Old 05-22-2013, 12:54 AM   #351
enouf
Mr. Grumpy
enouf's Avatar
Drives: 86 GT, Fuji Red, MT
Screw (pun intended) the numbers - @robispec's car sounds like a friggin spaceship. The whine makes me wee just a little...
enouf is offline   Reply With Quote
Old 05-22-2013, 01:16 AM   #352
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Ok, I did this once before in one of the "Lost" Innovate threads, so let's do it again:
First, let's convert the units to something more familiar.
Stock 106kW = 143hp
Final 163kW = 219hp
Now, stock, we know the engine produces about 200hp. And a good rule of thumb is that a RWD with a manual transmission and independent suspension loses about 15%. So:
.85 * 200 = 170rwhp
That's a little on the high side, but still in the neighborhood of most stock dynos which land around 165hp. So we know we're on the right track. To keep things conservative, however, let's go with 165rwhp.
So we have what we should see at the wheels stock and what this dyno is showing. We can determine the percentage difference here.
165 / 143 = 1.15
A dyno that would report 165rwhp on a stock car is reading 115% of the dyno used on this graph. We can now figure out where the modified numbers would be:
219 * 1.15 = 251rwhp
Not the biggest numbers we've seen, but very respectable. This puts the crank hp at roughly:
251 / .85 = 295hp at the crank.
What I REALLY like is the shape of the torque curve. Lots of meat where it counts. This kit will be a dream at AutoX for those like me that don't give a fig about classing. The tough part will be getting the rears to hook coming out of the corners. But that's half the fun.
The Following 5 Users Say Thank You to Draco-REX For This Useful Post:
Asphaltfrs1 (05-22-2013), Batman (05-22-2013), Calum (05-22-2013), robispec (05-22-2013), Sonolin (05-22-2013)
Old 05-22-2013, 01:24 AM   #353
Asphaltfrs1
Asphaltfrs1's Avatar
Drives: 2013 asphalt fr-s
I'm definitely gonna wait out for this, I love the whine it makes. And those are really good numbers for a daily. Well for me at least.
Asphaltfrs1 is offline   Reply With Quote
The Following User Says Thank You to Asphaltfrs1 For This Useful Post:
Batman (05-22-2013)
Old 05-22-2013, 01:30 AM   #354
Batman
Easy, Tiger.
Batman's Avatar
Drives: Tiguan, S4, SBC 350 Wrangler
Stock 106kW = 143hp
Final 163kW = 219hp
.85 * 200 = 170rwhp
165 / 143 = 1.15
Two V8s, one turbo, 12 Wheels total.
Batman is offline   Reply With Quote
Old 05-22-2013, 01:58 AM   #355
sw20kosh
Drives: 2013 Black FR-S
It is no secret I like this kit too.
I do want to point out that what your math has deduced (250 whp @ 7 psi) is what the 'other' supercharger makes at 9-10 psi. *ducks for cover* This run was on higher octane though so it is not apples to apples - I do understand that.
And I wont comment on area under the curve differences as it is pretty obvious.
The Following User Says Thank You to sw20kosh For This Useful Post:
Calum (05-22-2013)
Old 05-22-2013, 02:56 AM   #356
Sithspawn
Drives: '14 Hot Lava FR-S w/Flappy Paddles
Originally Posted by tom@kartboy View Post
Interesting read on screw type blowers from Kenne Bell.
http://kennebell.net/KBWebsite/Commo...romcatalog.pdf
Most thing i find interesting is the charge temps at the lower PSI AKA this kit.
What do you think @robispec?
Tom
I'm not a fan of Kenne Bell's literature on their website. It is often inaccurate and presents an incomplete picture. I've also seen quite a few technical errors in their writing as well. Take it with a grain of salt.
Sithspawn is offline   Reply With Quote
Old 05-22-2013, 07:19 AM   #357
Calum
That Guy
Drives: 2013 asphalt FRS MT
So what you're saying is that this system should have less of EVIL heat issues, easier installation, no wires to cut, no holes to drill, should make the same peak power but at a lower pressure, and has more area under the curve.
Why are you ducking? Unless he's back....
The Following User Says Thank You to Calum For This Useful Post:
sw20kosh (05-22-2013)
Old 05-22-2013, 07:57 AM   #358
2forme
No, he's not back, but I'm sure he's throwing an epic fit reading this thread.
The Following 2 Users Say Thank You to 2forme For This Useful Post:
Calum (05-22-2013), sw20kosh (05-22-2013)
Old 05-22-2013, 08:39 AM   #359
Calum
That Guy
And now I have to clean the up the milk that just sprayed out of my nose. You know what hurts? Cheerios moving through your nose at high velocity. Fuckin' ouch!
The Following 2 Users Say Thank You to Calum For This Useful Post:
Sportsguy83 (05-22-2013), wparsons (05-22-2013)
Old 05-22-2013, 08:46 AM   #360
2forme
Sorry man. Go with Cinnamon Toast Crunch. They hurt less in that situation
Calum (05-22-2013), Sportsguy83 (05-22-2013)
Old 05-22-2013, 09:58 AM   #361
swift996
swift996's Avatar
The absolute numbers aren't bad, it's just difficult to understand the power curve with the scale they used.
It looks like ~+60whp at 4K RPMS!
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 05-22-2013, 10:03 AM   #362
OrbitalEllipses
Drives: Attitude
The cinnamon would likely burn more. I recently made the switch after 15 years of Cinnamon Toast Crunch to Frosted Flakes...can't say I'd prefer one over the other moving through my nose.
Old 05-22-2013, 10:13 AM   #363
2forme
Ahh, I was going based off texture. CTC seems to soften up faster than Cheerios. Didn't even think about content. Good catch!
Old 05-22-2013, 12:13 PM   #364
KevinBRZ
Going by the above math, this makes about 252-258 lb-ft of torque at 5400 rpm, since it is 15% lower?
295 HP and 255 torque with 2700-2800 pounds of weight will be very respectable. A little less at 91 octane.
KevinBRZ is offline   Reply With Quote
Bullet/Sprintex/Innovate on the bullet website JoeBoxer Forced Induction 333 04-18-2013 11:07 AM
Still searching for an FR-S? 2 available in Little Rock Moshpit37 Southwest 9 01-02-2013 11:32 AM
Bullet SC 86 Loki556 AUSTRALIA 9 08-08-2012 02:39 AM
Searching Inventory in the SE Erroneous Southeast 40 07-23-2012 05:40 PM
