Old 01-05-2013, 01:35 PM   #15
DYOLF26
I'm trying to hardwire my escort radar detector and there is no power going to the unused connector that is for the Brz powered rear view mirror. Does anyone with a Brz know where the fuse is? It would really help me out.
DYOLF26 is offline   Reply With Quote
Old 04-17-2013, 02:21 PM   #16
HotSauce
Drives: 2013 Scion Fr-s Firestorm
+1 I followed this DIY and after about 2 seconds the fuse on the valentine power block, the thing where you plug in the phone cord, blew and afterwards the connector doesn't seem to have power. It still works using the cigarette lighter adapter so I guess I'm doing that until i can figure this out.
HotSauce is offline   Reply With Quote
Old 04-19-2013, 01:45 PM   #17
HotSauce
Still no power to the rear view mirror harness but i noticed something interesting, the DRL no longer run. So I checked the fuses both under the hood and under the dash, unless the fuse is on something totally unrelated I haven't found one that has blown. still no luck in getting power back to either
Old 05-26-2013, 12:31 PM   #18
zahrtman2006
zahrtman2006's Avatar
Did you ever figure this problem out HotSauce?
As for the pictures, i took this after the fact so, there is electrical tape covering the connector.
Pry from the rear forward, it will come out very easily, i disconnected the dome light to allow more room with less interference, then like Doc said, reach around the dome light well for that unused connector, he used U-shaped connectors, i just tapped into the wire and added quick disconnects ( i dont plan on ever needing that harness anyway).
NOTE: I would HIGHLY recommend feeding the wire through the gap at the windshield BEFORE wiring, i did not and had quite a time trying to force the thicker end of the wire (where the adapter is) through that gap.
Thanks to Doc for the DIY, that how i did mine
zahrtman2006 is offline   Reply With Quote
The Following User Says Thank You to zahrtman2006 For This Useful Post:
Chad86 (03-28-2015)
Old 05-26-2013, 10:23 PM   #19
HotSauce
No luck yet... :/ I've been planning on having them take a look at it under warranty when next time I get around to the dealership though
Old 05-26-2013, 10:50 PM   #20
zahrtman2006
Do your lights work when you remove the radar detector wire? aka back to "normal"
Old 05-27-2013, 03:46 PM   #21
HotSauce
I rewired the radar detector down the passenger pillar to the glove box plug in and removed all wires from the other attempt, and still no DRL or power mirror functionality. However the high beams still work so its more of an issue of the power mirrors not adjusting if anyone else were to drive my car.
Old 06-01-2013, 03:53 PM   #22
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Heads up it is the 1st 10amp fuse under the dash on the right side in the manual it is the number 1 fuse listed.
2superblus is offline   Reply With Quote
The Following User Says Thank You to 2superblus For This Useful Post:
HotSauce (06-03-2013)
Old 06-03-2013, 02:37 PM   #23
HotSauce
Confirmed it is listed on the panel as ECU ACC 10 amp, replaced and it restored full functionality to mirrors and DRL THANKS!
Old 09-15-2013, 12:06 AM   #24
benlaz88
Drives: 2013 Asphalt FRS
I'm trying to connect my radar detector on the connector that was not use that Doc mention. However, i use my electrical meter and it did not show its has any power. Do i need to put a fuse in the fuse box or am i missing something? If i do need fuse, which fuse do i put in?
benlaz88 is offline   Reply With Quote
Old 10-05-2013, 06:36 PM   #25
Furinax
Drives: Accord 2007
Hey, just wanted to say thanks so much! I tried this today and it worked!
My V-1 had been plugged into my ACC port next to the driver's side and it was fine for about 6 months then when I went on vacation and came back I plugged it in and it kept blowing fuses for some reason. I plugged it into the one in the glove box and that one blew too... so I was going to hardwire it and maybe send it in for repairs thinking there was a short in the V-1.
Since this wire isn't used I figured hey why not try it! For reference, I used blue crimp connectors (like this: https://dlnmh9ip6v2uc.cloudfront.net...591d000000.JPG) which you can get for $1 at Lowe's. Sadly, I bought the crimper with it thinking I needed it but you really don't even need to cut the u or crimp anything. Just jam the "u" into the back of the plug where the wire meets the adapter and isolate the negative and positive leads. It was tough because I had to fiddle with it in order to get both connected properly, so the battery had to be connected. Also, I needed to strip down the wires that I got from the V-1 hardwire kit in order to connect to those crimp junctions. Maybe if I used the crimper I wouldn't have to wrap the wires around the other prong and tape it up! =(
Anyway, thanks!
Furinax is offline   Reply With Quote
Old 07-06-2014, 06:54 PM   #26
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Just wanted to bump this in case anyone was having this same issue with blowing this fuse after installing their radar detector in the headliner. Replacing the 10a ACC ECU fuse fixed the mirrors and drl
Cockatoo is offline   Reply With Quote
Old 10-27-2014, 06:50 PM   #27
Caspeed
Caspeed's Avatar
Drives: FRS-RS1, Triumph Speed Triple, Lola
Originally Posted by Doc View Post
Hey guys. Here is FYI for FRS owners who want to hardwire their radar detector but don't want to run the wires to the fuse box or accessory plug.
If you pop out the dome light (grasp the edges and easily pull down, the plastic clamps will release and pop out). Feel around where the dome light hole is in the headliner and about an inch from the opening, towards the passengers side, you will feel wiring that is bundled with a grey foam at the end.
Easily pull the grey portion down. That unattached electrical connector is for the power rearview mirror on the BRZ and not used on the FRS. There are 3 wires (blue, black, grey). The middle black wire is the ground and the grey is the power and ONLY on when the ignition is on.
I used two small, blue, U shaped metal electrical connectors with half of the U cut off and stuck them in the back of the wiring harness (grey power, black ground), wrapped the connections some with electrical tape, then connected the hardwire kit that came with the V1. Secured all the wires so there was no rattle in the headliner. Reattached the dome light. This is just like using an invisicord.
Oh, you can feed the wire to the radar detector through the headliner towards the windshield, there is a small gap between the headliner and windshield.
Hope this helps. Doc.
Very helpful thanks for the info!!!! I used a Blend Mount and a Mirror Tap (it plugged into the backside of the connector} Sweet!!!!
Caspeed is offline   Reply With Quote
Old 10-27-2014, 07:31 PM   #28
vividracing
vividracing's Avatar
Nice work with this one!
vividracing is offline   Reply With Quote
DIY-Replacing Rear View Mirror/Hardwire Radar Detector Lil Abner DIY (Do-It-Yourself) Guides 40 06-11-2020 02:48 PM
DIY: Hardwiring your radar detector speedracer38 DIY (Do-It-Yourself) Guides 108 09-08-2019 10:06 PM
BRZ hardwire radar. Jive Turkey DIY (Do-It-Yourself) Guides 12 03-20-2015 12:11 AM
Win a Laser/Radar detector! raul Off-Topic Lounge [WARNING: NO POLITICS] 0 10-10-2012 01:57 PM
Radar Detector? Longhorn248 Other Vehicles & General Automotive Discussions 68 07-14-2012 04:31 PM
