Old 05-21-2013, 11:25 PM   #43
ChandlerSwyng
ChandlerSwyng's Avatar
Drives: 2013 Red Subaru Brz
Originally Posted by itdansharpe View Post
Here's my photo response to the image that motivated me...
Looks nice, can I see some side view pics? or just more general pics?
Old 05-22-2013, 12:18 PM   #44
itdansharpe
itdansharpe's Avatar
Sure:
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
The Following 4 Users Say Thank You to itdansharpe For This Useful Post:
jflogerzi (09-07-2013), Rectify (08-14-2013), theseloaded86hips (09-08-2013), ts87 (08-04-2013)
Old 05-22-2013, 04:49 PM   #45
Ryuu0u
(=^・ェ・^=)
Ryuu0u's Avatar
Drives: 2013 FRS, '08 GSXR 600
Originally Posted by GoForStoke View Post
I was in the same boat but ultimately decided on the gunmetal after seeing this pic:
From this thread: http://www.ft86club.com/forums/showp...7&postcount=54
I think I'm going this route after I pick up my FRS. I like that it looks more performance oriented but also looks like a factory option.
Ryuu0u is offline   Reply With Quote
Old 05-22-2013, 05:32 PM   #46
ChandlerSwyng
Sure:
Thanks man, I definitely think i'm doing black. What's your setup?
Old 05-22-2013, 11:27 PM   #47
vinnie86gt
Drives: Pearl White 86 GTS
they do look quite sexy..well done
Do you know how much they weigh?
vinnie86gt is offline   Reply With Quote
Old 05-23-2013, 04:20 AM   #48
TRD_86
Drives: 2013 86 white
Sure:
Enkei Raijin. Hankook Ventus V12 evo K110
Front: 245/35 - 18x8.5 45mm
Rear: 265/35 - 18x9.5 45mm
Drop: Eibach Sportlines
Look really good. Did you set up similar size tires and where did you order the raijin from? I'm thinking to go w/ silver for my setup.
TRD_86 is offline   Reply With Quote
Old 05-23-2013, 11:56 AM   #49
itdansharpe
I went with Tire Rack. Thanks guys.
The Following User Says Thank You to itdansharpe For This Useful Post:
TRD_86 (08-24-2013)
Old 05-23-2013, 09:07 PM   #50
Scaldy
Scaldy's Avatar
Drives: 2013 red FR-S mt
This is exactly what I'm looking for.
Scaldy is offline   Reply With Quote
Old 06-03-2013, 06:55 PM   #51
TRD_86
I like the 265 tire fitment for rear, but not sure about the 245 wide tires for front. Should I go with 235x40x18 V12 tires which may easier to fit than the wider 245 for front? I already have eibach prokit w/stock rims.
Old 06-03-2013, 08:37 PM   #52
itdansharpe
Your call! The widths are so close I can't see there being much difference either way.
TRD_86 (08-24-2013)
Old 06-20-2013, 10:09 PM   #53
Hagbard
Hagbard's Avatar
Enkei Raijin 18x8.5 - 18x9.5
Front 18x8.5 +45 with 225/40
Rear 18x9.5 +45 with 255/35
Shop is crazy dusty, just needs a bit of a drop now.
Rear Side View
255 beside the stock
Head on view at side lot more out then stock
Hagbard is offline   Reply With Quote
The Following 2 Users Say Thank You to Hagbard For This Useful Post:
normancw (06-21-2013), tinma (07-31-2013)
Old 06-22-2013, 12:41 PM   #54
TRD_86
look good. Just a little poke about ~1/4" but it can be twist in w/ camber and spring drop. Can you describe the drive and feel compare to stock?
Old 06-22-2013, 01:17 PM   #55
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Looks good. A great combo. We just loaded this on our site the other day. Love how these look!
FT-86 SpeedFactory is offline   Reply With Quote
Old 06-22-2013, 03:55 PM   #56
Hagbard
Hagbard's Avatar
Originally Posted by TRD_86 View Post
look good. Just a little poke out about ~1/4" which you can be twist it in w/ camber together w/ spring drop. Can you describe the car drive and feel compare w/ the stock wheel/tire?
Thanks, so far car feels about the same as it did with stock wheels, more grip in the corners but you can still make it kick out if you want like stock, so i think no fun factor lost at all like this, just more grip hopefully it stops raining so i can go drive more in the dry soon,
Thanks for the camber tip i will look into that when i look for springs, cause it does need just that little bit of a drop for sure. The good thing tho no rub and nothing to worry about stock with this wheel setup.
Wheel Directory: Enkei Raijin 18x8.0 +45 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 66 03-30-2018 11:37 AM
Wheel Directory: Enkei Raijin 18x8.5 +45 SWPBRZ415 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 62 11-28-2016 03:51 PM
Enkei Raijin Mesh Wheels - 18x8.5 / 18x9.5 in custom 5x100 FR-S / BRZ fitment GuerillaRacing Wheels and Tires 193 05-26-2015 05:55 PM
Enkei Raijin Wheels: IN STOCK - 18x8.5 & 18x9.5 Concave Touge Factory Wheels and Tires 27 04-03-2015 05:33 PM
enkei raijin 18x8 raven frs thebear21 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 08-06-2012 03:03 PM
