#351 |
Mr. Grumpy
Drives: 86 GT, Fuji Red, MT
Screw (pun intended) the numbers - @robispec's car sounds like a friggin spaceship. The whine makes me wee just a little...
#352 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
Ok, I did this once before in one of the "Lost" Innovate threads, so let's do it again:
First, let's convert the units to something more familiar. Stock 106kW = 143hp Final 163kW = 219hp Now, stock, we know the engine produces about 200hp. And a good rule of thumb is that a RWD with a manual transmission and independent suspension loses about 15%. So: .85 * 200 = 170rwhp That's a little on the high side, but still in the neighborhood of most stock dynos which land around 165hp. So we know we're on the right track. To keep things conservative, however, let's go with 165rwhp. So we have what we should see at the wheels stock and what this dyno is showing. We can determine the percentage difference here. 165 / 143 = 1.15 A dyno that would report 165rwhp on a stock car is reading 115% of the dyno used on this graph. We can now figure out where the modified numbers would be: 219 * 1.15 = 251rwhp Not the biggest numbers we've seen, but very respectable. This puts the crank hp at roughly: 251 / .85 = 295hp at the crank. What I REALLY like is the shape of the torque curve. Lots of meat where it counts. This kit will be a dream at AutoX for those like me that don't give a fig about classing. The tough part will be getting the rears to hook coming out of the corners. But that's half the fun.
| The Following 5 Users Say Thank You to Draco-REX For This Useful Post: | Asphaltfrs1 (05-22-2013), Batman (05-22-2013), Calum (05-22-2013), robispec (05-22-2013), Sonolin (05-22-2013) |
#353 |
Drives: 2013 asphalt fr-s
I'm definitely gonna wait out for this, I love the whine it makes. And those are really good numbers for a daily. Well for me at least.
| The Following User Says Thank You to Asphaltfrs1 For This Useful Post: | Batman (05-22-2013) |
#354 | |
Easy, Tiger.
Drives: Tiguan, S4, SBC 350 Wrangler
![]() Quote:
Two V8s, one turbo, 12 Wheels total.
#355 | |
Drives: 2013 Black FR-S
I do want to point out that what your math has deduced (250 whp @ 7 psi) is what the 'other' supercharger makes at 9-10 psi. *ducks for cover* This run was on higher octane though so it is not apples to apples - I do understand that.And I wont comment on area under the curve differences as it is pretty obvious. |
| The Following User Says Thank You to sw20kosh For This Useful Post: | Calum (05-22-2013) |
#356 | |
Drives: '14 Hot Lava FR-S w/Flappy Paddles
#357 | |
That Guy
Drives: 2013 asphalt FRS MT
Why are you ducking? Unless he's back....
| The Following User Says Thank You to Calum For This Useful Post: | sw20kosh (05-22-2013) |
#358 | |
#359 |
That Guy
| The Following 2 Users Say Thank You to Calum For This Useful Post: | Sportsguy83 (05-22-2013), wparsons (05-22-2013) |
#360 |
| The Following 2 Users Say Thank You to 2forme For This Useful Post: | Calum (05-22-2013), Sportsguy83 (05-22-2013) |
#361 |
The absolute numbers aren't bad, it's just difficult to understand the power curve with the scale they used.
It looks like ~+60whp at 4K RPMS!
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#362 |
Drives: Attitude
#363 |
Ahh, I was going based off texture. CTC seems to soften up faster than Cheerios. Didn't even think about content. Good catch!
#364 |
Going by the above math, this makes about 252-258 lb-ft of torque at 5400 rpm, since it is 15% lower?
295 HP and 255 torque with 2700-2800 pounds of weight will be very respectable. A little less at 91 octane. |
| Bullet/Sprintex/Innovate on the bullet website | JoeBoxer | Forced Induction | 333 | 04-18-2013 10:07 AM |
| Still searching for an FR-S? 2 available in Little Rock | Moshpit37 | Southwest | 9 | 01-02-2013 10:32 AM |
| Bullet SC 86 | Loki556 | AUSTRALIA | 9 | 08-08-2012 01:39 AM |
| Searching Inventory in the SE | Erroneous | Southeast | 40 | 07-23-2012 04:40 PM |
