Old 05-26-2013, 11:33 AM   #85
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
It was a mass email
Sent from my HTC One using Tapatalk 2
Old 05-26-2013, 11:40 AM   #86
xjohnx
Grip>Slip
xjohnx's Avatar
Thanks. I'll have to get him to add me. Won't bug him about it now though.
Old 05-26-2013, 11:45 AM   #87
vtmike
vtmike's Avatar
Drives: Scion FR-S
So was he saying the tune didn't have the fix included yet? When I contacted him about purchasing a tune he said it had been in the tune for a month now.
vtmike is offline   Reply With Quote
Old 05-26-2013, 01:31 PM   #88
Opposed
Drives: 2013 Asphalt FR-S
Well, looks like I'm in this club now too. Mine has been doing this since new, but only discovered it during cold Starr ups in the winter. But it wasn't predictable. I don't have any CEL's, runs and starts great when its warm.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 05-26-2013, 01:47 PM   #89
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by whitefrs View Post
While John was tuning it
Right, but what happened to cause him to suspect that the seals had failed. Was it something that appeared in datalogs? a sound he heard? Something else?
Sportsguy83 (05-26-2013)
Old 05-26-2013, 02:56 PM   #90
vubaru
Now with Boost!
vubaru's Avatar
Drives: 2013 SWP BRZ Ltd.
Originally Posted by xjohnx View Post
or someone less scrupulous might try flashing back to stock and taking it into the dealer for warranty repair.
Or, you know, you could just be honest and take the car as-is to a mod friendly dealer, turbo and all, and see if they warranty it based on the fact it's an OEM issue.
It worked for me with the VVTI failures! Livermore Subaru just gave me a thumbs up and complimented my mods, lol.
vubaru is offline   Reply With Quote
Old 05-26-2013, 11:48 PM   #91
xjohnx
Grip>Slip
xjohnx's Avatar
What exactly was it doing during those cold starts? Noise? CEL?
Old 05-27-2013, 10:35 AM   #92
Opposed
I have been getting the popping noise in my intake during initial cold start-up. It does it a couple times and stumbles then its fine. No CEL's yet. Its been doing this since new and I now have a little over 10k miles.
Old 05-27-2013, 11:42 AM   #93
xjohnx
Grip>Slip
xjohnx's Avatar
I got a pop in the intake only (it only happened on one or two occasions) when attempting to get the car to turn over for cold-start on some of the earlier E85 tunes.
It only happened if i tried to start 4 or 5 times in a row in pretty quick succession. I've never heard it while in motion or under load. I'm assuming mine was probably caused more by the quick repeated start attempts vs an injector seal. What do you guys think, is that a safe assumption?
Old 05-27-2013, 12:24 PM   #94
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Does any one know how much a shop will charge to replace all 4 seals
Old 05-27-2013, 12:24 PM   #95
Opposed
Its hard to say. Im on the same boat as you. I don't have any issues under load at all, or if its warm out. It will start up with no issues on a warmer morning.
Old 05-27-2013, 12:35 PM   #96
xjohnx
Grip>Slip
xjohnx's Avatar
Did your pop happen during the cranking/turning over or once the car had already started? Have you gotten it lately? What were the temps like when you were starting? Also which version of the E85 rom are you running?
Sorry for all the questions.
Old 05-27-2013, 12:51 PM   #97
vtmike
vtmike's Avatar
Drives: Scion FR-S
There is someone who had them replaced that had the popping after a cold start in cooler weather. Although I believe his would make the noise while reving when still cold.
Sent from my SCH-I535 using Tapatalk 4 Beta
Old 05-27-2013, 02:07 PM   #98
Opposed
\Its ok Pops usually happen after the car was started, typically for the first 5-8 seconds, then it idles fine. I got it this morning actually. Temps were in the mid fifties. I am running his latest 1.11 version of the E85 tune. It also did it on pumpgas as well.
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 05:26 PM
Need Help - 2 codes thrown jpit Issues | Warranty | Recalls / TSB 3 04-20-2013 01:41 AM
Bulb codes JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 1 02-17-2013 04:25 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 06:03 PM
