Old 05-23-2013, 12:47 PM   #85
groucho
Drives: '65 Lotus Elan, '05 Elise, '22 BRZ
Sheesh. Apparently WolfpackS2k forgets what this car is competing with. The Miata has all of 167hp (less with an automatic.) The Lotus Elise only tops 200 with a supercharger, and even then, it's not a lot more. A Mini Cooper S is 181. A base BMW 1-series is only 230, with a 3l 6-cyl. The Z4 is only 240 with a turbo. In terms of small performance cars, it is not unreasonably underpowered.
Does this make it a crappy engine? Hell no. Hey, those weirdo Honda guys still go gaga over the old VTEC engines like in the Integra like you apparently have - all of 172hp and 127 lb/ft of torque. What a pile of junk, right? That appears to be what you're saying, if all you care about are the numbers.
Look, if you are so concerned with horsepower, the BRZ is not the car for you. Subaru didn't design or build it for you. Buy a Mustang or wait for a BRZ STI (which will probably still not have a big enough horsepower number.) If you just want a little bit more hp, Mazda would be VERY happy to unload an RX-8 to you.
'65 Lotus Elan S2, '05 Lotus Elise, '22 WRBlue BRZ 6MT Limited
Formerly '13 DGM 6MT BRZ Limited
groucho is offline   Reply With Quote
Old 05-23-2013, 01:06 PM   #86
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
And that's a problem because....?
The compressor shuts down the moment you floor it.
Are you sure about that? I thought it was just high rpm?
Tell ya what, if you find me a DD BRZ that weighs 1900lbs I'll never complain again about it's 200hp engine output.
Old 05-23-2013, 01:09 PM   #87
groucho
I'm pretty sure most A/C systems, at least in performance cars, shut off on heavy throttle.
You're crapping all over the engine itself, not the weight. I am defending the engine itself. Stay on target.
Old 05-23-2013, 01:29 PM   #88
WolfpackS2k
Now just you're just trying to pick a fight. I (and a lot of other people) are saying the engine isn't anything special in this car, given it's weight. I'm sure it would rock my socks off if it was dropped into your 1500lb Elan.
(lovely car btw, congrats on having it)
Old 05-23-2013, 01:53 PM   #89
groucho
"...you can't deny the engine sucks. It has no personality and sounds horrible..."
"...100hp/liter is great, but when the end result is still just 200hp and 151 torque..."
I'm not trying to pick a fight, but you very specifically trashed the engine. Which has a smoother powerband and more power than your VTEC. (You do realize that the BRZ engine, like their turbo engines, has variable valve timing, too...) It's a brand-new, high-compression, square, relatively high revving engine designed for performance. It's a good 'un.
In the car, it's a good match, too - nicely balanced. If you add much more power, you'd have to start working on the suspension and brakes, too, and you'd lose some of the character of the car.
Old 05-23-2013, 03:40 PM   #90
WolfpackS2k
You are correct. Allow to me rephrase that I don't think it's great, given it's application (and given how easy it seems for the aftermarket to get more power from bolt-ons, why didn't the factory crank out more hp from what's already there?).
I would like to offer a minor correction to part of your statement however. The two cam profile VTEC system on my B17A engine is completely different than the variable valve timing on the FA20.
As far as which engine is better yes I think the FA20 is better than the B17A. Overall, though, given that the FA20 is 23 years newer than the B17A, no, it's not that impressive.
B17A: 160hp, 117 ft-lb, 8000 rpm redline, 9.7:1 CR
FA20: 200hp, 151 ft-lb, 7400 rpm redline, 12.5:1 CR
My B17A has 300k miles under it's belt, doesn't burn oil, has never been opened up for any work/maintenance, and still gets 30-33 mpg hwy (despite short gearing from a 4.40:1 final drive). It's a remarkable engine.
Old 05-23-2013, 05:36 PM   #91
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by iLuveKetchup View Post
I think the engine would be fine if the car wasn't so heavy at 2750lbs.
This is heavy?
A SR20DET S13 made 205PS with a curb weight of around 2700.
Yeah, seriously for the price of the car, no one should be complaining.
-alex
Old 05-23-2013, 06:34 PM   #92
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Originally Posted by mav1178 View Post
This is heavy?
-alex
Yes that's heavy. It's the size of a Miata & weighs +300lbs more. It's smaller than the s2k & only under 100lbs lighter. That's heavy.
Granted that it has today's new safety standard that packs in the lbs. Sad that 2750lbs is considered light in today's standards.
iLuveKetchup is offline   Reply With Quote
Old 05-23-2013, 06:39 PM   #93
BRZJonny
Drives: 2013 Satin White BRZ Limited
Smaller then a s2k and Miata? I don't think so...
BRZJonny is offline   Reply With Quote
Old 05-23-2013, 06:42 PM   #94
dsgerbc
Drives: BRZ(sold), STI
Only 150lbs, from HardTop miata that is.
Old 05-23-2013, 06:45 PM   #95
BRZJonny
BRZ/86/FR-S
L - 166.9
W - 69.9
H - 50.6
S-2000
L - 162.7
W - 68.9
H - 50
Miata
L - 155.3
W - 66.1
H - 48
The Following User Says Thank You to BRZJonny For This Useful Post:
iLuveKetchup (05-23-2013)
Old 05-23-2013, 07:34 PM   #96
iLuveKetchup
Drives: EFF JAY
Originally Posted by BRZJonny View Post
BRZ/86/FR-S
L - 166.9
W - 69.9
H - 50.6
S-2000
L - 162.7
W - 68.9
H - 50
Miata
L - 155.3
W - 66.1
H - 48
ah so I stand corrected. Thanks! Still think the BRZ is a heavy car though.
Old 05-23-2013, 08:42 PM   #97
mav1178
mav1178's Avatar
Relative to WHAT?
The most recent "entry level sports car" weighed 3100lbs (350Z), and compared with that this car is much more nimble/fun to drive.
If the car is overweight, how can it weigh less? 2500lbs? If that is the goal, what can be done to save 200lbs, and keep the cost of the car the same?
I don't think this statement is thought out properly in context.
-alex
Old 05-24-2013, 12:30 AM   #98
groucho
The car is about as light as it can get and still cost what it costs. Comparing to the Miata/S2000 is a little unfair - the BRZ is a 2+2, not a two-seater, after all. Regardless, if the S2000 was released today, it's doubtful that it'd be lighter. A better comparison is the RX-8 - which is about 300 lbs heavier.
There's a good video of Subaru engineers discussing some of the work they did to "add lightness" (as Colin Chapman would say) and to keep the weight that is there as low and centralized as possible.
[ame="http://www.youtube.com/watch?v=co4tMJ_4d1A"]New SUBARU BRZ In Detail Film Part 1 - 2013 New Car Review HD - YouTube[/ame]
High pitched whine from sound tube and idle jumping Nourdmrolnmt1 Issues | Warranty | Recalls / TSB 0 04-17-2013 11:00 PM
Tonight: I need a Portland BRZ owner and S2000 owner! DarrenDriven Northwest 2 06-19-2012 02:40 AM
Too late for a BRZ this year? CrashPrime BRZ First-Gen (2012+) — General Topics 10 06-10-2012 12:10 PM
Jumping ship from FR-S to BRZ hfcman CANADA 28 04-24-2012 07:27 AM
Is it too late? Ryuu0u Other Vehicles & General Automotive Discussions 2 08-19-2011 12:56 PM
