Old 05-25-2013, 01:42 AM   #1
kALMIGHTY
Drives: TRD Ultramarine '13
Cheapest way to get white light?
Basically, I want that white/6000k look without getting an HID kit. I saw some Philips lamps that were a little different from the H11's and would be a simple plug and play after you cut a little tab off in the connector of the bulb. This seems like the cheapest and easiest solution as far as getting the white light, but is there another way as well that is NOT HIDs?
Does anyone have experience with the Philips bulbs I'm talking about? (I can't remember which ones exactly. I think they might have been H9's though.)
Old 05-25-2013, 01:45 AM   #2
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Try the "Cosmetic Modification (Interior/Exterior/Lighting)" section of the forum:
http://www.ft86club.com/forums/forumdisplay.php?f=36
Old 05-25-2013, 02:02 AM   #3
kALMIGHTY
Already been through it...nothing quite answers my question.
Old 05-25-2013, 02:13 AM   #4
BlaineWasHere
Grip>Drift
Drives: FRS
Great, but that's where you should ASK the question.
Old 05-25-2013, 07:57 AM   #5
BadMoon
BadMoon's Avatar
Drives: 2014 GLI Autobahn/Nav
Get yourself a pair of these. I love mine. Bought from this seller. You may find them cheaper. I'm lazy and didnt look.
http://www.ebay.com/itm/Philips-Diam...-/300782917195
BadMoon is offline   Reply With Quote
Old 05-25-2013, 08:13 AM   #6
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
You have a picture of them with your headlights turned on?
Enraged21 is offline   Reply With Quote
Old 05-25-2013, 08:18 AM   #7
BadMoon
BadMoon's Avatar
Give me a sec. I'll go fire them up.
Old 05-25-2013, 08:21 AM   #8
BadMoon
BadMoon's Avatar
Here you are.
The Following 4 Users Say Thank You to BadMoon For This Useful Post:
Enraged21 (05-25-2013), kALMIGHTY (05-27-2013), SoCal_86 (05-26-2013), thientai (05-25-2013)
Old 05-27-2013, 12:31 AM   #9
kALMIGHTY
Here you are.
That's pretty much exactly what I'm looking for. Are there going to be any problems with these bulbs that I should expect before buying them? The Philips H9's I saw in another thread at some point were a bit cheaper (about $30) and they were 6000k, so any recommendations between those and the ones you have?
Old 05-27-2013, 12:59 AM   #10
infinite012
Drives: 13 DGM BRZ Ltd
Aren't H9 going to put out more light than the H11? Go with the H9...
Also, getting a blue tinted bulb is going to harm light output. Think about the last time you sat in a car with window tint. It blocked light, right?
infinite012 is offline   Reply With Quote
Old 05-27-2013, 01:48 AM   #11
kALMIGHTY
So you're saying forget the blue tinted H11's and go with the H9's?
Edit: These are the H9's I'm talking about. http://www.ft86club.com/forums/showthread.php?t=26717
The Following User Says Thank You to kALMIGHTY For This Useful Post:
86WRX (06-23-2013)
Old 05-27-2013, 08:08 AM   #12
BadMoon
BadMoon's Avatar
I was never a guy willing to take a risk at modding bulbs. I've installed HID kits in projector lamps. But never been willing to mess with the other stuff. I get the look I want without the risk. I don't have a problem seeing the road although these do not put out the same light as an HID. There is no comparison.
The Following User Says Thank You to BadMoon For This Useful Post:
86WRX (06-23-2013)
Old 06-23-2013, 03:39 PM   #13
86WRX
Drives: Asphalt
My only concern swapping H9 with H11 will create more problems down the road.
First off H9 draws more electricity than H11 which in the long run had chances to burn the wired and housing of our projectors which are difficult and expansive to replace.
Alternator issue- since the wattage are higher, the alternator works extremely harder to put out energy and heat to keep up with the higher wattage lamps. That will shortens the life of the alternator which costs at least $300 or so to replace.
H9 is a high beam light bulbs. That means we are running a high beam at all time. The heat output and the life of the light bulbs will reflect on how long the bulbs will last.
The choice and decision we made is end up we suffers towards your pocket unless you lease your FRS, then do whatever. Here are my humble $.02
Andrew
86WRX is offline   Reply With Quote
Old 06-24-2013, 05:34 PM   #14
Diode Dynamics
Diode Dynamics's Avatar
If you're going to spend that much on bulbs why not just buy a set of HIDs and be done with it? You will get incredible results with our kit and they start at $89. Plus, we back our ballasts with a lifetime warranty!
PM me if you need help!
Nick C.
The Following 2 Users Say Thank You to Diode Dynamics For This Useful Post:
kombatlion (12-09-2013), OICU812 (12-05-2013)
Cheapest way to eliminate the torque dip allawd Engine, Exhaust, Transmission 42 04-24-2013 09:40 PM
Cheapest way to get 5-Axis or TRD wing in Canada? SkAsphalt CANADA 13 03-21-2013 11:07 PM
LED WHITE COURTESY FOOT LIGHT- Group Buy F-T Exterior Parts - Lighting 2 03-04-2013 04:59 AM
Gram Light equipped white GT86 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 34 02-17-2012 03:20 PM
