Custom User Title
Drives: Asphalt FR-S MT
Why does the fuel pump not do well with ethanol?
We all (most) know of and have the dreaded chirp. It has been known for quite a while that the chirp is emitted from the fuel pump when ethanol enriched fuel is used. But what exactly does the ethanol do that causes the pump to scream?
#2 |
'Senior' Junior Member
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
If I had to guess it would be the less lubricating properties of alcohol vs. petroleum-based gasoline.
BTW, I can only get 10% ethanol here and have no chirp. Or at least my 63 year old ears are so damaged I can't hear it. Then again, no one looks at me funny at traffic lights so maybe it's really not there.
"You'll never know if you don't try" - Shinroko Momose |
#3 | |
I Love custom Turbo kits
Drives: Limited BRZ
Furthermore, if this theory were true, then cars running E85 would sound like they are about to explode and very different then cars running 93, right?
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | SkAsphalt (03-17-2014) |
#4 |
The Answer
Drives: Mazda 2
The pump uses fuel as it's lubricant.
#5 |
Sometimes I get the chirping noise on Shell 91 (zero ethanol), and sometimes it's totally silent on Petro 94 (10% ethanol). It comes and goes throughout a tank, so I don't think it's purely caused by the ethanol content.
| The Following User Says Thank You to wparsons For This Useful Post: | Hardrock4445 (05-22-2013) |
#6 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
The amount of lubrication needed is minimal, and I am not aware of studies that quantify it for this particular setup. E85 is not E100 for this (though not sole) reason. The 15% adds lubrication. My own car started chirping and regular old 93 octane nearly immediately after delivery (bought with 8 miles), and does it when it is hot no matter the fuel. I'm not concerned, it is a 3000 psi direct injection pump. 3000 psi is very loud. If I all I hear is crickets so be it. 8000 miles later no issues.
| The Following 3 Users Say Thank You to Xero-Limit For This Useful Post: |
#7 |
Drives: 13 FR-S, 12 CLS AMG, 05 Lotus Elise
I use e85 and I don't get chirps anywhere. Perhaps because I'm running an aftermarket pump. Are you using the stock pump?
2005 Lotus Elise
2012 Mercedes Benz CLS AMG 6.3 2013 Scion FR-S 2011 Land Rover LR4 2013 Lamborghini Gallardo LP570-4 Superleggera |
#8 | |
Drives: Limited BRZ
I have have used obviously the OEM in tank pump, the Visconti in tank pump and the DW in tank pump and all of them of them have no effect on the HPFP chirping.
#9 |
I've been using E85 for about 6K miles now with no problems.. filled up on 93 a couple of times during that stretch. The "chirping", if there is any, doesn't bother me. I might be one of the few who's never been bothered or worried about it.
#10 |
I don't get chirps :shrug:
2005 Lotus Elise
#11 |
Drives: Limited BRZ
#12 |
I believe toyota at one time thought it was related to ethanol content but from the reports we have on the forum, ethanol content makes zero difference as there are some folks on E Free fuels exclusively that have chirps all the way to people on E85 that have seen no change from E10.
Not to mention the change in lubricating properties from E0 to E10 are minimal at best.....
~Namaste~ |
#13 |
Drives: FR-S 6MT Ultramarine (BeeDrill)
For a while I wasn't sure if I had the chirping or not. Then I heard someone else's car that had it and realized I definitely do not. I've run both pure 91 and E10 94 and never seem to have it. I'm at about 5000 miles.
2013 Scion FR-S - Ultramarine 6MT
| The Following User Says Thank You to A5D5TRYR For This Useful Post: | tripjammer (05-23-2013) |
#14 |
Grip>Slip
| Car fuel pump on... | Genomaxter | Engine, Exhaust, Transmission | 5 | 11-29-2012 10:06 AM |
| Where to get non ethanol fuel? | mhigham | Engine, Exhaust, Transmission | 19 | 11-13-2012 11:27 AM |
| Ethanol fuel treatments | JoeBoxer | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 09-19-2012 11:42 AM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 3 | 08-21-2012 04:53 PM |
| Website that locates ethanol-free fuel | wbradley | Issues | Warranty | Recalls / TSB | 8 | 07-24-2012 12:47 AM |
