| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 | |
In Autobahn withdrawl
Drives: 2015 BRZ Limited Man., WRB
My 2003 BMW had oil change intervals of 18,000 miles. Generally I did it at 15k miles, but if you're really paranoid there's always an oil analysis. Hell, even the U.S. Army stopped doing regular oil changes in garrison, instead defaulting to oil analysis. It's saved them millions of dollars in oil and parts alone, not considering that they have to dispose of or recycle all of their oil. And that's a big admission from one of the largest (if not THE largest) fleet maintenance program(s) in the world. |
#16 | |
Drives: '15 STi Ltd
#17 | |
Drives: 2004 Subaru Forester 2.5XT
Although I think it's overkill, I believe the BRZ/FR-S has a minimum time interval of 7.5 months for warranty purposes. Is that correct? -Dennis |
#18 | |
Drives: RV-7
"The Right Time To Change Your Oil So where does this leave the car owner who was raised on the perceived wisdom of the 3,000-mile oil change? For a full discussion, your next stop should be our related article, "When Should You Change Your Oil?," which will save you hundreds of dollars over the next few years and fully protect your car and its warranty, while limiting the use of a natural resource. The short answer, meanwhile, is to consult your service manual or Edmunds' maintenance section to learn your car's actual oil change schedule... Let the Manual Guide You Oil change information is in the maintenance chapter of your owner's manual." And the Scheduled Maintenance Guide for my Toyota FJ Cruiser specifies replacing the oil and filter every 5,000 miles OR 6 months for normal use, more frequently for towing or off-road use. It makes no distinction between oil type, the schedule applies to dino or synthetic. So long as my vehicle is under warranty, I'll stick to the Toyota factory recommendations using OEM filters. I'm a DIYer so save all receipts in case of any oil related warranty claim as happened last month. My FR-S hasn't arrived yet, maybe someone here can quote their scheduled maintenance guide to see what the latest factory change intervals are. |
#19 |
Drives: RV-7
I found the FR-S Scheduled Maintenance Guide online. In order to keep the factory warranty in force, engine oil and filter must be changed at least every 7,500 miles OR 7½ months, whichever comes first for normal duty, more frequently for severe duty.
http://a230.g.akamai.net/7/230/83646...ranty_2013.pdf Last edited by torqdork; 05-02-2013 at 08:58 PM. |
#20 | |
Edit: What's this I hear about free oil changes from Subaru? Is that a dealer incentive or universal? Last edited by DoomsdayJesus; 05-20-2013 at 05:38 PM. |
#21 | |
Free Subaru oil changes are dealer specific. -Dennis |
#22 | |
Drives: RV-7
I understand what you're saying about analysis vs. changeout, but should an oil related failure occur an owner will need to document oil and filter change receipts (from anywhere or DIY) complying with specified intervals or risk denial of a claim. |
#23 | |
Drives: Scion FR-S/Toyota Yaris
But is says fore severe duty 3500 mile oil change intervals. Which could mean driving 1 mile to work each day since you aren't warming up the car, or driving in a hilly area, or a dusty area, basically anything can be considered severe duty. With this engine it only makes sense to change it every 3500 miles if you know how to read between the lines in the service manual. As far as changing the oil at 1k miles, absolutely. Look at your build date, odds are the oil has been in the engine more than the 5.5 months by 1k miles.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#24 | |
And no use in changing the factory fill too early either, especially when people usually change it to an oil with a weaker additive pack than the oil used at the factory. If the car sits on the lot for 8 months, do you think that the dealer is going to change the oil before you buy it? That's doubtful, IMO. ![]() No use in guessing when all you have to do is have your oil analyzed to determine a safe interval. -Dennis |
| Almost at 1000 miles. Oil change when? | TheGuyWithTheFireStorm | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 08-08-2013 12:31 PM |
| Oil change at 1000 miles. | Dorb | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 03-08-2013 04:18 PM |
| 1000+ miles | jarviz | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 31 | 02-02-2013 12:23 AM |
| Coming up on 1000 miles... | jm1681 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 08-30-2012 02:09 PM |
| 1000 miles | jarviz | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-29-2012 02:42 PM |
