Old 05-25-2013, 09:54 AM   #169
troek
troek's Avatar
Drives: 2012 Toyota 86
http://www.ebay.com/itm/J2-ENGINEERI...item2325e55481
even if you get the other kit, you dont have to install the catless down pipe. they are the exact same kits, except one has an extra, optional piece.
troek is offline   Reply With Quote
Old 05-25-2013, 12:52 PM   #170
Onealpha
Drives: 2013 Subaru BRZ
Originally Posted by troek View Post
2 kits available. one deletes the 2nd cat, one doesn't.
thanks, ive been wondering what that noise is. so you just put it between the heat shield and the underside of the trunk?
Yup, i removed the heat shield, attachedit to the back of the heat shield and reattached the heat shield to the car.
Onealpha is offline   Reply With Quote
Old 05-25-2013, 08:39 PM   #171
troek
troek's Avatar
nice! i cant wait to try it. i just gotta find a similar product here in japan...
Old 05-27-2013, 05:33 AM   #172
troek
troek's Avatar
This exhaust seems louder inside the car than the outside. I have a theory that its cause its touching the heatsheild and resonating into the cabin. Im gona try hanging it lower with longer exhaust hangers and hopefully kill two birds with one stone.
The Following User Says Thank You to troek For This Useful Post:
Onealpha (05-27-2013)
Old 05-27-2013, 08:30 AM   #173
troek
troek's Avatar
yep, lowering the muffler to not touch the heat shield made it significantly quieter in the cabin. i highly recommend that to anyone running this exhaust. i still hear a weird raspy if i have it in too high of a gear and try to accelerate, i hope its the heat shield bouncing sound wave vibrations and not just from the exhaust. im gona take the heat shield off tomorrow to check.
Edited when i notice the raspy noise.
The Following 2 Users Say Thank You to troek For This Useful Post:
8R6 (04-14-2014), Onealpha (05-27-2013)
Old 05-27-2013, 09:04 AM   #174
Onealpha
Great news. Keep us updated.
Old 05-27-2013, 09:54 AM   #175
Nm86
Drives: Ultramarine
Did you just get longer rubber hangers, or did you just weld new metal hangers onto the exhaust? I'm ordering one right now, finally got the ok from the wife. I think the exhaust sounds amazing in the videos, hoping its just as amazing in person.
Nm86 is offline   Reply With Quote
Old 05-27-2013, 10:01 AM   #176
troek
troek's Avatar
longer rubber hangers. about 1/2" longer. doesn't need to be quite that long but i wanted to give plenty of clearance. now the ONLY downside to this exhaust is that raspy noise when the car struggles in low rpms. hopefully its the heat shield. it sounds amazing in every other part of the rev range.
EDIT: i would recommend the ones with multiple holes so you can get it perfect.
BLACK->BULLET (06-01-2015)
Old 05-27-2013, 05:57 PM   #177
CodyFRS
CodyFRS's Avatar
Drives: Asphalt FRS
So I'm considering buying this, worth it? Is it junk?
CodyFRS is offline   Reply With Quote
Old 05-27-2013, 07:19 PM   #178
troek
troek's Avatar
as far as sound, it is great. but id realy like to see a dyno of before and after. dynos are close to 200 bucks for one run here in japan unless u have a hook up.
Old 07-02-2013, 12:19 PM   #179
Pooverdam
Pooverdam's Avatar
Drives: Whiteout 6MT FRS
[ame]http://youtu.be/JjctGSm6PWY[/ame]
Here is a sound clip of the quad tip.
Pooverdam is offline   Reply With Quote
Old 07-02-2013, 02:58 PM   #180
Ammonia
Ammonia's Avatar
Drives: Whiteout FRS, Audi A4, 135i (sold)
Is it me or is the left set of tips crooked?
Ammonia is offline   Reply With Quote
Old 07-02-2013, 03:00 PM   #181
Pooverdam
Pooverdam's Avatar
Haha could be. I'm trying to find lower hangers cuz right now it's pressed up against the heat shield underneath the spare tire.
Old 07-02-2013, 03:08 PM   #182
Nm86
Drives: Ultramarine
Run by an exhaust shop and get them to adjust it, they heated up the hangers on myne and just pulled it down, that fixed the rubbing issue.
Quad exhaust tips? migle Engine, Exhaust, Transmission 86 09-24-2020 12:45 AM
J2 Quad catback exhaust? bcmakesiteasy Engine, Exhaust, Transmission 22 06-01-2015 04:43 AM
TRD Style Quad exhaust Nafe AUSTRALIA 17 05-11-2013 03:13 AM
Quad Exhaust Lip? Neekowahhhh Scion FR-S / Toyota 86 GT86 General Forum 4 12-17-2012 09:49 PM
Stacked Quad Exhaust quik1987 Engine, Exhaust, Transmission 43 08-16-2012 04:34 PM
