Old 12-10-2011, 04:05 PM   #29
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Originally Posted by Tofu View Post
^^ That looks like shit.
The idea in general is shit too., no piece of cloth is going to look right just separating the spaces.
chulooz is offline   Reply With Quote
Old 12-10-2011, 04:12 PM   #30
Re_Invention
Re_Invention's Avatar
Drives: '22 Tacoma, '19 Macan, '22 BRZ
The general idea is much like your opinion. Other manufactures do it from the factory (911 gt3rs, mustang boss 302) and they don't necessarily look much better. Not to bring up any extra bracing that may coincide with the rear seat removal, it's just aesthetics. If you don't like it, you don't need to go out of your way to say something negative about it.
Re_Invention is offline   Reply With Quote
Old 12-10-2011, 04:16 PM   #31
chulooz
Registered you sir
chulooz's Avatar
None of those cars use a cloth with plain backing to cover their spaces, try again.
It really is just silly, if you want to lose weight that bad, do not add anything.
Old 12-10-2011, 04:20 PM   #32
Longhorn248
Hook 'em
Longhorn248's Avatar
But hey, to each his own right. I don't plan on pulling stuff out of the car once I get it since I'm planning on it being a DD.
Longhorn248 is offline   Reply With Quote
Old 12-10-2011, 04:53 PM   #33
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
LOL at the "performance" drivers who will take out the back seats to save less than 20LB and the add 150LB of amps, woofers and speakers.
Rampage is offline   Reply With Quote
Old 12-10-2011, 05:01 PM   #34
nixeighty6
nixeighty6's Avatar
Drives: Faster than you!
most people thinking of doing this should leave the seat in and spend the time you would have used taking it out and making some cover on reading up on driving theory and race technique.
its all ways silly to me that people that can't run consistent laps think that ten or 50 pounds is going to make a big difference. once you hit a plateau then try taking it out and see how little a difference it makes
plus as i see it, the car is 53/47 so you want weight from the front out, not the rear
keeps your seats
nixeighty6 is offline   Reply With Quote
Old 12-10-2011, 06:18 PM   #35
hartnsol
Drives: 2000 Honda Civic Si
Best mod anyone can do straight out of the box is going to be tires. Removing this and that is trivial if you can't drive and if you can tires are still going to be the best place to start. Why is everyone complaining about a car that, in a world of 3,000lb plus "sports" cars, is already pretty damn light?
hartnsol is offline   Reply With Quote
Old 12-10-2011, 08:31 PM   #36
subaruslow
Drives: subaru
I can tell you removing the rear seat in
ALL IMPREZAS SUBARU
= 2 bolts, weigh=5lbs, literally the seatbacks and cushions are just very light pieces of foam.
You will be able to pull it out, and save it if you need it. Getting it without would save you 100, 150 bucks?
you are better off changing your front seats to save weight, and ditching the side airbags.
subaruslow is offline   Reply With Quote
Old 12-11-2011, 11:59 PM   #37
slidingRalphy
Drives: 1989 240sx- sold 2004-honda pilot
just loose 20 lbs , bonus you will look better too
slidingRalphy is offline   Reply With Quote
Old 12-12-2011, 12:27 AM   #38
Mitch
form follows function
Drives: RIP '13 BRZ
keeps your seats
Haha yeah, fix the nut behind the wheel first. If I pick this car up, you better believe I'm taking it to a couple of autocrosses before I touch anything on it.
Mitch is offline   Reply With Quote
Old 12-12-2011, 06:38 AM   #39
timeatkuu
Fanatic
Drives: N/A
Originally Posted by tripjammer View Post
Don't forget to replace the heavy battery...I think it is at least 35 pounds. There are good 3 pound lithium ion batteries....for less than $300....
^ THIS. You've read my mind good sir.
+ As mentioned, the Exhaust System, Wheels, and Springs/Dampers will be easiest ways to reduce the weight. Maybe even lighter Rotors would do some justice. If the CF Roof is offered as an option, take it. I'd imagine it'd only be slightly lighter, but definitely structurally more rigid.
I'd keep the rear seats for functionality unless you were focusing on track only where every pound counts.
timeatkuu is offline   Reply With Quote
Old 12-12-2011, 06:54 AM   #40
Gardus@Supersprint
Drives: Clio TCE
I don't see the point. It's not a track car, you can get as much weight removed as you want, but you'll still be left behind but almost everything on a trackday.
Just enjoy the car as it is!
If you want a fast car to remove stuff from, just by an Evo or a old M3.
By the way, most of the light exhausts on sale drone a lot when cruising and are build in Taiwan / China, Invidia is one of them, I wouldn't fit on of these on my car.
A nice note it's good but when it doesn't compromise the daily use.
and the read seats...what's the point? They're just foam cushions, and they could always become of some use, it's just not worth it.
Gardus@Supersprint is offline   Reply With Quote
Old 12-12-2011, 08:26 AM   #41
wcbjr
Drives: 2006 Subaru LGT
Lightweight driveshaft? Or is the stocker aluminum?
wcbjr is offline   Reply With Quote
Old 12-12-2011, 11:00 AM   #42
oneday
Opinionated
oneday's Avatar
Drives: Something Red
Doing a "lightweight" drive shaft swap, ala GT5, is utterly pointless. Even if you could shave 7lbs off (which is unlikely given how short the drive shaft will be) it would do next to nothing in terms of performance gain even if you are trying to make a dedicated track car. That weight is already very low in the car and is spread out along the centerline of the car so.
As someone else said, go on a diet.
Most of the cars I drive have nets for windows.
oneday is offline   Reply With Quote
Sit in the rear seat for me ;) (with photos of people in back seat) D4ng3r Scion FR-S / Toyota 86 GT86 General Forum 125 11-14-2013 06:59 AM
Toyota Holds "FT-86 Fastest Painted Website" Event to Help Launch FR-S / FT-86 Snoopyalien24 Scion FR-S / Toyota 86 GT86 General Forum 35 11-26-2011 07:56 AM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 05:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
