
Sonolin
I drive at ~80mph regularly, which sits me at about 3500rpm+. So, I figure with this final drive, it should just encourage me to drive a little slower, lol.
Can't do this mod for a while but I'm planning on it
Sonolin is offline   Reply With Quote
Old 05-25-2013, 11:01 AM   #212
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Car is going in on tuesday for the install. Will update as soon as its finished.
Tye300 is offline   Reply With Quote
Old 05-28-2013, 02:50 AM   #213
Tye300
Tye300's Avatar
Update: Car is at the shop now. Differential is out and dissassembled as I am typing this. Install is a pretty straightforward affair. Only difficulty is pressing the bearing into the new pinion gear. Changing the ring gear is pretty easy, just reverse the dissasembly method. Will post pics later after the install.
Old 05-28-2013, 02:59 AM   #214
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Let us know what shims they use. I know all builds will be different. But I'm just curious. Thanks.
JimmyMac is offline   Reply With Quote
Old 05-28-2013, 03:29 AM   #215
twitism
Drives: Toyota 86/VW Golf GT
can't wait to see how it goes! do take a video too!
twitism is offline   Reply With Quote
Old 05-28-2013, 07:22 AM   #216
WatchmaN
WatchmaN's Avatar
Drives: the girls crazy
@Tye300 yeah please come back with more details about everything, I'm doing that mod very soon, just waiting @Silverdub to be ready. Did you keep the original bearing or bought new one? How did they put back the bearing on the new pinion? ect the more the better haha.
thanks
Vortech SC(314hp/226tq), Perrin pully, Tanabe strut tower bar, Perrin exhaust, LP Tune, hsd coilovers, DTC-60 fr, hp+rear),track rubber RS3 and Continental :-), Forester oem oil cooler,Custom brake cooling kit. Driveway lab rear diffuser, Wasp front spliter, TRD canard/fenders.
WatchmaN is offline   Reply With Quote
Old 05-28-2013, 02:01 PM   #217
Tye300
Tye300's Avatar
Well the install with pics and vids are on my build page. You can find it here:
http://www.ft86club.com/forums/showt...711#post964711
Originally Posted by Captain Insano View Post
Oh my goodness. You ROCK!! I can't wait to see the results since I'm very interested in doing this on an AT. Please keep us posted and if you do start another thread with results can you place a link in this thread so I don't miss it??
Thanks for posting!
Here to help a fellow AT owner.
I'm looking forward to hearing your impressions on this...
I used all the shims that came with the kit.
thanks
I kept the original bearing. We took the stock pinion gear to the machine shop and they took care of it.
Old 05-28-2013, 08:32 PM   #218
Captain Insano
Nice review. This mod is on my "to do" list now.
Captain Insano is offline   Reply With Quote
Old 05-28-2013, 08:58 PM   #219
xjohnx
Grip>Slip
xjohnx's Avatar
I thought the kit shipped with a full range of shims and you're only supposed to use the one that fits best?
Old 05-28-2013, 09:06 PM   #220
wootwoot
Drives: FRS
That is correct. Racecomp only used one shim I believe. Not sure how you determine the number necessary.... But apparently his diff is working.
Old 05-28-2013, 11:47 PM   #221
Tye300
Tye300's Avatar
I just all the new ones supplied with the kit. Did not use the old ones.
Originally Posted by zenkizero View Post
awesome car, look forward to more mods.
The revs seem to climb much faster than the stock auto I drove sometime back...nice mod and thanks for the update!
This is awesome. Thanks for posting the information.
If you could supply info on - in the auto and auto sport mode, do the differing/new rev/MPH settings due to the diff affect any behavior other than expected (quicker revs)? I was wondering about the OEM trans software working OK with a mod like this.
I was wondering the same thing. How do the oem sensors/programming make sense of the new ratios?
This and a CF driveshaft would be really Insano!
Your welcome bro.
Forgot to comment on that. I actually was expecting something to go wrong with the new ratios. Apparently not, the car seems to shift normally during normal AT mode. It just shifts at the same shift points if you just drive normally. The gear indicator seems fine and reads the correct gear, so the ecu doesn't seem to mind the new final drive. During SPORT mode, the revs climb out to redline like stock but is much faster because of the final drive, the same as the video in manual paddle shift mode.
Old 05-29-2013, 12:50 AM   #222
Lonewolf
Lonewolf's Avatar
Drives: Moped
The 4.55 rears paired with a cf driveshaft would probably make the car feel like driving a stick of well-balanced butter....
Old 05-29-2013, 01:20 AM   #223
Turdinator
Señor Member
Turdinator's Avatar
How did you determin if you had the correct endplay for the bearings?
1974 TA22 Celica
2013 86 GT
Old 05-29-2013, 08:23 AM   #224
Tye300
Tye300's Avatar
We took measurements of both ring gears. Both had 41 teeth, the stock one was a little bit thinner than the new one. The stock pinion gear had 10 teeth while the new one had 9. 41/9=4.556. The kit basically come with a pinion gear, ring gear, new screws and shims. We just used the new ones and it all bolted up fine. There was a hiccup with the pinion gear though. During the first reassembly, we used the new pinion sleeve that came with the kit, the pinion gear had a little play if you tug on it. We dissasembled the differential again and tried the old one. Apparently the two sleeves have different lenghts, we tried using the old one and there was no play anymore. Maybe we just got lucky with the bearing?
cusco final drive
PST Carbon Fiber Drive Shaft Installed msile Engine, Exhaust, Transmission 155 08-28-2018 07:53 PM
Mfactory Final Drive Ring and Pinion Crossover Auto Engine, Exhaust, Transmission 87 05-26-2017 02:21 AM
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 12:17 PM
Is my Cusco catch can correctly installed? wbradley Engine, Exhaust, Transmission 9 02-24-2014 09:49 PM
Has anyone actually seen any of the Cusco roll bar / roll cages installed? xenocharger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-03-2013 06:54 PM
