Old 05-26-2013, 12:33 PM   #15
jamesm
this has got me kind of worried. my car is in the shop getting a turbo kit right now, and i haven't had any of the TSB updates people are talking about. I just got my car a month or two ago, should I be safe from this? how long ago did they figure this out and start correcting them at the factory?
Old 05-26-2013, 12:34 PM   #16
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by whitefrs View Post
just read the codes on my CEL
P117B and P1171 Bank 1 too lean
How are you 1000% sure it is your DI seal that is shot?
Old 05-26-2013, 12:35 PM   #17
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Welcome to the turbo world bud
as per @Visconti
Old 05-26-2013, 12:37 PM   #18
Sportsguy83
Drives: Limited BRZ
as per @Visconti
More detail, what is the car doing that would lead him to reach that conclusion?
Old 05-26-2013, 12:44 PM   #19
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
im not really sure as im new to all this tuning stuff, so maybe @Visconti can chime in but from my understanding the car was running too lean
Old 05-26-2013, 12:45 PM   #20
lexusb3
Drives: FRS
^^^ so the 305? Isn't the real power u will most likely make more ?
lexusb3 is offline   Reply With Quote
Old 05-26-2013, 12:53 PM   #21
jamesm
oh i'm not new to the turbo world. nearly every car i've owned in the last 10 years has been turbocharged. i'm a long-time fan of turbocharging lol. i just want to know whether or not my car is effected.
Old 05-26-2013, 01:22 PM   #22
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Really??? I want more power
Sent from my HTC One using Tapatalk 2
Old 05-26-2013, 01:22 PM   #23
Sportsguy83
Drives: Limited BRZ
So, you got on the Dyno, were running lean, got helped with fuel pump install, got the fuel pump install sorted out but still was running lean? Just trying to get as much info as possible and see if by any chance I have it too, not trying to be an ass at all.
My advice to you, whenever someone tells you something and you really don't know or understand, ASK. That is how you will learn!!
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
lexusb3 (05-26-2013), skatery1989 (05-26-2013)
Old 05-26-2013, 01:29 PM   #24
lexusb3
Drives: FRS
whats your power goal?
Old 05-26-2013, 01:42 PM   #25
Gen
Drives: Scion FR-S
Mine are 7,000 miles in ???? And still working
I'm at about 4k on the turbo and got mine in july. No issues with this...
Gen is offline   Reply With Quote
The Following User Says Thank You to Gen For This Useful Post:
Old 05-26-2013, 02:12 PM   #26
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Will talk to john more about it
Old 05-26-2013, 02:13 PM   #27
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
350 whp
Old 05-26-2013, 02:27 PM   #28
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
I was wondering if these are the stock injectors or aftermarket. I have seen a few issues with the design of aftermarket ones (I'm a hydraulics mechanic for aircraft). The seals on the aftermarket pumps and a injectors don't seem to be up to par. I would use high temp back up teflon rings on the back side of a high grade seal. This will make you good for temps over 300 degrees and pressures up to 6000psi. It's over kill but better to have to much than to little.
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 06:33 PM
Direct Injector Leaking Carwhisperer Issues | Warranty | Recalls / TSB 356 03-13-2020 12:35 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 04:26 PM
Brake fluid leaking from pistons/seals normal? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 12-06-2012 02:54 PM
Bad window seals? Dzeremijs Issues | Warranty | Recalls / TSB 18 10-26-2012 03:24 PM
