#43 | |
#44 |
Drives: Volkswagen GTI
It's high strung, anything you gain over 5000 rpm is going to make a huge difference. 5ft lb of torque is something like 20 hp at 7000+ rpm.
#45 |
Drives: Toyota
Come on. With "nothing" we'll get +10 PS. With Bolt-ons we'll get +20 PS and and with costly moddification we'll get +40 PS. If increased capacity is technically possible, we'll get at from +60 to + 80 PS. It is still not a Ferrari 458 Italia engine, so there is room for improvement, and even the Ferrari can get +20 PS just from ECU and exhaust modification.
#46 |
Drives: Clio TCE
You make it seems SO easy.
It isn't. NA engine with 100 hp/l are already close to the limits, the only way to make this engine push more than 220 hp is to get the rev limiter past 8k rpm, change the cams (4 of them-->costly!), a full exhaust etc |
#47 |
Drives: Miata Club
More like the exhaust after cat since the headers are already very well made. I think pics from engine on stand showed some sort of coating on the headers.
It'll be hard to increase the power on the engine without changing the engine rev and parts on the header and block. I doubt anyone can make a bigger number on the intake that's already tuned by Yamaha, maybe at the cost of low-end torque. The easy way will be better flowing from cat and back, and increasing the revs modestly. |
#48 |
Drives: Clio TCE
Soravia can you post the picture of the engine with the headers? I haven't seen them yet.
The coating you see on the "showcase" engines are not there on the finished products, sometimes even the design of them is different, the "show" engine has tubular, well designe, expensive headers, the one son the car on sale are stamped headers, shorter and not equal length. Sometimes the difference is just in the finish they are chromed, polished or coated. I think we could develop a dual diameter, equale length manifold for the 86, which could give a 10 hp increase by itself, if the ECU is able to adjust enough. On the Civic Type R it's very effective. |
#49 | ||
Drives: 2006 Subaru LGT
#50 |
Drives: Clio TCE
The key is the revs...the 86 engine will never revs to 10k, even more than 8k will be probably dangerous.
The S2000 revs to 9200 to get 240 hp after all. The Ariel engine is basically a race engine and by itself costs more than 2 whole 86s! Please be realistic. |
#51 |
Drives: 2013 Firestorm FRS
Subaru designed the motor. Subaru has years of experience with this kind of motor so its a pretty safe bet they supplied the ecu which will be easily hacked by Cobb
There will be Hp left over just in the tune |
#52 |
Drives: Clio TCE
I don't think it's so easy. Modern ECU on NA cars have target (perfect) A/F ratio and advance spark. If the conditions are right (fuel, temperatures, weather, air density...) the car can reach the target and make the most power.
With just an ECU remap you can't make the car magically reach that "sweet spot". You get consistent gains only on car with poor auto-adjustment (old cars) with 100 ron fuel, with cars with DBW throttle limited electronically in ° of opening (AMG) or that suffer from letargic throttle response (R50 Mini Cooper and basically all the 1st gen DBW throttle cars), or with particular camshaft systems (VTEC or similar), where you have more room to play. In case the ECU can adjust itself, you can modify the exhaust and the car will run better, without a ECU remap, as long as the spark advance and the A/Ration are correct. There's no way to increase the efficiency % without any mechanical modifications, you're limited by the law of physics. Car manifacturer engineer are not stupid, you know...they know much more about the car than any aftermarket tuner. It's a completely different argument if you talk about turbo cars, obviously. |
#53 |
Drives: Lightening Red BRZ Ltd.
Supposedly, the ECU is easy to crack from the factory. But I'm not so sure we'll get more than 15-20hp (if that much at all) out of the motor in basic bolt-ons. But, I would imagine that a lightened crank pulley would surely get the best mod for the buck, as it allows the motor to rev faster, and give a feeling of increased torque in the lower speeds and gear.
#54 |
Kuruma Otaku
Big difference here is that COBB doesn't have access to boost limits anymore. What they did was hardly advanced tuning. Hacking the ECU, good for them. But what they did tuning-wise is negligible. Plus letting amateurs 'tune' their own cars then re-flash back to stock, has probably led to the WRX/STI's recent poor reliability hit.
I can't think of an NA car that COBB 'tunes' so don't hold your breath for crazy AccessPort gains. This car will actually need to be properly tuned to get gains (proper header/exhaust/intake sizing).
Because titanium. |
#55 | |
Drives: Clio TCE
We work with quite a few tuners both in Italy (Serial tuning, Autoteknica Pistoia...) and outside (Evolve Automotive, Revotecnik) and not everyone is competent on NA cars. Evolve for example is very good on M engines, they have good maps for our exhaust, plus on this car you can really feel the difference thanks to the sharper but progressive throttle maps. The speed limiter removal is a bonus too... Autoteknica did a very good job on some decat Renault sport clio which had problem at low rpm because the auto-adjust function wasn't enough, and they were clever enough to turn off the "anti-tuning" system which was working on the fuel trim values to bring back the car to standard after a while. Most of the tuners doesn't know how to work with NA engines, especially with direct injection and variable time and/or lift. |
#56 |
Sigh. Cobb hacks the ecu. Sells the tuning rights to authorized tuners who tune it. Hondata did the same thing for the k20. Sct, diabolic sport did the same with the new 5.0 liter coyote motor..... etc all factory tunes run extremely rich and never advance timing to be safe and reliable. It is always easy to get the tune more aggressive and get more Hp.
Also. Tuning WRX/STI makes them more reliable the tune from the factory is so bad it runs pig rich then at 4k Roms takes a dip and runs dangerously lean head over to nasioc.com and see for yourself its a well discussed problem. So lets not treat engineers like they are einstiens |
| The wheel bolt pattern is... | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 193 | 02-29-2012 06:04 PM |
| Mods? | Bruninho8 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 12-06-2011 06:11 PM |
| Estimated Price.. | SLeRoux92 | Scion FR-S / Toyota 86 GT86 General Forum | 44 | 05-25-2011 11:58 AM |
